Going in on eBay electric ignition for 650SR. Suggestions?
- chopper1963
30 Sep 2024 08:44
1978 KZ650SR.
These bikes have basically little to no resale value so sticking a big $$$$ electronic ignition on it makes little sense.
There are ebay kits to convert the points ignition to electronic for $60 or so. Has anyone where had good luck with an ebay seller or should I just do the usual ebay due dillagence?
I have a parts bike 1979 KZ650SR but never looked to see if that is points or electronic ignition.
Suggestions welcome.
Re: Going in on eBay electric ignition for 650SR. Suggestions?
30 Sep 2024 08:55
Is this the "Copy" Dyna "S" ? - if so there are a few posts regarding these, generally people seem to have done OK with them
The following user(s) said Thank You: Warren3200gt
- Warren3200gt
30 Sep 2024 10:49
I've fitted several of the Chinesium Dyna systems to bikes for people. Never had one fail electronically only had one cause an issue where the trigger magnet fell out. Glued it back in and been good ever since.
- chopper1963
30 Sep 2024 11:32
Well, there's a lot of different prices. The 4into1 kit is $300. A basic china kit is $54. Any suggestions?
- zed1015
30 Sep 2024 12:36
The 4-1 kit is a real Dyna Ignition but with chinese copy coils and leads.
Most of the cost there is due to the genuine Dyna ignition.
The following user(s) said Thank You: chopper1963
- Warren3200gt
30 Sep 2024 12:49
Your original kawasaki coils will work fine with the copy ignition plate.
There's plenty of resellers of the Chinese ignition plate which all come from the same Chinese sweatshop.
Take your pick from whichever has best price/delivery time.
Just make sure you buy the correct one for your 650 as the one for 900's is a different diameter backing plate.
- chopper1963
01 Oct 2024 05:19
The $50 one comes with zero instruction and 4into1 doesn't do any customer support after the sale. I learned this the hard way.
What would a guy do if he opted for $50? What comes off, what goes where?
01 Oct 2024 05:41
As it's a copy of a Dyna the fitting should be similar - There are several videos of "how to" on YouTube and also I have included a Dyna wiring diagram
- Warren3200gt
01 Oct 2024 07:52
You can download and print the fitting instructions off the Dyna website.
Fitting the Chinesium one is exactly the same.
- sf4t7
01 Oct 2024 16:06
It would be a good time to add a relay and fuse to the coil power supply wiring while you're installing your ignition. Plenty of posts here covering the addition.
BTW I installed one of the 45 dollar no-name Dyna copies and so far so good.
Scotty
1974 Z1A
Yoshimura 987, 10.25:1
welded Z1 crank
Andrews 1X Cams
Delkevic 4 into 1
Superbike bars
530 conversion
1974 Z1A
welded Z1 crank
Andrews 1X Cams
Delkevic 4 into 1
Superbike bars
530 conversion
- Injected
08 Apr 2026 20:41 - 08 Apr 2026 20:42I am not sure if all the China copy Z1 plates are like this but the one I bought was also out of wack. Flipping the backing plates works just fine, but its crazy to think they would all be assembled wrong!Received my Chinese DS2-1 pickup coil today and tried to get it fitted. Prior to removing the old one I put the timing mark on #1/4 advance and when I manually trigger the advance the alignment is spot on. See photo. With the DS2-1 installed and with the same timing mark alignment, manually rotating the advancer fully is putting the magnet just at the start of the pickup tab. It's hard to see in the photo, but if you look closely you can fully see the round magnet.
I recalled someone saying they had to flip the backing plate to resolve this and when I did this it did work out. I now have spark on 1,2,3 and 4. I'm not real happy with how the pickups mount to the plate as the screws are what seems to be too far out of the slot to hold. Would have been better if they aligned on the inner part of the slot.
I have not bought a 650/750 plate yet but will probably get one later on this year and I will be checking it for correct alignment.
1978 KZ650B2 modified project
1981 Z50R Honda tow bike
Last edit: 08 Apr 2026 20:42 by Injected. Reason: sp
- sf4t7
09 Apr 2026 05:07
I think you're referring to a post of mine. Of 3 chinese DS2-1 kits that I have used, two needed the plate flipped and one worked as shipped by using the rotor from a real DS2-1. I think the difference is in the position of the magnet in the rotor, as the pickups seem to be assembled on the plates the same as the real DS2-1's. Easiest way to tell is by installing the unit and noting where the magnet is when ignition is at the F for cylinders 1-4.
Scotty
1974 Z1A
welded Z1 crank
Andrews 1X Cams
Delkevic 4 into 1
Superbike bars
530 conversion
1974 Z1A
welded Z1 crank
Andrews 1X Cams
Delkevic 4 into 1
Superbike bars
530 conversion
