1982 KZ1000J IGNITER ????
  • F64
  • F64's Avatar
  • 81-KZ440D2
Re: 1982 KZ1000J IGNITER ????
03 Oct 2021 09:30 - 04 Oct 2021 09:16
#856129
Probably best to put the old coil back on. You may just have a wiring issue. Wiring issues are time-consuming to find, but can be complicated by replacing parts.
If I can find some time, I'll help you trace out the wires.
Ok, 3am. Time to figure out what your problem is.
Grab your meter.
DC V
Ignition on, engine not running
everything connected
red probe on positive battery post(metal part of battery)
black probe on negative battery post
note voltage
move your red probe to the red wire at each coil (put your probe on the coil's metal post-this will test the red wire connector's resistance)
note voltage of each wire
Your voltage at the coils should be within 0.5V of the battery voltage check.
81-KZ440-D2.
LIC, NY
Last edit: 04 Oct 2021 09:16 by F64.
The following user(s) said Thank You: aquaholic
  • aquaholic
  • aquaholic's Avatar Topic Author
  • 1981 KZ1000 J1
06 Oct 2021 08:38
#856263
First of all thank you. Your reply is cut off on the right side lol. If you could PM me maybe I'll be able to read all that you wrote. Thank you again
  • Mikaw
  • Mikaw's Avatar
06 Oct 2021 09:32
#856267
Does this help?
The following user(s) said Thank You: aquaholic, F64
  • aquaholic
  • 1981 KZ1000 J1
07 Oct 2021 08:51
#856306
Yes but please don't stop there lol. I recieved a different igniter today and will try that. I appreciate your help and any information you can send that user friendly lol. I have a manual but it is difficult to understand sometimes. Thank you again. Be well and stay safe. Jon
  • aquaholic
  • 1981 KZ1000 J1
07 Oct 2021 13:03
#856327
Absolutely helps. I put the igniter in that I just received,  no change. I did your test and everything was good. I'm lost lol
  • F64
  • F64's Avatar
  • 81-KZ440D2
07 Oct 2021 19:38
#856343
How did you do your test for spark?
81-KZ440-D2.
LIC, NY
  • aquaholic
  • 1981 KZ1000 J1
08 Oct 2021 08:32
#856366
Induction timing light
  • F64
  • F64's Avatar
  • 81-KZ440D2
08 Oct 2021 13:55 - 08 Oct 2021 17:32
#856381
meter DC V
ignition on/engine off
what is your voltage?
red probe to yellow/red wire at the 6pin connector in pink square(backprobe all the wires from the ignitor side. Do Not Disconnect the connector when measuring)
red probe to black wire at the 6pin connector in pink square
what is the voltage?
red probe at green wire at the 6pin connector in pink square
red probe at black/yellow wire at the 6pin connector in pink square
And check the red wires at the coils again.
I need to know the voltage numbers.
Do not disconnect the wires from the coils.
Just out of curiosity---use the timing light again but put the inductive pickup close to the coils
shut off ignition.
photo courtesy of Scirocco
81-KZ440-D2.
LIC, NY
Last edit: 08 Oct 2021 17:32 by F64.
  • aquaholic
  • 1981 KZ1000 J1
09 Oct 2021 11:31
#856424
Battery voltage 11.56
Yellow/red 6.25
black wire 5.90
green wire 5.90
coil for 1/4 5.82
Coil for 1/3 5.82
Your help is much appreciated. Where do I go next lol
  • F64
  • F64's Avatar
  • 81-KZ440D2
09 Oct 2021 12:11 - 09 Oct 2021 12:48
#856426
Woah, You have a huge voltage drop somewhere.
Also check the voltage on the (black with yellow stripe) wire.
That wire should be 0 volts anything above 0.5v is telling you that is a bad ground.
key on/ignition on/ engine not running
meter on DC V
red probe on red wire at the ignition kill switch(green box).
note voltage on red wire on both sides of the switch(it looks like one side of the switch is red and the other side is yellow with a red stripe).
Tell me what the voltage is.
Photo courtesy of Scirocco
81-KZ440-D2.
LIC, NY
Last edit: 09 Oct 2021 12:48 by F64.
  • aquaholic
  • 1981 KZ1000 J1
09 Oct 2021 12:22
#856427
Once again your reply was cut off on the right. not sure why that happens. what should the voltages be on those wires
  • F64
  • F64's Avatar
  • 81-KZ440D2
09 Oct 2021 12:24 - 09 Oct 2021 12:49
#856428
Can you see the full text now?
81-KZ440-D2.
LIC, NY
Last edit: 09 Oct 2021 12:49 by F64.
