1982 KZ1000J IGNITER ????
- aquaholic
- 1981 KZ1000 J1
02 Oct 2021 12:11
Started engine to synchronize the carbs. Shut it down and won't start again. No spark from the coils on any cylinder. New coils, igniter is original. Any help would be appreciated. Stay safe my friends
Re: 1982 KZ1000J IGNITER ????
02 Oct 2021 12:36
Check the fuses first, next check primary/secondary ignition coils.
The service manual offers a multimeter test for the coils and ic igniter.
The following user(s) said Thank You: aquaholic
- aquaholic
- 1981 KZ1000 J1
02 Oct 2021 13:13
Is the igniter the same as a rectifier ? Coils are new and no spark on any of them
02 Oct 2021 15:12Both are total different divices in function.Is the igniter the same as a rectifier ? Coils are new and no spark on any of them
- aquaholic
- 1981 KZ1000 J1
02 Oct 2021 16:29
My wire colors don't match the manual mentioned in the igniter test lol. Attached are pictures of the wires.
02 Oct 2021 17:38
RED CONNECTOR = Recifier/Regulator Unit
BROWN CONNECTOR = Reserve Lighting Device
WHITE CONNECTOR 6 PIN= IC Igniter to ignition coils (YELLOW/RED, BLACK, GREEN, BLACK/YELLOW)
UNKNOWN COLOR 4 PIN CONNECTOR = IC Igniter to pic up coils (RED, YELLOW, BLUE, BLACK)
Read the manual about the connectors, wire colours....
- aquaholic
- 1981 KZ1000 J1
03 Oct 2021 06:58
I forgot to mention that I hooked up the vacuum gauges and ran it to synchronize the carbs. I shut it down because of gauge flutter. That is when the issue started. I had spark on 1 and 4 but nothing on 2 and 3. I installed a new coil and then had no spark. I ordered a new rectifier. I don't think that any of my wires are the same as the manual call out. I'll going to go out today and look again. I do appreciate you following and helping me. thank you so much. Jon
03 Oct 2021 07:06I forgot to mention that I hooked up the vacuum gauges and ran it to synchronize the carbs. I shut it down because of gauge flutter. That is when the issue started. I had spark on 1 and 4 but nothing on 2 and 3. I installed a new coil and then had no spark. I ordered a new rectifier. I don't think that any of my wires are the same as the manual call out. I'll going to go out today and look again. I do appreciate you following and helping me. thank you so much. Jon
The charging system (rectifier) has nothing to do with spark (other than the fact that the battery needs to be sufficiently charged to make the bike run.)
- hugo
- '92 Zephyr 750
03 Oct 2021 08:26 - 03 Oct 2021 08:27
When doing an alternator test. And this is following a factory manual. The alternator is disconnected making leads available to voltmeter, and the engines is run strictly on battery power. The battery does not need Rectifier/Regulator, as is already 12.6 VDC (unlike the alternator)
.....this is to say, as Nessism said. You can run the engine....and have spark....with no alternator and no rectifier nor regulator AT ALL, as long as your battery is healthy.
Last edit: 03 Oct 2021 08:27 by hugo.
- aquaholic
- 1981 KZ1000 J1
- aquaholic
- 1981 KZ1000 J1
03 Oct 2021 09:08
Alternator is working. Getting 14 volts at the battery .
- aquaholic
- 1981 KZ1000 J1
03 Oct 2021 09:10
What is the igniter and could this cause the no spark issue if bad. Thank you for your help. I need all I can get lol
