Cold Cylinder #2, '81 KZ750 LTD
  • riturbo
  • riturbo's Avatar
Re: Cold Cylinder #2, '81 KZ750 LTD
09 Sep 2025 15:14
#916957
Are you sure your carbs are clean ? Sounds like you pilot circuit might be clogged. Check out this thread.
pic of where to spray carb cleaner in CV carbs - KZRider Forum - KZRider, KZ, Z1 & Z Motorcycle Enthusiast's Forum
Gpz 750 turbo The one I ride
Gpz 750 turbo Not finished
Gpz 750 turbo Not started
Gpz 550 1981
Gpz 550 1983
Bunch of other junk
The following user(s) said Thank You: SnyperX
  • AOB85
  • AOB85's Avatar
30 Oct 2025 01:28
#918501
The other thing is that once the bike has been running and has gotten hot I find it almost impossible to get it to restart. Not sure what that is about.
This is usually a sign of a failing ignition coil, check the resistance after it's hot. As for your run away RPM issue, how sure are you about your float height being correct?
  • SnyperX
  • SnyperX's Avatar Topic Author
03 Nov 2025 12:08
#918680
I am going to look at the pilot circuit again I think. I never sprayed carb cleaner directly, but did use an ultrasonic cleaner when I rebuilt the carbs and "assumed" it got everything nice and clean.
Regards,
SnyperX
1981 KZ750H2 LTD
