Engine turns over, no spark still
  • BikeNoob
  • BikeNoob's Avatar Topic Author
25 Jun 2020 09:15
#828958
Hey guys, I posted a thread two weeks ago that was really helpful and since then I've done some more work on my 78 kz650b but it has failed to started the bike up yet. When I press the push start the bike turns over but just seems to spin and not fully start with no spark to the plugs. My ignition coils are getting full battery power to them and I have just replaced the points/condenser as well. The plug caps and wires are also new as well as the battery. I have been studying the wiring chart but have not been able to pinpoint where my issue may be yet. All the other electrical works on the bike great aside from the ignition system so I am assuming the issue would be in that range as opposed to a start motor issue? What are my best chances of getting this thing started up? I set the gap and timing at the points and after having tested most of the connections to in the ignition system wiring I'm kinda stumped. Only thing I noticed that was weird was that the wiring leaving the contact breaker points have three connections as opposed to the two in the wiring diagram but that might just be the previous owner jerryrigging something? Any further help would be greatly appreciated.
78' KZ650-B2 (Under Construction)
  • Mikaw
  • Mikaw's Avatar
Re: Engine turns over, no spark still
25 Jun 2020 12:24 - 25 Jun 2020 12:31
#828973
Some bikes have the oil sending unit inside the points housing. That should be the third wire. If you don’t have that then maybe a wire harness was swapped into service that had the third wire...
Three things needed to make a engine run... all need to be confirmed. 1.) spark, 2.) fuel, 3.) compression. Verify all three and the bike will start.
Test the coils. Need an ohm meter and check results against the acceptable range in the FSM. I’ll look to see if I can find one...
Last edit: 25 Jun 2020 12:31 by Mikaw.
The following user(s) said Thank You: BikeNoob
  • Mikaw
  • Mikaw's Avatar
25 Jun 2020 12:32 - 25 Jun 2020 12:34
#828975
Last edit: 25 Jun 2020 12:34 by Mikaw.
  • Mikaw
  • Mikaw's Avatar
25 Jun 2020 12:35 - 25 Jun 2020 12:36
#828976
Last edit: 25 Jun 2020 12:36 by Mikaw.
  • lakshan
  • lakshan's Avatar
25 Jun 2020 13:28
#828983
Did you try actually testing the plugs for spark? If you pull the plug, attach it to the wire and ground the plug against the engine, you should be able to test if you have spark.
Also as Mikaw suggested, I would do a compression test to rule that out.
'77 KZ650B1 in progress...
  • F64
  • F64's Avatar
  • 81-KZ440D2
25 Jun 2020 23:08 - 26 Jun 2020 09:27
#829017
Hey Bikenoob,
Could you check some voltages at your coil again.
Rotate your engine with a wrench till one of your points is fully open.
The bike ignition switch on.
Put your meter to the 20v DC setting.
Negative meter probe on the negative battery terminal.
Use the positive meter probe to check each of the coil terminals on both coils.
You will have 4 readings.
Then rotate the engine with the wrench till the second set of points is fully open.
Positive meter probe on each of the coil terminals.
Tell us what those 8 readings are.
Don't forget to turn off the ignition switch when you're done with the readings. The coils will overheat if left on for too long.
81-KZ440-D2.
LIC, NY
Last edit: 26 Jun 2020 09:27 by F64. Reason: because i'm a confusing writer before coffee
  • F64
  • F64's Avatar
  • 81-KZ440D2
26 Jun 2020 17:19 - 26 Jun 2020 17:25
#829055
When you hold down the start button, do the points open and close as the engine rotates?
81-KZ440-D2.
LIC, NY
Last edit: 26 Jun 2020 17:25 by F64.
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Premium Member
26 Jun 2020 17:44 - 26 Jun 2020 17:44
#829057
The third wire should be connected to the oil pressure switch.
Last edit: 26 Jun 2020 17:44 by Scirocco.
  • BikeNoob
27 Jun 2020 13:24
#829115
Just checked the voltage at my coils again. So with the left, 1-4 points open my readings were as follows: Left coil - (Left Terminal) 10.79 (Right Terminal) 10.79, Right coil - (Left Terminal) 10.79 (Right Terminal) I got .428 but I also got 10.81 a few times so may have just been touching the rubber seal around the terminal. As for the 2-3 points opening measurements I got 12.59v across the board. So I take it this means my 1-4 ignition coil is getting enough juice to start up the bike? What can I check to fix this? The coil is brand new so I don't suspect that is the reason?
  • BikeNoob
27 Jun 2020 13:26
#829116
F64 wrote: When you hold down the start button, do the points open and close as the engine rotates?
And yes when the engine turns over the points open and close, I have set the gap as well. They spark a little bit when spinning if that means anything.
  • Mikaw
  • Mikaw's Avatar
27 Jun 2020 13:47
#829119
Pull all 4 plugs. Put them back into the plug wire caps. Lay them on the engine... make sure off/run is in the run position. Ignition to first station.... clutch lever in and crank the engine... watch for spark plugs to fire... easier in evening or in a closed garage with lights out... your looking for a blue to white colored spark... easiest way to confirm it coils are firing...
  • BikeNoob
27 Jun 2020 13:57
#829121
Mikaw wrote: Pull all 4 plugs. Put them back into the plug wire caps. Lay them on the engine... make sure off/run is in the run position. Ignition to first station.... clutch lever in and crank the engine... watch for spark plugs to fire... easier in evening or in a closed garage with lights out... your looking for a blue to white colored spark... easiest way to confirm it coils are firing...
Coils definitely weren't firing already I think, I tested the 1-4 coils with the screwdriver method and I didn't get any spark there. But I guess the question is that if the coils aren't firing and they are brand new, what could I trace the issue back to?
