swingarms.com
- cnyl
Re: swingarms.com
24 Dec 2008 19:12 - 24 Dec 2008 19:15Obviously I haven't tried every GSXR arm in every KZ, but I have run my bike with both 600 and 750 arms, and checked that a 1000 arm would fit, and there are various other Suzuki arms including a Busa arm mounted in 750 turbos on my site.
I also know that ZX6, ZX9 and ZX11 arms are all approx 1" too wide. They can still be fitted with some surgery, but the Suzuki arms generally go in easier.
What else will you need? You will need an offset front sprocket (assuming you are using a wider donor wheel), usually you will have to machine the sprocket carrier on the donor wheel, conversion to 530 chain makes clearance a lot easier, the swingarm spindle will need a sleeve (on the turbo the standard sleeve fits inside the Suzuki arm conveniently), and you will need to space out or replace the footrest hangers to clear the wider arm. The more donor bits you have from the bike the swingarm came from the better. Don't forget the chainguard, spindles etc, a complete rear end is ideal. If you are mix-n-matching bear in mind there is quite a lot of work involved in aligning everything, caliper hangers, spacers etc.
Thanks for the great info! Nice to know what i'm getting into.
Oh yeah the year doesn't matter much. The bracing arrangement varies, and the caliper mounts, but not much else. Bear in mind if you are going for twin shocks that the arms are wider on the left than they are on the right, to allow for the chain run...
WOW! It sounds easier to go with the mono shock config.
Thanks again!
1982 KZ1000 M2 CSR
North Port, FL
Check out my band
www.myspace.com/tukrhill
North Port, FL
Check out my band
Last edit: 24 Dec 2008 19:15 by cnyl.
- PLUMMEN
- PLUMMEN
- ds390ss123
Re: swingarms.com
30 Apr 2009 16:31
GOT THE JCM ARM!!! The thing is a work of art. cant wait to fit it. It took 4 months for delivery and a few pestering phone calls but it really does seem to be worth the wait. Especially since it was $850 shipped.
- supercharged
Re: swingarms.com
30 Apr 2009 16:50
Congrats!
PICS!!!
PICS!!!
Mike D
- 79 KZ1000 LTD Supercharged
- 80 KZ1000 1105cc Pridmore/Vetter tribute
- 79 Honda CBX
- 03 Z1000 Mod
- 80 KZ1000 LTD Modified
- 80 KZ1000 LTD PROJECT on Hold
- 78 KZ1000/900 - Street big block
- 78 KZ1000-NEEDS HELP!
- 80 CBX -Project STARTED
- 81 GPZ1100
- GSRX1200
- 80 CB750F supersport... eahhh not so good
- 1988 KZ1000 Police - 50K miles
- 1978 KZ1000 LTD - should be a quick project
- 2001 KZ1000 Police - 30K miles - chromed Sgt Bike GREAT SHAPE
- 79 Honda CBX
- 03 Z1000 Mod
- 81 GPZ1100
- GSRX1200
- ds390ss123
- ds390ss123
- ds390ss123
- ds390ss123
Re: swingarms.com
30 Apr 2009 18:07
Sorry for my not so good ability to get the pics on here properly. There is the arm. And here is the frame with primer ready to fit the arm. Looks like I will be removing the rear foot peg braces.
- ds390ss123
- ds390ss123
Re: swingarms.com
30 Apr 2009 18:58
forks, power coated triple and painted calipers ready for install. progressive springs installed with new seals
- T_Dub
Re: swingarms.com
30 Apr 2009 19:54
Swingarm looks delicious, wish I had the mula for one, but I think mine will be almost as good when I get it. Forks look nice.
1977 KZ650B1
-810cc
-Cavanaugh Racing Head
-Mikuni RS34's
-GPR Muffler
-810cc
-Mikuni RS34's
-GPR Muffler
