Tach... or no tach?
Re: Tach... or no tach?
22 Feb 2011 16:24 - 22 Feb 2011 16:27
hocbj23 wrote:
Black-wire from tach connects to coil primary black-wire.
Am uncertain why method of coil primary grounding and ungrounding would matter to the tach.
[Click on image to enlarge view.]
Electronic tach,J bike..When u install Dyna S,u unplug the igniter as the Dyna powers the coils.When u unplug the igniter,u lose the tach. I even installed a seperate tach pickup and it does not seem to help.Tach is still beaucoup bonkers....
Last edit: 22 Feb 2011 16:27 by Patton.
- hocbj23
22 Feb 2011 17:18
Me neither,but apparently the tach does.Tach pickup is on the black wire,and it registers all over the map.I called the folks that make the pickup and have tried all their suggestions to no avail.Last time I called,thetech rep said that the pickup reads "square wave" signals and the bike may be emiting some other type signal.I am not an electrician,so I wouldnt know a "square wave signal" if it bit me in the bohunkus.At least as long as it doesnt make me glow green in the dark.So there u are.bj
- 1981kz550ltd
22 Feb 2011 17:36
the tach is my most favorite intrument!!! i love it! it is so useful. When i got my 550, the cable was busted, and the first thing i did was buy a new cable. It is just really useful for me, as far as shifting, and just everything... if it has a tach, fix it!!! but thats just my opinion.
22 Feb 2011 18:11
hocbj23 wrote:
Then that explains it, 'cause the coils are round. :laugh:
Unfortunately, I don't know squat about aftermarket tach pick-ups, and was envisioning simply a basic splice into the black-wire to coil primary.
Wonder if other J bike owners with Dyna-S are experiencing the same tach problem?
- mtbspeedfreak
22 Feb 2011 18:50
I look at my tach MUCH more frequently than my speedo.
And I have a Dyna S too. I try not to run it >9k
2000 ZRX 1100
1976 KZ 900- Daily Driver
- loudhvx
22 Feb 2011 23:17
hocbj23 wrote:
The Dyna S uses a super-long dwell. This means the time that coils are not getting primary current is too short for the tach to acknowledge. Most electronic tachs are looking for a more reasonable ratio of "on" time to "off" time for the coils. With the Dyna S, the coils are "on" almost all of the time.
If the tach can take signals from just one coil of a two-coil KZ, then I would think the adapter circuit would be easy to make.
How did the seperate tach pickup attach?
Have you tried an adapter circuit of any kind?
Electronic tach,J bike..When u install Dyna S,u unplug the igniter as the Dyna powers the coils.When u unplug the igniter,u lose the tach. I even installed a seperate tach pickup and it does not seem to help.Tach is still beaucoup bonkers.I dont drive by tach,but if u do,something to consider.Engine sound is quite enough to decide if u r overdoing things or not.Lol.bj
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
- john8
- Anything unrelated to elephants is irrelephant
23 Feb 2011 05:12
If you know your bike, you know when to shift. It is like driving a stick shift in a car. If you need a dummy light you shoulden't be driving one. My kz1000 came with one that did not work either so I ditched it.
I want to ride my bicycle!!!
23 Feb 2011 12:06
john8 wrote:
So when you're running up through the gears at wide open throttle you can tell by the sound and feel of your bike when it hits 9000 RPM (or what ever the readline is on your machine)? I'm impressed. I've put more than 50,000 miles on my bike and I cannot do that. I'll need to write to the factory motorcycle racing teams and give them the good news - they no longer need tachs. I'll also pass the news along to NASCAR. Thanks for the tip.
- 550A2
- keep the shiny side up
23 Feb 2011 12:15
I do like my tach, and I do use it. But when im cruising I dont rely on my tach to know when to shift. I know how my bike runs and sounds when its time to shift, especially if im really ripping, I keep my eyes on the road!
Id say its not completely neccisary if you have a feel for your bike and dont bounce it off redline much.
Ditch it or keep it, its up to you...Cables are usually cheap.
82 Honda ATC 200-sold
82 Yamaha Virago 920-sold
82 Yamaha YZ250j-kept
80 Suzuki GS 550-sold
82 Kawasaki KZ550 A2-ride all the time
79 Kawasaki KZ650 C-sold
73 Kawasaki Z1 900E-paid $200, sold $6000
86 Yamaha Radian YX600-new project
- PLUMMEN
23 Feb 2011 12:15 - 23 Feb 2011 12:19
650ed wrote:
most people will never have the balls to redline a 900/1000,or the ass to hold it down ! :woohoo:
shift when it quits pullingjohn8 wrote:If you know your bike, you know when to shift. It is like driving a stick shift in a car. If you need a dummy light you shoulden't be driving one. My kz1000 came with one that did not work either so I ditched it.
Last edit: 23 Feb 2011 12:19 by PLUMMEN.
23 Feb 2011 12:49
PLUMMEN wrote: "shift when it quits pulling"
The problem is my bike is still pulling hard as it hits redline (9k) so my concern is that when it quits pulling it might quit running because it blew up. :laugh:
- PLUMMEN
23 Feb 2011 15:41
ive never seen a stock bike that would keep making power all the way to redline without some upgrades,theres a differance between being able to rev to 9000 and making actual hp at 9000. :laugh:
most 900s-1000s even with a pipe quit making power closer to 7000-7500,but will still rev past that point.
allthough i must admit banging a big kaw through the gears at 8500 at a stop sign is something i hope to never grow tired of! :woohoo:
