Wired George coil mod w/ Dyna S - Only 10.5 volts
- BlackZ1R
- Kawasaki in my blood
Re: Wired George coil mod w/ Dyna S - Only 10.5 volts
22 Jun 2021 21:09Ok, found what I'm going to say was part of my main issue, the ring terminal on the red wire from Dyna box going to 1-4 coil was slipping on the wire, making an intermittent connection. Fixed that, then checked all the terminals on both coils and all connections again. It ran much more consistent after that. The next thing I found was a suspect weak AGM battery. Swapped a good one into it and she's running better than she has in a while. Thanks for the post.BlackZ1R
Fire up the bike.
Meter on DC V
Black probe on negative battery post(metal part of battery.
Red probe on the 1,4 coil positive post(metal terminal on coil not the connector) .
Note voltages firing vs not firing
Move the red probe to the negative post of the coil.
Note voltage when firing vs not firing
Kawasaki
Someone once told me to marry that motorcycle I was riding ......there's times I wish I hadda listened .
- BlackZ1R
22 Jun 2021 21:22Have you had a chance to get back to figuring out the problem with dropping 2 cylinders on your bike? I've got the Wired George relay set up on mine and the last I checked coil voltage was nearly identical to what you're getting. That was with a not so old, suspect AGM battery in it.I have #30 going to the starter relay bolt, not direct to battery. When measured I got same voltage at starter bolt vs battery positive.
Turned key on, with switch in RUN position, 12.07 volts.
Measured #87 to ground and got 11.95 volts.
NOW, I measured power at coils with the negative probe on battery, not negative coil wire. Measured 11.92 volts.
So, I think I am good, seems like I was measuring voltage wrong the whole time and should have been grounding to battery post not coil wire if that makes sense.
Thanks guys!
I actually found a goofy crimped terminal/wire connection from the Dyna box red wire to the 1-4 coil on my bike. After I fixed that and swapped to a better battery, my bike has been starting, and running great. So far nearly 500 miles since I did that, 200 miler on Sunday. Bike ran great.
I checked and rechecked until I found that bad ring connector. Should be something similar on yours causing the problems. Check all your grounds again. Do you remember what your battery voltage is at 2-3k?
Kawasaki
- BlackZ1R
23 Jun 2021 11:20
Kawasaki
- Bama704
28 Jun 2021 07:27
I took another look at all my connections and I'm good there. The bike is running great now and I haven't had any issues since changing to the green dyna coils.
1977 KZ900
Carbs are late model 1975 28mm
- BlackZ1R
28 Jun 2021 10:08Glad yours is running good, mine will still fire up on 2 cyl., ever so often. I have not found the issue yet. From everything I have done so far it has gotten much better at not dropping 1-4 coil. I have Dyna III and new green coils. I have another Dyna III box here that I have hidden from myself within the last few weeks that I was going to give a go to see if that was it. I have another pickup plate to try also. That's all I can do next.I took another look at all my connections and I'm good there. The bike is running great now and I haven't had any issues since changing to the green dyna coils.
How does the 12" meg sound on your bike? Is that a Delevic header?
Kawasaki
- Bama704
29 Jun 2021 05:52
Hope you get yours sorted out quick, that is extremely annoying!
Header is a Vance and Hines (i'm pretty sure) and I love the 12" cone, sounds great.
1977 KZ900
- BlackZ1R
30 Jun 2021 10:14Thanks man, you aren't kidding. That is putting it mildly, dribing me insane!Hope you get yours sorted out quick, that is extremely annoying!
On another note, not saying it's not, but I've never seen a wrap around V&H header for these bikes, Looking back at your pic, it does look chrome instead of SS, like the Delkevic I first thought it was. So that means it could be one of two pipes if it's not a v n h, Kerker, or MAC. Did you make the mid pipe on that header to cone section, or is it part of the original pipe? I know that thing BARKS!!
Kawasaki
- Gdailey2112
- 82 KZ1100D1
11 Aug 2022 15:34No points, have Dyna-S. Changed from points to Dyna about 200 miles ago.
2&3 will come back to life if I'm WOT intermittently. Usually I baby it back home
dealing with this same situation right now, i'd learned right here at kzr that dyna 3 ohm coils were poorly designed, they will arc to connecting posts.
gonna distance coils further away from bracket n see if that helps.
1982 KZ1100D1
- Warren3200gt
12 Aug 2022 04:42 - 12 Aug 2022 05:45
Just sleeve the posts with heatshrink. Problem solved.
Last edit: 12 Aug 2022 05:45 by Warren3200gt.
- Gdailey2112
- 82 KZ1100D1
15 Aug 2022 21:28Just sleeve the posts with heatshrink. Problem solved.
word!
1982 KZ1100D1
- TheTrout
16 Aug 2022 09:30Just sleeve the posts with heatshrink. Problem solved.
No shit?! I have ben having the same issue with my bike. Dyna s ignition and green Dyna coils. I'll have to give this a try.
1978 KZ1000B2
- Gdailey2112
- 82 KZ1100D1
17 Aug 2022 08:15Good. The relay mode has been removed from the mix. Still need to diagnose the drivability issue. Does spark os 2&3 come back if the bike cools off?
yep that is exactly what mine is doing
1982 KZ1100D1
