Tach... or no tach?
- treitz
Tach... or no tach?
22 Feb 2011 10:21
Curious, who runs a tach. Who doesn't. And why?
My bike currently has a tach ON it, but my cable is broken so it's not working. Debating just ditching it but wanted to see what everyones opinions are first. A early model 400 at the salvage yard has the speedo only mount that I could pull to clean thing up if I decide to ditch the tach.
Since this is my first bike I don't really know how badly I will wish I had it if I DON'T have it. Make sense?
1979 KZ400 - 2-1 Manifold - Mikuni VM34
- PLUMMEN
Re: Tach... or no tach?
22 Feb 2011 10:44
my tach and speedo are there on my ltd,just too lazy/cheap too buy new cables :laugh:
- treitz
22 Feb 2011 10:47
PLUMMEN wrote:
So they're there, but neither work? I have my tach mounted as well. Just can't decide if I'd rather buy a cable for it, or pull it and try to clean up the look of the front section.
- Mcdroid
- Gone Kwackers
22 Feb 2011 10:48
Virtually everyone runs a tach and speedometer. Some, who know their bikes rather well, skip the speedometer and run only a tach. Personally, I won't run any of my bikes without a tach.
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
- PLUMMEN
22 Feb 2011 11:06
i have a tach built into my pacemaker,it tells me when its time to shift.
with my 1327 its pretty simple to figure,6,000 rpms in 1st 3 gears averages out to about 6" between the ground and front wheel :woohoo:
- loudhvx
22 Feb 2011 11:32
I run just a tach on one bike, but no gauges on two others.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
- hocbj23
22 Feb 2011 12:33
Run Tach and speedo.Tach is not accurate due to Dyna S ignition.Speedo only reads 85 mph so Im forever putting it on the peg.Answer: I gottem but they are about as useless as tits on a boar hog.bj
22 Feb 2011 12:56
I wouldn't run without both. If you're the type to run the bike up to redline from time to time you won't know when you're crossing into the forbidden zone without a tach. If you're a sedate rider (yeah, right, who is?? :lol: ) who never approaches redline you don't need a tach. Ed
- bearshawk
22 Feb 2011 13:06
im about to put a dyna S on my bike and sorry for the threadjack, but how bad will it mess the tach up??
1978 kz650 sr- long time project/first bike mostly gone
1979 kz659 sr- new acquisition NEXT project GONE
Both 650s combined to make one great bike! with a new powerplant
it is a 79 frame, 78 front end, both 78 wheels and brakes, 78 body work and a 80' 750-4 motor with gpz 750 cams and a kerker and...
Last edit: 11 Feb 2013 13:01 by martin_csr.
- treitz
22 Feb 2011 14:06
Mine is mechanically driven... not sure about hocbj23 though.
- hocbj23
22 Feb 2011 15:17
Electronic tach,J bike..When u install Dyna S,u unplug the igniter as the Dyna powers the coils.When u unplug the igniter,u lose the tach. I even installed a seperate tach pickup and it does not seem to help.Tach is still beaucoup bonkers.I dont drive by tach,but if u do,something to consider.Engine sound is quite enough to decide if u r overdoing things or not.Lol.bj
