Ballistic Battery opinions/thoughts?
- MFolks
21 Oct 2011 16:46
Ballistic Battery opinions?
Ballistic Batteries EVO2 now with Balanced Charging Capabilities
Ballistic Performance continues to lead the way with innovative lightweight batteries for motorcycles, ATVs and other applications where power and weight are important factors. Now, Ballistic has introduced a new connection scheme that perfectly compliments their Battery Management System (BMS): Intelligent Digital Balance Charger. This additional connection allows the user to charge each cell within the battery individually for a balanced charge and peak performance. Furthermore, balanced batteries can be expected to last twice as long as batteries that are only charged by your machine’s generator system. And should you choose to forego the Ballistic BMS charger, you can still charge every Ballistic Performance EVO 2 battery in the conventional manner as directed by the included instructions.
Ballistic Performance EVO2 batteries are available in four different sizes: 4-cell, 8-cell, 12-cell and 16 cell.
These hand-made in the USA lithium iron phosphate batteries are engineered to be extremely light, durable and powerful with every component designed specifically for use in high-performance powersports applications. If you’re looking to save a significant amount of weight, and improve your machine’s starting performance, look no further than Ballistic Performance EVO2 batteries. Often, our machines are designed to be as light as possible yet they still employ rather arcane lead-acid batteries that comparatively, weigh a ton. Depending on the application, you can expect to save up to ten pounds of weight just by switching batteries! This is a considerable amount of mass that will be noticeably absent the first time you ride the bike with this battery installed.
From a maintenance standpoint, a conventional lead-acid battery will lose much of its charge, even during short-term storage which is why trickle chargers are so popular today. Ballistic Performance EVO2 lightweight lithium iron phosphate batteries have a very low self-discharge rate and can easily withstand indoor storage for a year or more with no recharging required to start your bike afterwards!
Another big advantage of this aftermarket motorcycle battery, other than its light weight - is its power output performance. Pound-for-pound, conventional lead-acid batteries do not transfer electricity nearly as efficiently as Ballistic Performance batteries and consequently, must be built oversized to make up for this. The result is a battery that weighs significantly more yet provides less starting power output than a Ballistic EVO2 battery.
For those of you concerned with properly securing a Ballistic Performance battery in your ride, each battery comes packaged with a foam carrier that can be cut and shaped perfectly for installation. And with the addition of a BMS Intelligent Digital Balance Charger, Ballistic Performance batteries can be kept at true peak performance year-after-year.
If you’re unsure of which battery is best for your application, call our expert Nate at 866.931.6644 x 809 or send a note to FORUM at RIDERSDISCOUNT dot COM with BALLISTIC EVO2 BATTERIES in the subject line, let us know what machine you have, and we’ll get back to you right away.
New Ballistic EVO2 batteries come with a BMS plug in right between the leads.
This port is designed to allow users to plug in a Ballistic BMS Intelligent Digital Balance Charger for peak charging performance and extended battery life.
Other than the addition of this extra charging port, there is little difference between the latest EVO2 battery and its predecessor. Each EVO2 battery comes fully charged out of the box, simply plug in and you’re ready to go. The high-strength chassis provides a durable package for the LiFePO4 cathode that’s up to the challenge of starting high-compression engines. Plus its small size frees up room within your bike’s battery box for popular aftermarket tuning equipment like a Power Commander or a Bazzaz Performance tuning kit.
Fret not, those of you that have already purchased a Ballistic Performance EVO2 battery without the balancer feature. This charger can also be used to keep your Ballistic Performance battery in top running condition.
Four, eight, twelve and sixteen cell batteries are available to suit a wide range of applications. From dirtbikes and ATVs to high-compression V-twins – if you’re unsure of your needs, call us for advice on what best suits your application.
And where maximum power is required, we now have 16-cell Ballistic Performance batteries in stock.
- tachrev
- Rubber Side Goes Down
Re: Ballistic Battery opinions/thoughts?
21 Oct 2011 17:09
I have one, but I haven't run the bike with it yet. I only used it to test my redesigned wiring harness.
I think DutchZ put one on his bike and seemed happy with it.
Super light...my 8 cell is around 1.5 lbs or less, with more CCA than the stock lead acid battery.
The shop I got mine from uses them in a lot of SV's and also in a few total loss race bikes. They like 'em.
Build Thread
Build Thread
- clutch
- I wish I had a tad more patience to do it better!
21 Oct 2011 19:54
Kinda pricey, but if they work well, I may get one when it's time for a new juice box (lol)
Southern Maryland, USA
1980 KZ250 LTD (traded, but still missed)
1982 KZ750 E3 (Cafe Project) (Dyna-S, Dyna Coils, V&H 4-1, K&N Pods, 6 Sigma Jet Kit, Acewell Computer, Woodcraft Clip-ons, Custom Rewire)
1966 A1 Samurai (Restoration Project)
Wish List:
KZ1000 P (For a "touring" bike)
Z1 (need I...
Wish List:
Z1 (need I...
- bountyhunter
22 Oct 2011 03:09 - 22 Oct 2011 03:12
That is the EXACT battery technology being used in development of the massive electric vehicle battery packs here. They are not tolerant of overcharging or incorrect charging. If you have multiple cells in series, you have to monitor each cell and "balance charge" to maintain battery health.
IMHO, the typical bike charging system is nowhere near accurate enough to properly charge a Lithium rechargeable battery.
Any guarantees from the battery maker on what charge voltage it has to have? That info is conspicuously absent from the marketing BS.
Last edit: 22 Oct 2011 03:12 by bountyhunter.
- clutch
22 Oct 2011 03:13bountyhunter wrote: That is the EXACT battery technology being used in development of the massive electric vehicle battery packs here. They are not tolerant of overcharging or incorrect charging. If you have multiple cells in series, you have to monitor each cell and "balance charge" to maintain battery health.
Hmmm...maybe I will just stick with the standard juice box then...the ones with the liquid in them, and the straw sticking out the side seem to work just fine for me...
Wish List:
Z1 (need I...
Wish List:
Z1 (need I...
- bountyhunter
22 Oct 2011 03:17 - 22 Oct 2011 03:18
Here's the problem from their web site:
ballisticparts.com/tech/charging.php
"1.) When charging a Ballistic Performance Components Battery with a traditional automotive or motorcycle based external charging device, the following input specifications are recommended:
Standard Charge: 2A @ 13.2-14.4V for approximately 45 minutes or until the battery registers 14.4V."
That is NOT how a bike's charging system works. It supplies whatever current is required to hold the battery voltage at 14V +/-0.5V.
I would not use a battery unless the maker is EXPLICITLY STATING it is compatible with a standard electrical system. I don't think it is.
Last edit: 22 Oct 2011 03:18 by bountyhunter.
- 750steve
22 Oct 2011 03:57
Bountyhunter is a Shorai battery the same as the Ballistic ones? Have i anything to be cautious of/worried about when mine arrives? I needed a small battery to keep it hidden as much as possible.
07 ZX6R Race Bike
1977 Z750 B2 Twin
1976 Z650 B1
1977 Z750 B2 Twin
1976 Z650 B1
- bountyhunter
22 Oct 2011 04:02 - 22 Oct 2011 04:04
I don't know, I haven't researched them. I just learned about the Lithium Iron batteries because a buddy of mine worked with a guy developing an EV and they called me in on it.
EDIT TO ADD ABOUT SHORAI:
"The product utilizes Shorai exclusive, eXtreme-Rate LiFePO4 cell technology"
That is also lithium iron technology, I don't know the tech specs.
Last edit: 22 Oct 2011 04:04 by bountyhunter.
- stonemaster
- Sorry I wasnt paying attention
22 Oct 2011 04:39
this is a topic I have researched to some degree, I am considering a Ballistic for my bike but still am in the research mode the following article is one I found interesting, take it for what u will
www.webbikeworld.com/motorcycle-battery/...torcycle-battery.htm
jus ridin my Rickshaw baby, among other things
- clutch
22 Oct 2011 05:02
It seems that all of the major parts suppliers are carrying these. I'm assuming if there were any major issues, they would have been ditched by now....but keep in mind that they are running the tests in the article linked above in a newer motorcycle...may or may not be similar results putting them with our 30 year old charging systems.
Wish List:
Z1 (need I...
Wish List:
Z1 (need I...
- stonemaster
22 Oct 2011 05:16
the one thing I 've heard is that u need to warm up theses batteries for a minute or 2 before starting, Just what I've heard, also some that are considering this option are going with vrod batteries, i dont know why for sure ( size and weight) but something u might want to look into
- 750steve
22 Oct 2011 08:00stonemaster wrote: this is a topic I have researched to some degree, I am considering a Ballistic for my bike but still am in the research mode the following article is one I found interesting, take it for what u will
Very interesting read that!
07 ZX6R Race Bike
1977 Z750 B2 Twin
1976 Z650 B1
1977 Z750 B2 Twin
1976 Z650 B1
