1977 KZ1000LTD gauge dismantling?
  • Kawidave
  • Kawidave's Avatar Topic Author
24 Aug 2019 08:07 - 24 Aug 2019 08:07
#809743
The inside glass on my speedo and tach need cleaning. Can the chrome ring that surrounds the glass and is crimped over be bought to replace the one I would have to pry open? The smearing is not on the outside.
Last edit: 24 Aug 2019 08:07 by Kawidave.
  • TexasKZ
  • TexasKZ's Avatar
Re: 1977 KZ1000LTD gauge dismantling?
24 Aug 2019 08:13 - 24 Aug 2019 08:16
#809745
So far as I know, they are nla. You will need to be very, very careful with them.
There is an article under the Articles tab describing and showing the process.
Edit: I was going to insert the link, but for some reason the paste feature refuses to work.
Last edit: 24 Aug 2019 08:16 by TexasKZ.
The following user(s) said Thank You: Kawidave
  • Kawidave
24 Aug 2019 08:45
#809747
I figured they were NLA
  • davido
  • davido's Avatar
24 Aug 2019 09:14
#809749
This article from Practical Sportsbike magazine should help;
www.kzrider.com/forum/4-electrical/61024...eedometer-reset-knob
CB550 (1978)
CB500/4 (1972)*
KZ1000CSR (1981)
XT 600E (1999)
TDM900 (2003)
  • SWest
  • SWest's Avatar
  • 10 22 2014
24 Aug 2019 09:16
#809750
After trying the repops (JUNK) didn't last so I decided to use old stock ones. I have a thread on them
kzrider.com/forum/5-chassis/599906-new-tach-speedo
  • martin_csr
  • martin_csr's Avatar
24 Aug 2019 10:59 - 25 Aug 2019 06:14
#809754
I don't know anything about these. see links. I would fab up a crimp ring holder or something, so that they can be crimped with minimal damage.
Honda CB750 Faces ---Kawasaki parts
www.cb750faces.com/cb750faces.nl/en/48-kawasaki-parts
Honda CB750 Faces ---Kawasaki crimp rings
www.cb750faces.com/cb750faces.nl/en/kawa...-ring-set-2-pcs.html
Last edit: 25 Aug 2019 06:14 by martin_csr.
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Premium Member
24 Aug 2019 12:01
#809756
The following user(s) said Thank You: slmjim+Z1BEBE, Street Fighter LTD
  • Kawidave
25 Aug 2019 04:36
#809792
What makes you call the replacement gauges junk? Except for the missing ND marking they sure look good?
  • SWest
  • SWest's Avatar
  • 10 22 2014
25 Aug 2019 05:10
#809794
Two sets. Didn't last.
  • Kawidave
25 Aug 2019 05:12
#809795
SW, bought from? PM if u prefer.
  • SWest
  • SWest's Avatar
  • 10 22 2014
25 Aug 2019 06:26
#809800
Bought them from z1parts.net . One set lasted a couple months. The speedo failed so they sent me a new one then the tach did the same thing and they sent me a new one. The odometer stopped working so I sent them back for a refund. It's all in my thread. If I hadn't bought them from z1parts I would be stuck with them and out $400. They have a lifetime money back warranty. No one else has that. They first said it must have been a bad batch but then they stopped selling them for a time. I don't know how they are now but I decided I'd make my own out of used ones and when I could afford it I'd send them out to be redone professionally. OEM is best and I doubt the repops would last 40+ years.:whistle:
  • Kawidave
25 Aug 2019 06:46
#809801
Steve, can I ask how long ago this was?
