Cold Cylinder #2, '81 KZ750 LTD
  • SnyperX
  • SnyperX's Avatar Topic Author
Re: Cold Cylinder #2, '81 KZ750 LTD
08 Jul 2025 08:47
#914445
You need a minimum of around 100 PSI for combustion to occur. I would also check valve lash while your running thru all the rest of a basic checks.
I've already done the valve clearance checks and re-shimmed. The valve clearances are in spec.
Regards,
SnyperX
1981 KZ750H2 LTD
  • Wookie58
  • Wookie58's Avatar
  • Moderator
  • Moderator
08 Jul 2025 08:51
#914446
Have you tried setting the petcock to "prime" and blanking the vacum port on #2 carb ?
  • SnyperX
08 Jul 2025 09:07
#914447
Thought I had done that when my test/secondary fuel tank was connected. I usually hook that up to the fuel line in and then block the vacuum connection on cylinder #2. When doing that got the same result.
Regards,
SnyperX
1981 KZ750H2 LTD
  • SnyperX
08 Jul 2025 09:46
#914448
I was mistaken. With the test tank connected and the vacuum connection blocked on cylinder 2 it fires up and cylinder #2 exhaust pipe is hot as expected. Though I am now also getting a runaway RPM issue. Blip the throttle and the RPMs climb to about 4k and just stay there.
Regards,
SnyperX
1981 KZ750H2 LTD
  • Wookie58
  • Wookie58's Avatar
  • Moderator
  • Moderator
08 Jul 2025 09:50
#914449
Progress then, looks like a vacum leak through the petcock. Sounds like you also have other air leaks given the "hanging revs"
  • SnyperX
08 Jul 2025 09:54
#914450
I already have new carb intake boots as well as new airbox boots. Do I need to start spraying WD-40 or starter fluid in places?
Regards,
SnyperX
1981 KZ750H2 LTD
  • Wookie58
  • Wookie58's Avatar
  • Moderator
  • Moderator
08 Jul 2025 12:52
#914453
You can try WD40 but it tends to be inconclusive unless the leak is huge. Have you tried slackening the throttle cables then operate the throttle linage by hand (this will rule out a mechanical or cable adjustment issue)
The following user(s) said Thank You: Nessism, SnyperX
  • SnyperX
21 Aug 2025 08:20
#916292
Wookie, I did try this and it seemed to operate fine. If I pushed the throttle more closed using my hand it made the engine sound like it wanted to die. So in my mind throttle linkage is not an issue. The bigger issue that is now scaring me at the moment is that all 4 cylinders are showing a cold compression level of only about 100 psi for all 4 cylinders. I did re-shim the valves and hoping that's not impacting anything. Terrified the top end if going to need to come off and if machining is needed I don't know what I will do. No real good machine shops around.
Regards,
SnyperX
1981 KZ750H2 LTD
  • Wookie58
  • Wookie58's Avatar
  • Moderator
  • Moderator
21 Aug 2025 15:06
#916301
Did the revs still hang with the cables slackened off ? forget the compression for now (should be checked "hot" with the throttle wide open)
  • Nessism
  • Nessism's Avatar
22 Aug 2025 07:08
#916326
I'm saddened to hear about your continual problems.  You have put forth a truly honest effort.
If you want to take a pause on this project, and send me your carbs, I'll go through them for you for free.  Just pay the shipping.  I can't assure you that this will solve your bikes problems, but I can assure you that the carbs will NOT be the problem, when we are done.
You already have my contact info, since you bought O-rings from me.  Send another email if you want to move forward...
The following user(s) said Thank You: Wookie58, SnyperX
  • 84_GPz750
  • 84_GPz750's Avatar
03 Sep 2025 13:00
#916760
@SnyperX I just found this thread but have and am still having all of the exact same issues you describe here with my GPz750. Cold cylinder #2, hanging revs once I was finally able to get it to start and idle, charging issues, and currently I'm fighting poor running just off idle.
I'll be keeping a close eye to your progress to see if you find a resolution that I can apply as well.
For my hanging revs, I found a combination of the throttle cable binding up and not fully returning, and the angle of the throttle cable holder bracket needed tweaked.
Best of luck on your project!
  • SnyperX
03 Sep 2025 13:25
#916761
I am going to get back at this tonight. Going to pull the carbs again and check that all the o-rings are seated correctly. Hopefully it's just a carb assembly issue after I cleaned them again because of the cold #2.
Regards,
SnyperX
1981 KZ750H2 LTD
