Starter Slipping ?
  • SWest
  • SWest's Avatar
  • 10 22 2014
Re: Starter Slipping ?
21 Apr 2016 13:22
#722233
OH, I think the swing arm pivot bolt will work as well. B)
  • kzdcw
  • kzdcw's Avatar Topic Author
  • 77' KZ1000A
22 Apr 2016 15:40 - 22 Apr 2016 15:41
#722417
Steve, I thought about using a large strap to hold dynamo rotor. Does the rotor bolt turn counterclockwise ( lefty loosey ) to loosen and remove ? It appears to be a 16mm bolt Flywheel puller needed to remove the dynamo rotor. I'm assuming you turn that bolt/puller clockwise ( to the right ) to remove the rotor?
77' KZ1000A
Last edit: 22 Apr 2016 15:41 by kzdcw.
  • SWest
  • SWest's Avatar
  • 10 22 2014
22 Apr 2016 17:03
#722421
Yes, it is 16mm. The one in the middle of your triple clamps fits it. The rotor spins counter clock wise so it tightens clock wise just like a normal bolt. Like on wheel bolts. they tighten in the same direction as the wheel or in this case rotor turns so they don't loosen, if anything they'll get tighter without a cotter pin. You might try the bolt before you buy a tool. It just might work. :whistle:
  • SWest
  • SWest's Avatar
  • 10 22 2014
22 Apr 2016 17:05
#722422
As for the dampener, reuse it.
  • kzdcw
  • 77' KZ1000A
22 Apr 2016 18:26
#722445
Once the rotor bolt is removed, is there a TRICK in removing the rotor ? I read on one of the Post to make a round bearing to place between the crank end and puller bolt to assist in removal of the rotor ? Any information on that and how that would provide more leverage ?
77' KZ1000A
  • SWest
  • SWest's Avatar
  • 10 22 2014
22 Apr 2016 18:31
#722448
Sometimes it's not needed. If the bolt won't go in far enough it will help. It also helps in turning the bolt. A 3/8" ball bearing you get at the hardware store is easy to come by.
  • kzdcw
  • 77' KZ1000A
22 Apr 2016 18:34
#722452
Steve, Beginning to see the picture more clearly as you have responded to this Post. I'll look and see if i can find that size Ball Bearing at a Hardware or Automotive Store ?
77' KZ1000A
  • SWest
  • SWest's Avatar
  • 10 22 2014
22 Apr 2016 18:40
#722453
Hardware store. It needs to be large enough as not to mung up the threads of the retaining bolt. 3/8's should do it.
  • kzdcw
  • 77' KZ1000A
22 Apr 2016 19:32
#722460
Steve, Does the Ball Bearing need to be Hardened ?
77' KZ1000A
  • SWest
  • SWest's Avatar
  • 10 22 2014
22 Apr 2016 19:34
#722462
They are hardened to some degree. They're bearings. :lol: Have you just tried the bolt first?
  • kzdcw
  • 77' KZ1000A
24 Apr 2016 17:12
#722760
Steve, Are you Sure it's a 3/8" Ball Bearing you use ? 16mm bolt equals 5/8" .
77' KZ1000A
  • SWest
  • SWest's Avatar
  • 10 22 2014
24 Apr 2016 17:55
#722770
It doesn't have to be 5/8 in fact you don't want to mung up the threads on the rotor ether. Also if too big there won't be enough threads to grab onto. Have you tried just the bolt? Generally I don't need the ball.
