Dyna 2000 Electronic Ignition & Coils DDK2-2C KZ65
- MuzzleMike
- Rice Only
25 Aug 2011 12:41
I found that my I C Igniter has gone bad on my 1982 KZ750 LTD H3 . My bike has the original ignition system on it . I am thinking this is probably the first of the system to fail and next will be the pick ups or the coils . I looked on Z1 "
www.z1enterprises.com/Dyna-2000-Electron...Z650-KZ750-1656.aspx
" and I am thinking if this will up grade the whole system and save me some cash . I have never done this before and Z1 has not gotten back with me with my question yet . Will this replace my Igniter along with my coils and pickups ? If this will do it I am thinking that after I get the bike going with it I should had vary little worry s about my ignition system for a while and the next up grade could be my charging system since that is original also but one thing at a time . Any thoughts ?
Mike
Mike
82 KZ750 LTD H3
- otakar
Re: Dyna 2000 Electronic Ignition & Coils DDK2-2C KZ65
25 Aug 2011 13:02 - 25 Aug 2011 13:17
It will definitely upgrade the system. I believe to an unnecessary degree. Why don't you just build a Dual GM CDI ignition for about $60 total, from Lou's drawings. You can get the parts at Radio Shack and any auto supply store. I bought the modules at Advanced Auto Supply for about $25 each His system is better and more durrable than the OE system and quite inexpensive. It is an outstanding system. It works with ALL Kawasaki Four cylinder bikes. You can also upgrade with the same Gray coils as the Dyna2000 uses.
shop.advanceautoparts.com/webapp/wcs/sto...NEAMS_1650024931____
Attachment GPZheiMod.gif not found
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Last edit: 25 Aug 2011 13:17 by otakar.
- MuzzleMike
- Rice Only
25 Aug 2011 13:23 - 25 Aug 2011 13:31
I forgot I seen that !!! I will save the file once my laptop settles down . Thanks SOOOOOOO MUUUUUUUTCH . When I found out that my igniter was bad it felt like it was the end of the world do to lack of cash .
I hate to ask but my computer is not wanting to pint or save the pic as a file . Is there a file some where I can down load and save for this ? And is there certain GM parts I will need ? Like part numbers ? Or did I miss that on the pic? Sorry If I did .
Mike
Mike
82 KZ750 LTD H3
Last edit: 25 Aug 2011 13:31 by MuzzleMike.
- cobura
- forever 2 wheels
25 Aug 2011 13:47
I wish there was a version of that diagram for retards such as myself. Im so lost when it comes to electrical wiring of any kind.
1979 KZ650B3
- mtbspeedfreak
25 Aug 2011 13:47
If you go the Dyna route, I'd suggest the Dyna S over the Dyna 2000 at this point. Dyna 2000s are for race bikes.
2000 ZRX 1100
1976 KZ 900- Daily Driver
25 Aug 2011 13:53If needed, here's how to save a forum image to your computer:MuzzleMike wrote: ...computer is not wanting to pint or save the pic as a file . Is there a file some where I can down load and save for this ?...
Click > www.kzrider.com/forum/8-about-the-site/4...age-to-your-computer
- MFolks
25 Aug 2011 15:13
GM HEI Ignition Modules (4 Pin) Cross Index For Loudhvx's Replacement Ignition Build
AC DELCO
DM1906 or D1906
WELLS
DR 100
ACCEL
ACC 35361/ACC 35367
PERTRONIX
D2000
CAR QUEST
21040
NAPA ECHLIN
ECH TP45
NIEHOFF
DR 400
BORG WARNER
Select CBE4/CBE22
GM
10482820
Mallory
607
Jegs
555-40600
Moroso
97857
AC DELCO
DM1906 or D1906
WELLS
DR 100
ACCEL
ACC 35361/ACC 35367
PERTRONIX
D2000
CAR QUEST
21040
NAPA ECHLIN
ECH TP45
NIEHOFF
DR 400
BORG WARNER
Select CBE4/CBE22
GM
10482820
Mallory
607
Jegs
555-40600
Moroso
97857
- MFolks
25 Aug 2011 15:18
When mounting the modules, make sure to use thermal or heatsink compound between the aluminum plate and the module. It ensures good heat transfer, just a thin film is about all you'll need.
Radio Shack sells a "Artic Siver" in a small easy to use container.
- otakar
25 Aug 2011 18:29mtbspeedfreak wrote: If you go the Dyna route, I'd suggest the Dyna S over the Dyna 2000 at this point. Dyna 2000s are for race bikes.
The Dyna S is only better than the stock points. The OE Kawasaki ignition is A LOT better than the Dyna S and the Lou-Ignitor is even better.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- otakar
25 Aug 2011 18:32 - 25 Aug 2011 18:34
Here is the link for Lou's sight. You will have to cut and paste it.
home.comcast.net/~loudgpz/GPZweb/Ignition/GPZgmHEImod.html
I am building one of these with three modules for my KZ1300.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Last edit: 25 Aug 2011 18:34 by otakar.
- mtbspeedfreak
25 Aug 2011 18:41otakar wrote:mtbspeedfreak wrote: If you go the Dyna route, I'd suggest the Dyna S over the Dyna 2000 at this point. Dyna 2000s are for race bikes.
...point being that the Dyna 2000 would be extreme overkill for his use.
2000 ZRX 1100
- otakar
25 Aug 2011 19:11
Point agreed with.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
