Ballistic Battery opinions/thoughts?
- bountyhunter
Re: Ballistic Battery opinions/thoughts?
22 Oct 2011 16:44 - 22 Oct 2011 16:44
The problem I see is that they list the optimum full charge voltage as 3.6V per cell which is 14.4V for the four cell stack. The typical bike voltage regulator will charge to 14.0V, +/- maybe 0.3V ballpark.
That means the battery is going to be undercharged by typically 400 mV (about 2.8%) or as bad as about 5% at lowest charge voltage.
Here is the worry: on Lithium Ion batteries, charging to a value 1% below ideal actually undercharges the battery's energy by about 30%. That's why Sony and sanyo absolutely required we hold the charge voltage to better than 0.5% on our charge control IC's. Very slight changes in charge voltage meant very large differences in energy delivered to the battery.
Maybe Lithium Iron is more forgiving (?) maybe not, I see no data from the battery makers on this. I would like to know how the battery will perform if it is undercharged by 5% voltage due to bike voltage regulator tolerance.
Last edit: 22 Oct 2011 16:44 by bountyhunter.
- loudhvx
22 Oct 2011 20:52bountyhunter wrote: The problem I see is that they list the optimum full charge voltage as 3.6V per cell which is 14.4V for the four cell stack. The typical bike voltage regulator will charge to 14.0V, +/- maybe 0.3V ballpark.
If the average voltage measured on the system is 14.3v (as is typical), ripple peaks will likely easily hit 14.4v, so the battery will likely see more than what it needs in terms of absolute/instantaneous voltage. The regulator is only regulating average voltage, so alternator ripples and ripples due to ignition duty cycle, and even turn signals, will get through. So it's really a matter of where the ripple peaks are, and the area under those peaks. Both of those values will vary greatly depending on RPM and other conditions.
If the Li-Fe battery needs a strictly DC, 14.4v value, there is no chance of getting that from a standard charging system. If it can deal with a varying duty cycle of peaks above that, then it may work.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
- bountyhunter
24 Oct 2011 01:42 - 24 Oct 2011 01:54
The problem is a standard ignition is typically about 13.6 - 14.4V (room temperature set point) but voltage regulator devices for lead acid batteries have a tempco built in of about -20mV/degC to track the tempco of a lead acid battery. That means in the winter at freezing temps, the voltage set point goes up about 400 mV. At high temps it goes down.
Bottom line: if the battery needs 14.4V to fully charge it (as their spec says): how much does it get charged if you only apply 13.8V continuously? Or 13.6? I'll wager it's something like 60 - 70% at best, probably less.
BTW: the recommended charger they sell has the "balance" feature built in. Pricey but it says it doubles the life of the battery.
www.ballisticparts.com/products/Charger/chargerBalance.php
If I was putting one of these batteries in my bike, I would wire the battery terminals out and connect it to their battery charger each time I parked it so the battery would be properly charged for next use. The typical bike regulator is going to be pretty iffy. It will charge it some while you ride, my guess is way less than 100%. It still surprises me they have absolutely no data on that available.
Last edit: 24 Oct 2011 01:54 by bountyhunter.
- jus1975
- www.tripleaperformance.com
24 Oct 2011 02:59
Do you guys want to give them a try. i have an account with them. If you like we can do a group buy
- ezrider714
24 Oct 2011 21:27
Don't understand the need for them.
Have had very few battery issues in over 30 yrs.
yeah they wear out every so often, what doesn't :laugh:
Unless it's for racing, and hotter, crisper ignition,
just another fix for something not broken
My thoughts, but hell I'm a mechanical guy, what do I know :dry:
78 KZ650SR Mine since 79
4-1 Mac Jet Hot coated since mid 80's
Dyna Coils
Saddlebags (I ain't skeered of going nowhere)
Dyna Coils
- 750steve
24 Oct 2011 22:27
Personally i'm buying one to conceal more easily, i like the idea of keeping the electric start but its good to have the kicker there for backup! The STD battery is way too big to conceal, if i could run it & spare the expense I would. Reading all of the above form more knowledgeable members things dont look good for me though! lol. Time will tell, i didn't buy the special Shorai charger (yet) either
07 ZX6R Race Bike
1977 Z750 B2 Twin
1976 Z650 B1
1977 Z750 B2 Twin
1976 Z650 B1
- clutch
- I wish I had a tad more patience to do it better!
24 Oct 2011 22:36ezrider714 wrote: Unless it's for racing, and hotter, crisper ignition,
Excellent point, but it is smaller and lighter as well. Basically it would seem that each of us would need to decide for ourselves whether the pros outweigh the cons, and vice versa.
Southern Maryland, USA
1980 KZ250 LTD (traded, but still missed)
1982 KZ750 E3 (Cafe Project) (Dyna-S, Dyna Coils, V&H 4-1, K&N Pods, 6 Sigma Jet Kit, Acewell Computer, Woodcraft Clip-ons, Custom Rewire)
1966 A1 Samurai (Restoration Project)
Wish List:
KZ1000 P (For a "touring" bike)
Z1 (need I...
Wish List:
Z1 (need I...
- bountyhunter
25 Oct 2011 04:37Strictly for size and weight reduction.ezrider714 wrote: Don't understand the need for them.
- tachrev
- Rubber Side Goes Down
25 Oct 2011 10:01bountyhunter wrote:Strictly for size and weight reduction.ezrider714 wrote: Don't understand the need for them.
Exactly.
There was no lead acid battery that would fit in the space I had, with the cranking amps to be useful for cranking the bike.
If I have issues with the battery, I will be sure to post it up. It won't be up and running until next season though.
I will probably end up getting the balancing charger for it as well.
Build Thread
Build Thread
- ezrider714
25 Oct 2011 21:54
I could think of 20 things to lighten up,before even considering the battery. Hell it's not big by any stretch of the imagination.
If the weight of the battery slows down your bike you have much bigger issues with it :dry:
Dyna Coils
Dyna Coils
- tachrev
26 Oct 2011 11:22ezrider714 wrote: I could think of 20 things to lighten up,before even considering the battery. Hell it's not big by any stretch of the imagination.
My stock battery with fluid, which was already smaller than the stocker, weighed about 12 lbs, IIRC.
The ballistic weighs a bit over 1 lb. That's a pretty big difference in weight on a motorcycle.
Plus, for custom applications you can mount if however you need to(sideways, upside down), in a much smaller space.
Anyway, I got mine for space reasons, but I'm not going to complain about losing another ~10lbs off my bike in the process.
Build Thread
Build Thread
- ezrider714
27 Oct 2011 22:17tachrev wrote:ezrider714 wrote: I could think of 20 things to lighten up,before even considering the battery. Hell it's not big by any stretch of the imagination.
All excellent points for sure.
Now I'm going to have to weigh mine, as I would never have guessed that much.
For custom applications, I could see the reasons for it, along with an up to date charging system to handle the modern technology.
But I'm just not buying that a charging system built in the late 70's has the ability to deal with what, back then was probably just theory. :dry:
That's the fun of working on your own bike,you can make it how YOU want it.
Dyna Coils
Dyna Coils
