1980 750H bare bones for mattylight
  • Donch
  • Donch's Avatar
Re: 1980 750H bare bones for mattylight
27 Feb 2011 13:09
#433778
relay or solenoid ?
kz750-G(twin)
  • loudhvx
  • loudhvx's Avatar Topic Author
27 Feb 2011 20:55 - 09 Jan 2019 19:49
#433894
Thanks for the photos. That does make it easier.
That regulator, looks to me like a combo regulator/rectifier, which is what should be on the G1. The starter relay looks a little strange to me, but I don't know the 750 twin very well. The starter relay should have the battery cable going to it. It should also have the heavy cable going to the starter.
I would post a seperate thread asking about the starter relay ID. Someone with more 750 twin knowledge will chime in.
Here's what I have so far. The relay is a standard auto relay you should be able to get at most parts stores.
EDIT 1/9/2019:
Mattylight Barebones Bare Bones Wiring Diagram
1980 Kawasaki Kz750G1 twin with relay for power for Donch
Kz750G Kz750 G1 Kz 750 G 750G1 750G
Last edit: 09 Jan 2019 19:49 by loudhvx.
  • loudhvx
09 Jun 2011 03:28 - 10 Jan 2019 10:00
#456279
This is for Skidooman. 1982 KZ750 M1 twin.
EDIT 1/10/2019:
1982 Kawasaki Kz750M1 twin for Skidooman
Kz750M Kz750 M1 Kz 750 M 750M1 750M
Last edit: 10 Jan 2019 10:00 by loudhvx.
  • sk8vet
  • sk8vet's Avatar
14 Jun 2011 01:31 - 14 Jun 2011 01:40
#457148
Hi loudhvx,
You've really helped a lot of people in this thread. I was wondering if you have a little extra time for me? I've got a 78 KZ650 C2 and found the following wiring diagram:
diagrams.kz650.info/wiring/images/KZ650-B2,C2.jpg
That's helpful, but I'm planning on cutting out a lot and having only the following:
-No ignition, no indicators, no horn, no speedo, no tach, no hazards
-Yes to headlight (with hi/lo), taillight, and turn signals
-A hidden on/off switch
-A hidden starter switch
Would you mind creating a bare bones diagram for this? I would really appreciate it!
Last edit: 14 Jun 2011 01:40 by sk8vet.
  • loudhvx
14 Jun 2011 15:13
#457262
Yeah, no problem. Do you know what starter and ignition switch you will use? Will you keep the kill switch? Sticking with points?
The following user(s) said Thank You: sk8vet
  • sk8vet
  • sk8vet's Avatar
15 Jun 2011 14:38
#457422
Hey, sorry for the false alarm but I'm going to stick with the stock wiring until I get it running right. Afterwards I'll do something more custom and probably come back here ;-). Thanks for the reply tho!
  • loudhvx
18 Jun 2011 11:21 - 10 Jan 2019 10:30
#457994
1979 kz650 for grabber.
Drag to the desktep to see in full resolution.
This is for the U.S. models. I don' know if the U.K. models will have variation.
Ignore the stuff to the right of the arrows. That's just for lighting in case you need it in the future. But it would require an ignition switch so the lights won't be on all the time.
EDIT 1/10/2019:
1979 Kawasaki Kz650 for grabber
Kz 650
Last edit: 10 Jan 2019 10:30 by loudhvx.
  • grabber
  • grabber's Avatar
18 Jun 2011 11:30
#457997
That's great thanks
  • loudhvx
19 Jun 2011 11:10 - 10 Jan 2019 10:31
#458163
added starter
EDIT 1/10/2019:
Kz 650
Last edit: 10 Jan 2019 10:31 by loudhvx.
  • sk8vet
  • sk8vet's Avatar
26 Jun 2011 00:54 - 26 Jun 2011 00:56
#459384
Hi loudhvx,
I'm back and hoping you can help me out now that I have my plan straight. Again, I have a 78 KZ650 C2 with the following wiring diagram:
BUT, my bike didn't come with right hand controls so I found one from a C3:
diagrams.kz650.info/wiring/images/KZ650-B3,C3.jpg
You'll notice the C3 right controls has a mystery yellow wire going to the ignition, and no headlight on/off switch which has me a bit confused.
Will you please help me with a wiring diagram based on the C2, with the C3 right controls, and with the following "deletes":
-No hazards
-No horn
-No speedo or tach
-No front indicators (turn signal indicators, neutral, high beam, oil, brake light fail)
-No starter lockout switch
Since I have no headlight on/off switch I'd like them to be on when I turn on the ignition key (ignition is off/on/park). Also, I will be using points for the time being.
What do you think? Doable? :unsure:
Last edit: 26 Jun 2011 00:56 by sk8vet.
  • loudhvx
26 Jun 2011 11:13 - 10 Jan 2019 10:33
#459434
I tripled up on the ignition switch contacts to make the ignition switch more reliable. As it's drawn, the input and output of the ignition switch will have 3 wires tied together. Input will be red and two whites. Output is brown, blue, and orange/green. THe blue may actually be blue with a red stripe, or red with a blue stripe.
EDIT 1/10/2019:
1978 Kawasaki Kz650C2 for Sk8vet
Kz650C Kz650 C2 Kz 650 C 650C2 650C
Last edit: 10 Jan 2019 10:33 by loudhvx. Reason: Corrected title on image
26 Jun 2011 11:31
#459440
If needed, here's how to save a forum image to your computer:
Click > www.kzrider.com/forum/8-about-the-site/4...age-to-your-computer
Good Fortune!:)
The following user(s) said Thank You: loudhvx, nkymain485
