1980 KZ1000 Shaft ignitor question
- ChopFinger123
Re: 1980 KZ1000 Shaft ignitor question
01 Mar 2014 19:37
Yeah that's what i was thinking. Its leaking right where it mates to the engine.
I just watched a video on YouTube on how to fix the carb holders but then right at the end the guy says he doesn't know if it will work or not lol.
Sent from my SCH-S720C using Tapatalk 2
01 Mar 2014 19:46
The good news for you is that according to Kawasaki.com all 4 carb holders are still "Active" parts so any dealer can order them for you. Ed
Attachment 00007_2014-03-01.jpg not found
- ChopFinger123
01 Mar 2014 19:48
I wonder how much kawasaki wants for them. Z1 wants almost $70 for the set.
- ChopFinger123
01 Mar 2014 20:18
On the rotor being backwards, i did the static timing and when the magnet in the rotor is lined up with the left pick up the light is on (with advance opened and timing marks lined up).
Would this still happen if it was installed backwards?
01 Mar 2014 20:28ChopFinger123 wrote: I wonder how much kawasaki wants for them. Z1 wants almost $70 for the set.
If you can get a set of 4 for about $70 that's a good deal. Partzilla wants $38 for each holder, and their prices are usually very good. Ed
- ChopFinger123
02 Mar 2014 11:29
Well i think i figured out the problem with the ignition. I had the green wire and the black wire swapped around. Hopefully that'll fix my problem.
Now if this weather would cooperate maybe i can get this thing running.
