1982 KZ1000J IGNITER ????
- aquaholic
- 1981 KZ1000 J1
- F64
- 81-KZ440D2
Re: 1982 KZ1000J IGNITER ????
09 Oct 2021 13:06 - 09 Oct 2021 13:07
go to your fuse block
key on/ignition switch on
meter DC V
black probe on negative battery post
red probe both sides of each fuse(put the probe on the terminal that
slides over the fuse not on the metal part of the fuse)
tell me the voltages of each fuse combo.
move your red probe to the metal fins of the engine case.
the voltage will be really low but i need to know that number
meter DC V
81-KZ440-D2.
LIC, NY
LIC, NY
Last edit: 09 Oct 2021 13:07 by F64.
The following user(s) said Thank You: aquaholic
- aquaholic
- 1981 KZ1000 J1
09 Oct 2021 13:16
Fuse block starting from the end that the wires come out. 5.87, 5.87, 5.87, 6.60, 6.60. Meter still on DC volts red to engine case 0 volts
- F64
- 81-KZ440D2
09 Oct 2021 13:19 - 09 Oct 2021 13:32
black probe on POSITIVE battery post(pink arrow)
red probe on POSITIVE battery terminal(green arrow)
what is the voltage?
the voltage will be low but i need to know the exact number
photo:revzilla
photo:revzilla
81-KZ440-D2.
LIC, NY
LIC, NY
Last edit: 09 Oct 2021 13:32 by F64.
- aquaholic
- 1981 KZ1000 J1
09 Oct 2021 13:39
Black and red on positive battery post ? 0 volts
- F64
- 81-KZ440D2
09 Oct 2021 13:46 - 09 Oct 2021 13:50
ok, so your issue is around this area(pink square).
red probe on red wire with white stripe
(inside green box connector--do not disconnect--
back probe both sides of the connector)
photo:filebase/Mcdroid
81-KZ440-D2.
LIC, NY
LIC, NY
Last edit: 09 Oct 2021 13:50 by F64.
- aquaholic
- 1981 KZ1000 J1
09 Oct 2021 13:48
Cut off again on the right. you can text me if it's easier 910-713-5455. FB Messenger or whatever is easier for you.
- F64
- 81-KZ440D2
09 Oct 2021 13:50
can you read it now?
81-KZ440-D2.
LIC, NY
LIC, NY
- aquaholic
- 1981 KZ1000 J1
- F64
- 81-KZ440D2
09 Oct 2021 13:52 - 09 Oct 2021 14:02
no voltage at the red/white wire?
black probe on negative battery post?
It will be a 1 into 2 connector.
back probe all 3 wires
back probe both sides of the black wire/yellow stripe
in the blue box with the red probe.
black probe on negative battery post.
Should be less than 0.5V for both sides.
81-KZ440-D2.
LIC, NY
LIC, NY
Last edit: 09 Oct 2021 14:02 by F64.
- aquaholic
- 1981 KZ1000 J1
09 Oct 2021 14:01
11.38 volts on white with red stripe and same on red with white stripe
- F64
- 81-KZ440D2
09 Oct 2021 14:10
open up your fuse block.
find the fuse with white wire on one side
and a red/white wire on the other side (green box).
black on negative post
red probe both sides of the fuse
voltages?
voltages?
81-KZ440-D2.
LIC, NY
LIC, NY
