Wiring my kz650h1
  • Rockybalboba
  • Rockybalboba's Avatar Topic Author
Wiring my kz650h1
25 Feb 2019 13:18
#799190
Do this look alright for how I have my ignition system hooked up? I am unsure where to connect the brown from the regulator, or what its function was, I know it went to the ignition switch, but that is long junk and gone...
  • Blue58
  • Blue58's Avatar
  • Old, Bald and Fast
Re: Wiring my kz650h1
25 Feb 2019 14:14
#799197
Brown is normally ground. Google wiring diagram kz650..
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
25 Feb 2019 14:40
#799199
I can be wrong (KZ650) but Brown is positiv 12 Volt if the ingnition key switch is in ON position.
Ground is black/yellow.
  • hugo
  • hugo's Avatar
  • '92 Zephyr 750
25 Feb 2019 14:49
#799201
Scirocco got it right.
  • Blue58
  • Blue58's Avatar
25 Feb 2019 14:58
#799203
I stand corrected. Sorry for the missinformationi.
  • martin_csr
  • martin_csr's Avatar
25 Feb 2019 15:29 - 26 Feb 2019 05:43
#799206
The brown wire to the voltage regulator acts as a voltage sensor wire for the voltage regulator.
Simplified wiring diagrams. KZR topic by loudhvx. bare bones for mattylight.
see pages 11-21 >> pg 14 has one for the 650-CSR.
note: some of the diagrams are no longer there >> pg 1-10. But from pg 11-on many are still available.
Last edit: 26 Feb 2019 05:43 by martin_csr.
  • loudhvx
  • loudhvx's Avatar
26 Feb 2019 10:52 - 26 Feb 2019 10:57
#799257
As Scirocco said, brown is almost always switched positive 12 volts on Kz wiring. That means it goes to many things, and is configured differently on different Kz's.
As Martin said, that brown wire, specifically in the original post, is the voltage sense line on the regulator. If the regulator has that wire, it must be connected to a hot wire whenever the bike is running. Without it , the electrical system can get fried by over-voltage.
Last edit: 26 Feb 2019 10:57 by loudhvx.
  • loudhvx
  • loudhvx's Avatar
26 Feb 2019 11:00 - 26 Feb 2019 13:03
#799258
Rockybalboba wrote: Do this look alright for how I have my ignition system hooked up? I am unsure where to connect the brown from the regulator, or what its function was, I know it went to the ignition switch, but that is long junk and gone...
The above diagram incomplete. Don't use it as is.
Find a better diagram. There might be similar ones in the link Martin posted.
(To Martin, I finished putting search tags at the bottom of each entry so a site search with "mattylight" and kz model designation should return results in that thread.)
Page 14 of the Mattylight thread has an 81 Kz650H1 bare bones diagram.
kzrider.com/forum/4-electrical/172746-19...ght?start=260#514373
Last edit: 26 Feb 2019 13:03 by loudhvx.
  • Rockybalboba
26 Feb 2019 15:33
#799281
Thank you guys for the help! I ended up going with the mattylight diagram, now to actually fully complete it.
