Starter Slipping ?
  • SWest
  • SWest's Avatar
  • 10 22 2014
  • kzdcw
  • kzdcw's Avatar Topic Author
  • 77' KZ1000A
Re: Starter Slipping ?
11 May 2016 18:14 - 11 May 2016 18:15
#725843
Steve, Worked on my Starter Clutch assembly today. Prepped everything and installed starter clutch w/allen head bolts to generator/rotor. Used Red Loctite and torqued to 27 fl.-lbs. as per FSM.
Question, on the installation of the clutch starter assembly, the FSM makes reference to the Thrust Washer to be mounted with it's chamfered side facing inward. If you look at the washer, it appears that one side is more rounded and is tapered towards the center of the opening or hole that slides over the crankshaft.
Is this rounded side of the washer, the chamfered side ?
It would make sense, since the flat side of the washer has more of a wider flatter mating surface that would mate up to the needle bearing.
Also, Does the end of the crankshaft need to be really polished well before mounting the rotor ?
77' KZ1000A
Last edit: 11 May 2016 18:15 by kzdcw.
  • SWest
  • SWest's Avatar
  • 10 22 2014
  • kzdcw
  • 77' KZ1000A
11 May 2016 18:58
#725855
Steve, Wish I could post pictures but computer having problems. Anyway there is an eBay listing of a starter clutch kit which has a picture showing the thirst washer ( has the 4 grooves facing upwards ) which I be is the chamfered side up?
Ebay listing # 322098770511
77' KZ1000A
  • SWest
  • SWest's Avatar
  • 10 22 2014
11 May 2016 19:04
#725856
The grooves face the engine.
  • kzdcw
  • 77' KZ1000A
11 May 2016 20:14
#725870
Steve, The grooves on Both Sides . The Taper is on the rounded or chamfered side ?
77' KZ1000A
  • SWest
  • SWest's Avatar
  • 10 22 2014
11 May 2016 20:40
#725873
Looks like it faces the engine.
  • kzdcw
  • 77' KZ1000A
13 May 2016 18:10
#726267
Steve, Completed the starter/clutch and rotor assembly over the last couple of days. Tested Today and bike started without making any of the clutch slipping/disengage sounds as it was making before. Bike much quieter ! So now it appears to be acting as it should though I still think that maybe the Starter itself might be slipping or skipping a little when hitting the starter button if that's possible?
Is there to Test the starter itself or can it be rebuilt if internally there might be a electrical problem ? I'm assuming you would have to open up the starter and inspect?
77' KZ1000A
  • SWest
  • SWest's Avatar
  • 10 22 2014
13 May 2016 18:16
#726270
Good job. B) Have you read the other starter thread? That was MURDER. :dry:
It shouldn't skip. You can take the starter out on these engines. You will have to take off the sprocket cover so you can get the wire off.
  • kzdcw
  • 77' KZ1000A
13 May 2016 18:28
#726277
Steve, Not hard to remove starter, did before. Tested it prior to make sure it would spin with current supplied and it did. I'll read the FSM and see how difficult it is to open it up and check out which I think are the brushes ?
Also, Steve I just posted another question on the Carburetor Forum about oil in the fuel ? It feels like the fuel from the carbs. might have a little oil in it ? Maybe you could take a look at my question and I'll read the other starter thread to see if I could offer any help too.
Thanks Again !!!
77' KZ1000A
  • SWest
  • SWest's Avatar
  • 10 22 2014
13 May 2016 18:31
#726278
Fuel in the oil, never heard of oil in the fuel.
  • SWest
  • SWest's Avatar
  • 10 22 2014
