GS1100 vs GSXR600 Swingarm
- supercharged
Re: GS1100 vs GSXR600 Swingarm
29 Dec 2008 00:14 - 29 Dec 2008 00:17
yeah... want to keep the retro look of dual shocks.
Although I teeter with the idea of passenger pegs, i think I'm going to remove the supports for a cleaner look.
This one is "my" bike style... no room for company
KawiConvert - I don't think you could bend the brake pivot mount out of the way. This is the bolt mounting right near the pivot point welded to the main frame... not the passenger peg/exhaust mounts
Mike D
- 79 KZ1000 LTD Supercharged
- 80 KZ1000 1105cc Pridmore/Vetter tribute
- 79 Honda CBX
- 03 Z1000 Mod
- 80 KZ1000 LTD Modified
- 80 KZ1000 LTD PROJECT on Hold
- 78 KZ1000/900 - Street big block
- 78 KZ1000-NEEDS HELP!
- 80 CBX -Project STARTED
- 81 GPZ1100
- GSRX1200
- 80 CB750F supersport... eahhh not so good
- 1988 KZ1000 Police - 50K miles
- 1978 KZ1000 LTD - should be a quick project
- 2001 KZ1000 Police - 30K miles - chromed Sgt Bike GREAT SHAPE
- 79 Honda CBX
- 03 Z1000 Mod
- 81 GPZ1100
- GSRX1200
Last edit: 29 Dec 2008 00:17 by supercharged.
- KawiConvert
29 Dec 2008 00:32
supercharged wrote:
Sorry, joking about the bending it out of the way. I assume if you are putting on a newer swingarm that you would also update the brakes to match.
Do the CBR swingarms work as well? Curious as I may decide to take my kz up another notch on the modifications. Gotta stay busy, if I keep working on it then I never have to ride it.
1978 KZ650 D1 ~ Carb jetting: 107.5 & 20 & 4th groove with pods and 4-1 Exhaust
- cnyl
29 Dec 2008 04:36
Thanks for posting the pics! Now I just have to decide which way to go.
1982 KZ1000 M2 CSR
North Port, FL
Check out my band
www.myspace.com/tukrhill
North Port, FL
Check out my band
- PLUMMEN
29 Dec 2008 04:45 - 29 Dec 2008 04:53
and heres a modded gsxr arm with stock kz1000 arm,any more questions? the stock arm looks like it should be used as a brace on the gsxr arm!:woohoo:
Last edit: 29 Dec 2008 04:53 by PLUMMEN.
- Old Man Rock
29 Dec 2008 06:12
Two issues come to mind but pictures can be deceiving...
1) As BohicaBob mentioned, Pivot bolt hole looks huge in the GSXR... Not a big deal though for you just make an insert (spacer) pivot tube that fits the kawi pivot bolt.
This was required on my project as well... I believe everyone else had to do the same...
2) New/larger tooth count CC sprocket seems to be required.
Pivot tube decking area thickness (chain travel) between the two.
As for the lower passenger foot peg/muffler mount off the frame, cut that sonsabitch off and custom mount for foot pegs and muffler support mounting...
OMR
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- BohicaBob
- supercharged
29 Dec 2008 10:25 - 29 Dec 2008 10:26
On this project, I will use the GSXR arm or another that has not shown up yet...
Will cut the supports, since the GS arm is not for this bike anymore.
Thought of making some sort of passenger peg mount... just in case i come across some hottie hitch-hiking
OH... BohicaBob, your image were an inspiration
they actually had me pick up the GS arm - I may put that on the 1075 (grey) bike.
Mike D
- 79 Honda CBX
- 03 Z1000 Mod
- 81 GPZ1100
- GSRX1200
- 79 Honda CBX
- 03 Z1000 Mod
- 81 GPZ1100
- GSRX1200
Last edit: 29 Dec 2008 10:26 by supercharged.
- BohicaBob
29 Dec 2008 11:27
On my '78 KZ1000 Stage III project bike, I will be fitting a '97 Suzuki Bandit 1200 swingarm. Got the PMC shock mounts to weld on plus I had a pal make me a spacer with an OD of 20 mm and an ID of 16 mm for the '78 KZ1000 swingarm pivot bolt.
- rpiian
- Live to Ride, Ride to Live
10 Jan 2009 06:22
Supercharged-
What year is that GSXR 600 swingarm?
I was planning on doing a conversion soon and I was just curious.
-Ian
-Ian
2006 SV1000S
Carbon Yoshi RS3
ZGDB Smoke Windscreen
Sharealike Clutch Basket Mod
Switchable TRE
13300mi
1981 KZ650 CSR H1
Dual "Pro-Burner" Headlights
ZX-6R Taillight
Tapered Head Bearings
Dyna Wires
Rebel Gears 26T Rear Sprocket
V&H 4-1 Exhaust
20100mi
My little streetfighter...
Carbon Yoshi RS3
Switchable TRE
13300mi
1981 KZ650 CSR H1
ZX-6R Taillight
Dyna Wires
V&H 4-1 Exhaust
20100mi
- PLUMMEN
10 Jan 2009 07:50 - 10 Jan 2009 08:10
well i had a picture of how i modified one of my frames for a gs1100 arm i tried to resize it,now it disapeared!:blink:
Last edit: 10 Jan 2009 08:10 by PLUMMEN.
- supercharged
10 Jan 2009 12:31
rpiian wrote:
Ian - I am using a 1998 and 1999 for 2 projects. Both are the same. Since they have been EZ to find, I have not had to expand my search to other applicable years.
I am getting busier and have not cut the frame out of the way at this time, but expect to accomplish this by end of next week. At that time I will work on my adaptation of the pivot. I'll be happy to share what I find out.
Keep us informed of your progress
Supercharged-
-Ian
Mike D
- 79 Honda CBX
- 03 Z1000 Mod
- 81 GPZ1100
- GSRX1200
- 79 Honda CBX
- 03 Z1000 Mod
- 81 GPZ1100
- GSRX1200
- PLUMMEN
10 Jan 2009 14:18
supercharged wrote:
ya know that hole where monoshock used to go through makes a perfect place for a nitrous bottle!
