GS1100 vs GSXR600 Swingarm
- rpiian
- Live to Ride, Ride to Live
Re: GS1100 vs GSXR600 Swingarm
10 Jan 2009 15:25 - 10 Jan 2009 15:31
Sick, thanks supercharged. I was going to go with a 99 GSXR swingarm on ebay. It looks like there's little or no modification needed (possibly some easy flycutting/machining?). I will most definitely keep you guys posted on how it goes. However, it may be a couple months before I can bring the bike down to school (Darn VT weather!).
2006 SV1000S
Carbon Yoshi RS3
ZGDB Smoke Windscreen
Sharealike Clutch Basket Mod
Switchable TRE
13300mi
1981 KZ650 CSR H1
Dual "Pro-Burner" Headlights
ZX-6R Taillight
Tapered Head Bearings
Dyna Wires
Rebel Gears 26T Rear Sprocket
V&H 4-1 Exhaust
20100mi
My little streetfighter...
Carbon Yoshi RS3
Switchable TRE
13300mi
1981 KZ650 CSR H1
ZX-6R Taillight
Dyna Wires
V&H 4-1 Exhaust
20100mi
Last edit: 10 Jan 2009 15:31 by rpiian.
- supercharged
10 Jan 2009 16:11
keep in mind the fit is good - a little shim on each side, but the 600 arm will require a sleeve in the pivot bolt.
Mike D
- 79 KZ1000 LTD Supercharged
- 80 KZ1000 1105cc Pridmore/Vetter tribute
- 79 Honda CBX
- 03 Z1000 Mod
- 80 KZ1000 LTD Modified
- 80 KZ1000 LTD PROJECT on Hold
- 78 KZ1000/900 - Street big block
- 78 KZ1000-NEEDS HELP!
- 80 CBX -Project STARTED
- 81 GPZ1100
- GSRX1200
- 80 CB750F supersport... eahhh not so good
- 1988 KZ1000 Police - 50K miles
- 1978 KZ1000 LTD - should be a quick project
- 2001 KZ1000 Police - 30K miles - chromed Sgt Bike GREAT SHAPE
- 79 Honda CBX
- 03 Z1000 Mod
- 81 GPZ1100
- GSRX1200
- jezz
- 1981 kz 750e
13 Jan 2009 18:58
will the gs 1100 swingarm work on a kz750e
1981 kz750e
- badrhino
13 Jan 2009 20:35
What about newer ones? Some of the 04-07 are going cheap and they are braced. Some even come with the shock if a guy wanted to go with the single shock conversion. Will these fit?
1980 KZ1000 with a 1982 KZ1000J motor with 1100 pistons and heads, Vance & Hines, 29MM Smooth Bores, Work in Progress
Franken Z!
Franken Z!
- badrhino
14 Jan 2009 09:46
Also, how big of a rear wheel/tire can you go with on the GS1100 arm?
Franken Z!
Franken Z!
- PLUMMEN
14 Jan 2009 10:04
150-160 shouldnt be a problem
- StreetfighterKz
14 Jan 2009 11:02
badrhino wrote:
If you don't mind a little work you can squeeze a 5.5" rim with a 180mm tire in a Gs1100E arm.
Later, Doug
Later, Doug
1978 z1000 Streetfighter
1976 z900 ‘Stripfighter
1978 z1000 w/RC Turbo
1979 z650 Resto-Mod
1983 Gpz750 Resto-Mod
2018 Z900RS
1979 z650 Resto-Mod
2018 Z900RS
- rpiian
20 Jan 2009 11:41
Ok guys. I'm really excited so I'll try my best to hold it in. Just got my swingarm today, GSXR 600 '03. Now, I'm going to need a sleeve for the pivot bolt.
I could definitely turn down and drill some aluminum (pipe or billet)... but out of curiosity, is there any aftermarket company that does this stuff?
My goal after that is a shock setup and lastly, the drive and brakes (w/ new wheel of course). Can't wait to get started!
2006 SV1000S
Carbon Yoshi RS3
Switchable TRE
13300mi
1981 KZ650 CSR H1
ZX-6R Taillight
Dyna Wires
V&H 4-1 Exhaust
20100mi
Carbon Yoshi RS3
Switchable TRE
13300mi
1981 KZ650 CSR H1
ZX-6R Taillight
Dyna Wires
V&H 4-1 Exhaust
20100mi
- SUZM109R
22 Jan 2009 19:51
I put a 02 gsxr600 swingarm on my kaw. kz 1000 and it's was the easy one I ever did and rides real good.
- SUZM109R
22 Jan 2009 19:55
- roy-b-boy-b
23 Jan 2009 02:56 - 23 Jan 2009 02:57
I think i have a GSXR swingarm with all the brake parts.
It is taking up a lot of shelf room and i would like to move it along to someone that wants/needs it. I used a early Ninja swingarm on my bike. Roy
Last edit: 23 Jan 2009 02:57 by roy-b-boy-b.
- supercharged
31 Jan 2009 16:03 - 31 Jan 2009 16:05
Had a little time to try and get the GSXR 600 swingarm fitted. Seems that I may have pick the machinist who thinks to much:( Here is what he said...
The goal for me was to build a collar that would sit inside the needle bearings of the GSXR swingarm and reduce down to the size the the KZ1000 pivot bolt of 16mm.
The issues:
Possible alternative:
Now I have to shop and figure this out.
QUESTION - I know others here have made collars for their swingarm applications... did you worry about the hardened steel over the needle bearings?
The issues:
- The material sitting on the needle bearings would have to be hardened steel, as the needle bearing will 'eat' through steel or aluminum and bind the bearing
- The 16mm bore for a distance of 8.75" is not practical, as the bore will flex and distort the hole
- Multi piece fitment is possible with hardend ends and aluminum center. This seems to be what OEMs use
- More practical approach may be to fit roller bearings at ends - replacing needle bearings - this would be 40mm OD cased (sealed) bearing with any ID 16mm or greater
- Since the exact bearing 40mm OD 16mm ID is not available... Set a collar inside the roller bearings to reduce the ID down to 16mm bolt size - This collar would not have to be hardened, since it will ride on the inside race of the sealed bearing.
Mike D
- 79 Honda CBX
- 03 Z1000 Mod
- 81 GPZ1100
- GSRX1200
- 79 Honda CBX
- 03 Z1000 Mod
- 81 GPZ1100
- GSRX1200
Last edit: 31 Jan 2009 16:05 by supercharged.
