Engine turns over, no spark still
  • F64
  • F64's Avatar
  • 81-KZ440D2
Re: Engine turns over, no spark still
27 Jun 2020 15:48
#829141
Rick H. wrote: Somewhere on this I am getting lost. Perhaps it is in the verbiage. I have never heard this diagnosis explained in this fashion.
Rick H.
Where are you getting lost Rick?
81-KZ440-D2.
LIC, NY
  • BikeNoob
  • BikeNoob's Avatar Topic Author
27 Jun 2020 15:51
#829142
When I check the points plate I am getting 16.8mV
78' KZ650-B2 (Under Construction)
  • F64
  • F64's Avatar
  • 81-KZ440D2
27 Jun 2020 16:00 - 27 Jun 2020 16:13
#829144
ok
so your ground on your points plate is good.
Ignition on
Move your positive meter probe to these wires.
When you got the 16.8 mv, was the ignition on?
81-KZ440-D2.
LIC, NY
Last edit: 27 Jun 2020 16:13 by F64.
  • BikeNoob
27 Jun 2020 16:18
#829146
F64 wrote: ok
Ignition on
Yes, the ignition was on. For the other two wires I got 12.56v on both
  • F64
  • F64's Avatar
  • 81-KZ440D2
27 Jun 2020 16:21
#829147
before the next measurement.
get a small file and sand your point contacts
81-KZ440-D2.
LIC, NY
  • F64
  • F64's Avatar
  • 81-KZ440D2
27 Jun 2020 16:25
#829148
Rick,
This is where I learned a bit more of troubleshooting.
Dan Sullivan's
Fundamental Electrical Troubleshooting.
81-KZ440-D2.
LIC, NY
  • BikeNoob
27 Jun 2020 16:26
#829149
F64 wrote: before the next measurement.
Ok, my points are brand new, should I still sand em down a bit?
  • F64
  • F64's Avatar
  • 81-KZ440D2
27 Jun 2020 16:35
#829151
yes, lightly and clean with alcohol.
81-KZ440-D2.
LIC, NY
  • BikeNoob
27 Jun 2020 16:37
#829152
Ok ill work on that, what is the next thing I should measure after I sand the points?
  • Mikaw
  • Mikaw's Avatar
27 Jun 2020 16:50
#829155
Be seriously gentle “filing” points... I’d check them first for pitting... if they are smooth and not pitted you not gaining anything... actually you be changing the gap and starting another issue
  • F64
  • F64's Avatar
  • 81-KZ440D2
27 Jun 2020 16:51 - 27 Jun 2020 16:53
#829156
Ignition on
points closed
20v DC scale on meter
negative meter probe on negative battery terminal
positive probe on each of these points
81-KZ440-D2.
LIC, NY
Last edit: 27 Jun 2020 16:53 by F64.
  • F64
  • F64's Avatar
  • 81-KZ440D2
27 Jun 2020 16:58
#829157
Mikaw wrote: Be seriously gentle “filing” points... I’d check them first for pitting... if they are smooth and not pitted you not gaining anything... actually you be changing the gap and starting another issue
Mikaw
The points are new.
I'm eliminating the possibility of a coating or residue on the points.
There is a break in the circuit between the points plate and the wires going out to the coil.
81-KZ440-D2.
LIC, NY
The following user(s) said Thank You: BikeNoob
