kz750 ltd h2 1981 - will crank wont start fully?
- KZJOE900
- Administrator
Super Users
Re: kz750 ltd h2 1981 - will crank wont start fully?
02 Mar 2012 18:59
Hi Angel, the video is not available. You will need to first post it to a media service such as YouTube (if you have an account). Afterwards, you can edit your prior post and delete the file attachment section. Replace it with a video link (choose the video link icon when you are in edit mode at the top of the text editing window). Paste the link in at resubmit your post. The video link should show on your post. You can keep editing your prior post until you can get it to work. Good luck.
76 KZ900
82 XJ550R SECA
Past:
86 FJ1200
74 Z1900
72 CB450
76 KZ900
82 XJ550R SECA
Past:
86 FJ1200
74 Z1900
72 CB450
- steelhorseangel
- [email protected]
02 Mar 2012 19:15
hi kzr's
i don't know whether this is the correct video file format.
can someone let me know if you can/can't see these videos please.
q) what file format is recommended riders?
here is the second video two weeks later, that i made after checking/adjusting
the leaky carbs by the 'clear tube method', thank you for helping me with this.
many thanks
Angel
many thanks
Angel
Angel
Restore, Wrench & Ride!
Brought up with Dad, brother, all riders!
Our Dad (Eric) taught us both simple mechanics
before he went to the happy hunting ground, too soon (44)
My KZ is now called Eric and he will ride and protect me!
x God Bless x
x God Bless x
- MFolks
02 Mar 2012 19:26
A big caution about using a glass bodied fuel filter! Many a bike and car fire has been caused by the glass body being cracked from vibration, and then dripping down by a hot engine.
I'd hate to read that all the time and effort you've put in the bike went up in a fire.....
- steelhorseangel
- [email protected]
02 Mar 2012 19:45
hi mfolks
thank you very much for telling me
about this. i just assumed that the filter glass
is toughened glass?
regards
Angel
is toughened glass?
regards
Angel
Angel
x God Bless x
x God Bless x
- Motor Head
02 Mar 2012 20:14
See if you can post up your video on you-tube, and then link it here.
Glass, and plastic, both types can be a disaster. Watch out where you mount either, vibration, heat, contacting a surface, etc. You can melt, or where a hole in a Fuel line or filter pretty easy.
Hope the bike is running well. Did you get the Ignition timing figured out Angel?
- steelhorseangel
- [email protected]
02 Mar 2012 20:36
hi motorhead
good to hear from you!
i've some probs at my end.
tek gave some sound advice about fuel
in my engine. asked me to smell my
oil filler cap. this smells like a cup of
fuel. so the fuel from the carbs, before
the 'clear tubes' contaminated my engine
oil. i can't get engine oil for my bike,where
i live. i've ordered some gulf semi synth
track oil. i will then change the oil/filter.
i can then have a look again at the timing.
the bike starts immediately, nothing leaks.
three pipes are hot, one warm/just.
i've been concerned about the fuel in the
oil. i'm just waiting for the new oil/filter-monday.
well the glass inline fuel filter looked suitable
for the job. i never thought about the
glass breaking. i assumed that it was
toughened glass, that wouldn't break.
i'm sending it back.
just won a pingel and adapter on
ebay, bargain price. mfolks says these
are good.
many thanks
Angie
ps: i will use utube to post eric's startup!
thanks motorhead!
are good.
many thanks
Angie
thanks motorhead!
Angel
x God Bless x
x God Bless x
02 Mar 2012 20:37steelhorseangel wrote: ... 'eric' starting up!
....Attachment 1ststartup14thfeb12_WMVV9.wmv not found
No problem playing the video.
- steelhorseangel
- [email protected]
02 Mar 2012 20:55
hi motorhead
i've uploaded converted movies of
the start up by alan, the mechanic.
then another after the carbs had
been clear tubed. the file format is
microsoft windows *.wmv.
**** patton said he can watch them,
can you?' they're not spielburg standard!
just a little video of what you and all
the other kzr's have done to get eric
started! made my day, thank you! ****
regards
Angel
regards
Angel
Angel
x God Bless x
x God Bless x
02 Mar 2012 21:08steelhorseangel wrote: ...here is the second video two weeks later...
Can see the first video (in the earlier post), but cannot see the second video (as referenced in the quoted post 507447).
02 Mar 2012 21:27
Perhaps find some helpful info in this thread:
www.kzrider.com/forum/8-about-the-site/3...me-made-video#334633
- Motor Head
02 Mar 2012 23:51 - 03 Mar 2012 11:30
I see the video that Patton was kind enough to post, but the other is not there. The one sounds like it is running on three cylinders, Idle way to high and possibly to much valve clearance. There is a bit of metallic sound, possibly from to much valve clearance. One of the three cylinders sound to be not running at all. This would be the one you refer to as Cold to the touch on the exhaust pipe. Try to drop the Idle speed adjustment screw to get the Idle closer to 1000 RPM, then attempt to find where or why it is not running on that cylinder. Could possibly be a vacuum leak, have you got a plug or connection to each of the four vacuum nipples at the intake manifolds? Maybe spray some carb cleaner around the intakes, once you have the Idle down a bit lower. It should change RPM, smooth out and increase when sprayed where there might be a vacuum leak. The vacuum leak would be pulling air with no fuel, causing it not to run. Or maybe the cylinder is not getting fuel through the low speed/ pilot circuit? Maybe it is possible that the spark plug has fouled, from to much Petrol? Was that the cylinder that the carb was overflowing/ leaking? I would double check the compression also.
Last edit: 03 Mar 2012 11:30 by Motor Head.
- TeK9iNe
- What did you do!?!
03 Mar 2012 17:14 - 03 Mar 2012 17:29Motor Head wrote: I see the video that Patton was kind enough to post, but the other is not there. The one sounds like it is running on three cylinders, Idle way to high and possibly to much valve clearance. There is a bit of metallic sound, possibly from to much valve clearance. One of the three cylinders sound to be not running at all. This would be the one you refer to as Cold to the touch on the exhaust pipe. Try to drop the Idle speed adjustment screw to get the Idle closer to 1000 RPM, then attempt to find where or why it is not running on that cylinder. Could possibly be a vacuum leak, have you got a plug or connection to each of the four vacuum nipples at the intake manifolds? Maybe spray some carb cleaner around the intakes, once you have the Idle down a bit lower. It should change RPM, smooth out and increase when sprayed where there might be a vacuum leak. The vacuum leak would be pulling air with no fuel, causing it not to run. Or maybe the cylinder is not getting fuel through the low speed/ pilot circuit? Maybe it is possible that the spark plug has fouled, from to much Petrol? Was that the cylinder that the carb was overflowing/ leaking? I would double check the compression also.
This sounds absolutely bang-on correct.
Soooo video was old. Disregard then... Carry on. :laugh: :laugh: :laugh: You're on the right track now!
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
Last edit: 03 Mar 2012 17:29 by TeK9iNe.
