Starter Slipping ?
  • SWest
  • SWest's Avatar
  • 10 22 2014
Re: Starter Slipping ?
30 Apr 2016 10:46
#723776
They can be hard to come by.
  • kzdcw
  • kzdcw's Avatar Topic Author
  • 77' KZ1000A
30 Apr 2016 11:56 - 30 Apr 2016 11:59
#723779
Steve, I tried to copy a link on eBay but couldn't. Bay Listing # 152008460425 . It's a Billet Reproduction Generator made in Ca. that's priced a lot lest than OEM.
Just type in the Part # 21007-1004. Any input on these ?
77' KZ1000A
Last edit: 30 Apr 2016 11:59 by kzdcw.
  • SWest
  • SWest's Avatar
  • 10 22 2014
30 Apr 2016 12:49
#723787
Go to the page, right click the browser, select copy, go back to your edit and right click again then select paste.
  • SWest
  • SWest's Avatar
  • 10 22 2014
30 Apr 2016 19:20
#723847
I checked it out but I didn't see any magnets in them. Better call to be sure it's not a scam. I was wrong about the pin. It is 6mm. I measured a #6 bolt and it reads 5.87.
  • kzdcw
  • 77' KZ1000A
10 May 2016 18:49 - 10 May 2016 18:50
#725615
Steve, Received my Starter Clutch, Rotor, and Starter Gear assembly yesterday. Kit pretty complete, minus damper but nice especially the generator/rotor. No cracks and real solid. So was happy about that.
Question, I have the 3 Allen Head Bolts that came with this kit are that are in nice shape and not like the original ones that I had that backed off the clutch and wore down the heads of the bolts. Should I re-use these better bolts? I was able to find new ones at Ace Hardware that were the right size and length. On the head of these purchased bolts, they read 12.9 just like the kawasaki original ones that read the same.
Some members are saying to use Grade 8 but don't know if the ones I have are that? Or does it matter? I'm not sure whether to use Red-Loctite or Blue-Loctite in fearing the potential of them loosening again might be there?
And this starter clutch kit did come with the locating 6mm dowel pin so that was a good thing even though I did make a make shift one.
77' KZ1000A
Last edit: 10 May 2016 18:50 by kzdcw.
  • SWest
  • SWest's Avatar
  • 10 22 2014
10 May 2016 18:57
#725616
That's great. Pics of the kit?
  • kzdcw
  • 77' KZ1000A
10 May 2016 18:59
#725618
I'll try to Post the pix. Was having trouble earlier.
But my question was concerning the Bolts to use ?
77' KZ1000A
  • SWest
  • SWest's Avatar
  • 10 22 2014
10 May 2016 19:09
#725622
That's why I asked. I'd like to see the new bolts. # 8 bolts are right. U used the blue lock tight and they were loose when I took it back off.
  • SWest
  • SWest's Avatar
  • 10 22 2014
10 May 2016 19:10
#725624
BTW, I used my hand impact driver too.
  • kzdcw
  • 77' KZ1000A
10 May 2016 19:41 - 10 May 2016 19:49
#725632
Steve, These New Allen Head Bolts are "exactly" like the stock KZ bolts. Are you saying to use Red Loctite ? Have to find the Torque Values of them ?
Looked up these bolts and the 12.9 on the head of them means grade 12.9 which again is what the Factory has. So I'm confident that they are strong enough. Which gets back to which loctite to use and torque .
77' KZ1000A
Last edit: 10 May 2016 19:49 by kzdcw.
  • SWest
  • SWest's Avatar
  • 10 22 2014
10 May 2016 19:48
#725634
Yes, use the red and the bolts. Torque if you like. I impact mine with a hand driver.
  • kzdcw
  • 77' KZ1000A
10 May 2016 19:51
#725635
24-27 Ft. Lbs. and a Non-Permanent locking agent. This is what the FSM says.
77' KZ1000A
