1980 KZ1000 Shaft ignitor question
- ChopFinger123
12 Feb 2014 00:57 #621978
by ChopFinger123
1980 KZ1000 Shaft ignitor question was created by ChopFinger123
I have tried searching everywhere for an answer to this question and i think Im just search illiterate lol.
I have a 1980 Kz1000 shaft that has a bad ignitor and i really don't wanna order one used and have it go out in a short time again. So i was planning on making one with the GM HEI idea but i can't find anywhere that says if it will work or not. If anyone could help me out with this id appreciate it.
- ChopFinger123
12 Feb 2014 03:34 #621984
by ChopFinger123
Replied by ChopFinger123 on topic 1980 KZ1000 Shaft ignitor question
Or if anyone can tell me if this bike has a mechanical advance that would help too.
Sent from my SCH-S720C using Tapatalk 2
- Nebr_Rex
- Thank you received: 300
12 Feb 2014 04:55 #621987
by Nebr_Rex
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
Replied by Nebr_Rex on topic 1980 KZ1000 Shaft ignitor question
You need to get a manual. I have used used ignitors with no problem.
2002 ZRX1200R
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
- ChopFinger123
12 Feb 2014 06:16 #621998
by ChopFinger123
I really do need a manual. I was just hoping someone here could answer my question. I have to order a manual and Im impatient when it comes to my hobbies lol.
- Thank you received: 797
12 Feb 2014 06:51 #622004
by 531blackbanshee
Replied by 531blackbanshee on topic 1980 KZ1000 Shaft ignitor question
[So i was planning on making one with the GM HEI idea but i can't find anywhere that says if it will work or not. If anyone could help me out with this id appreciate it.]
loudhvx would be the guy to pose that question to sir.
- MFolks
- Thank you received: 540
12 Feb 2014 09:13 #622010
by MFolks
Replied by MFolks on topic 1980 KZ1000 Shaft ignitor question
- ChopFinger123
12 Feb 2014 14:46 #622038
by ChopFinger123
I think that will help. Thanks
- Thank you received: 1656
13 Feb 2014 06:54 - 20 Feb 2014 12:10 #622087
by martin_csr
Replied by martin_csr on topic 1980 KZ1000 Shaft ignitor question
There seems to be only a few KZ1000 Shaft manuals on ebbaayy for the 1000-E ST... here are 2 of them... a couple of others were very pricy.
From the UK:
Kawasaki, KZ1000 Shaft, Service, Manual, 99924-1016-02
Note apparent typo in the item title - one of his pics shows the model application chart on the back cover. I always ask a seller for clarification whenever there's a discrepancy like that.
USED '82 Kawasaki KZ1000 KZ 1000 Shaft Motorcycle Service Manual
From the UK:
Last edit: 20 Feb 2014 12:10 by martin_csr.
- oldzed
- Thank you received: 10
13 Feb 2014 10:58 - 13 Feb 2014 11:01 #622109
by oldzed
Replied by oldzed on topic 1980 KZ1000 Shaft ignitor question
1980 z1000st has a mechanical advance retard unit.
no reason you could not make an igniter yourself.
Last edit: 13 Feb 2014 11:01 by oldzed.
- loudhvx
- Thank you received: 1616
13 Feb 2014 11:36 #622114
by loudhvx
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Replied by loudhvx on topic 1980 KZ1000 Shaft ignitor question
PM sent.
1981 KZ550 D1 gpz.
Other links.
- ChopFinger123
16 Feb 2014 17:21 #622486
by ChopFinger123
So I've got this thing built but i haven't had a chance to test it yet. Im having some trouble in how to mount it to the bike.
Im thinking about mounting it on the inner fender under the seat with some round head bolts. I just don't want it to hit the metal seat pan and short out. I don't know if i can get a plastic box from radio shack to fit under the seat.
What do you guys think?
- ChopFinger123
18 Feb 2014 16:59 #622710
by ChopFinger123
Well i got it in and i just mounted the whole thing under the battery box where the original was. I need to get a water proof box to cover it with so when i take it apart to add the box ill add pics.
