Going in on eBay electric ignition for 650SR. Suggestions?
- DoctoRot
Re: Going in on eBay electric ignition for 650SR. Suggestions?
09 Apr 2026 10:35
I'm curious how accurate the timing is on the Chinese versions and if the timing curves are the same as the Dyna.
Quality control is the main issue on cheap parts, so you're taking a gamble that you will get a usable one. For a $150 difference it doesn't seem like significant savings to me, but I guess the motorcycle crowd is known for beingcheap bastards frugal, so if it works, it works.
09 Apr 2026 12:16isn't the curve controlled by the factory mechanical advancer ?I'm curious how accurate the timing is on the Chinese versions and if the timing curves are the same as the Dyna.
Quality control is the main issue on cheap parts, so you're taking a gamble that you will get a usable one. For a $150 difference it doesn't seem like significant savings to me, but I guess the motorcycle crowd is known for beingcheap bastardsfrugal, so if it works, it works.
The following user(s) said Thank You: Nessism, DoctoRot, chopper1963
- DoctoRot
09 Apr 2026 14:29
Got the dyna s confused with dyna 2000.
- chopper1963
10 Apr 2026 15:28
"I guess" is the clearly pertinent part of your post.
- DoctoRot
11 Apr 2026 16:03 - 11 Apr 2026 21:40
Last edit: 11 Apr 2026 21:40 by DoctoRot.
