Brighter Light?
  • 750steve
  • 750steve's Avatar Topic Author
Brighter Light?
11 Nov 2011 16:38 - 11 Nov 2011 19:49
#488065
Ok lighting guru's, i bought a bates style headlight & would love to go HID but is it possible with this bulb? There is also a sidelight bulb built in too in another part of the light.
07 ZX6R Race Bike
1977 Z750 B2 Twin
1976 Z650 B1
Last edit: 11 Nov 2011 19:49 by 750steve.
  • mtbspeedfreak
  • mtbspeedfreak's Avatar
Re: Better Light?
11 Nov 2011 17:55
#488074
2000 ZRX 1100
1976 KZ 900- Daily Driver
The following user(s) said Thank You: 750steve
  • 750steve
Re: Better Light?
11 Nov 2011 18:30 - 11 Nov 2011 18:31
#488079
Thank you.....that all confuses me a little though........no surprise there TBH! :lol:
Is there a name for my bulb? eg H7 / H4 ????
07 ZX6R Race Bike
1977 Z750 B2 Twin
1976 Z650 B1
Last edit: 11 Nov 2011 18:31 by 750steve.
  • mtbspeedfreak
Re: Better Light?
11 Nov 2011 18:48
#488082
Hey Steve, unfortunately, I don't know what kind of bulb you have there.
If you convert to HID, you must use a reflector specifically designed for HID bulbs as HID light are significantly brighter than most [all ;)] other bulbs. Using such a bright bulb in a reflector not designed for it will blind oncoming traffic.
Maybe Otto can chime in and give you some more information.
2000 ZRX 1100
  • 750steve
Re: Better Light?
11 Nov 2011 19:17 - 11 Nov 2011 19:20
#488085
mtbspeedfreak wrote: If you convert to HID, you must use a reflector specifically designed for HID bulbs as HID light are significantly brighter than most [all ;)] other bulbs. Using such a bright bulb in a reflector not designed for it will blind oncoming traffic.
Oh dear, that seems like alot of trouble! If i knew what bulb that was i'd settle for LED if its possible or a bigger wattage bulb if thats safe to do.
All i can find at the minute is its called a 'Bosch Type' bulb
07 ZX6R Race Bike
1977 Z750 B2 Twin
1976 Z650 B1
Last edit: 11 Nov 2011 19:20 by 750steve.
  • 750steve
Re: Better Light?
11 Nov 2011 19:37
#488087
No eBay APP ID and/or Cert ID defined in Kunena configurationNo eBay APP ID and/or Cert ID defined in Kunena configurationNo eBay APP ID and/or Cert ID defined in Kunena configurationNo eBay APP ID and/or Cert ID defined in Kunena configurationI found a code for it, ba20d
So is it ok to use these safely?
I dont see how i have a high beam with the kit below
07 ZX6R Race Bike
1977 Z750 B2 Twin
1976 Z650 B1
  • otakar
  • otakar's Avatar
Re: Better Light?
11 Nov 2011 22:20 - 11 Nov 2011 22:22
#488106
you can use any of the Halogen bulbs that you found but you can't use the HID setup because you would have to change the reflector also. On a single light vehicle you can go as hi as 75W but you are restricted by the power output of your alternator. You would have to find out what it puts out.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
Last edit: 11 Nov 2011 22:22 by otakar.
  • 750steve
Re: Better Light?
11 Nov 2011 22:47
#488110
Ok Otakar, thank you. Is there a 4.5 inch reflector you can recommend then? Its a bates style headlight
07 ZX6R Race Bike
1977 Z750 B2 Twin
1976 Z650 B1
  • H1Vindicator
  • H1Vindicator's Avatar
Re: Better Light?
12 Nov 2011 14:00 - 22 Jan 2013 00:53
#488184
Last edit: 22 Jan 2013 00:53 by H1Vindicator.
  • otakar
  • otakar's Avatar
Re: Better Light?
12 Nov 2011 14:29
#488188
750steve wrote: Ok Otakar, thank you. Is there a 4.5 inch reflector you can recommend then? Its a bates style headlight
I Can't help you there. I just deal with the standard 7" in the round. All modern light reflectors have UV coatings.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
  • 750steve
Re: Brighter Light?
12 Nov 2011 18:51
#488220
No eBay APP ID and/or Cert ID defined in Kunena configurationIts ok, i ordered this today, for £3.29 delivered in UK money i cant really go wrong TBH, if its no good i'll check out the clear looking ones
07 ZX6R Race Bike
1977 Z750 B2 Twin
1976 Z650 B1
  • steell
  • steell's Avatar
Re: Better Light?
13 Nov 2011 20:54 - 13 Nov 2011 21:08
#488351
H1Vindicator wrote:
mtbspeedfreak wrote: ...
Also, HID light produce UV radiation that can be harmful to the human eye.
HID headlight assemblies have a lens that blocks the UVs.
An incorrect beam pattern & lack of UV filtering is why most if not all HID conversion kits are illegal for street use.
Er, no, they are illegal for street use because they are not DOT certified, and they're not DOT certified because no one wants to spend the $$$$$$$$$$$$$$ to get them certified.
I've never heard of anyone enforcing it though.
Check out the article at en.wikipedia.org/wiki/High-intensity_discharge_lamp
Last edit: 13 Nov 2011 21:08 by steell.
