No spark at the POINTS??
- bgmrc
Re: No spark at the POINTS??
15 Feb 2011 05:34
yes mine is the pull clutch to use starter...
and i was in nuetral and kickin her...
- TeK9iNe
- What did you do!?!
15 Feb 2011 13:24
bgmrc wrote:
:laugh: The descriptor "strange" does not compute.
Describe what is happening in order of what you do.
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- bgmrc
16 Feb 2011 08:52
yea...re reading that was a little OFF sounding...
when im in neutral and on bike...when i kick it it is very easy to kick with like little resistance and it seems not to move the pistons thru rotation nearly enough...if that makes sence...
like 1 full kick barely gets the bike to turn over....it feels as strange as it sounds discribing it to yall...
Ima pop start it down my local church parkin lot on friday or sat. I just ordered a starter off ebay and will install that when it comes in...till then its down the hill time..
thanx
thanx
16 Feb 2011 11:31
If not already done, would try kicking in neutral while NOT squeezing the clutch lever.
In event clutch is failing to fully engage with lever not being squeezed, could mean clutch is "slipping" which might be resolved by a simple push-rod adjustment.
- bgmrc
16 Feb 2011 12:42 - 16 Feb 2011 12:45
^^interesting...i dont pull the clutch in what starting with kicker...or start button...due to the clutch wires pulled out..
as mine is wired to not need to pull the clutch in to start it...the 2 black wires ar not going to the clutch right now...they r just twisted together....
so i still might need still pull the clutch when useing the kicker??.oppisite of what ur describing above??..even though its not needed electricly??
wondering...
when i get time ill look into fixing that clutch lever
wondering...
Last edit: 16 Feb 2011 12:45 by bgmrc.
16 Feb 2011 13:33
bgmrc wrote:
Don't squeeze the clutch lever when using the kick starter.
The clutch lever is of course located on the left side of the handlebar. It works the clutch cable that enters the sprocket cover.
The clutch push-rod adjustment is accessed through a removable panel on the sprocket cover. If the prescribed gap isn't set, it may be too tight and thereby preventing full clutch engagement which causes the clutch to slip even when the clutch lever isn't being squeezed.
...so i still might need still pull the clutch when useing the kicker? when i get time ill look into fixing that clutch lever
- bgmrc
17 Feb 2011 07:31
is the adjustment in the manual?
il look and make that adjustment if needed
Thanks bro!!
Thanks bro!!
17 Feb 2011 09:42 - 17 Feb 2011 13:51
bgmrc wrote:
Yes, it's a routine maintenance item.
Assure having some "slop" in the cable.
Removing the access plate should reveal the adjustment screw and locknut.
First, slightly loosen the locknut.
The hidden end of the screw interfaces with the pushrod.
The basic idea is to lightly seat the screw against the pushrod, then back the screw 1/4 turn away from the pushrod, to thereby provide a small gap between end of screw and pushrod.
Here's a possible snag ---
The screw is part of an actuator assembly.
On some designs (screw-type), the screw turns clockwise to seat before turning counter-clockwise to provide the gap.
On other designs (ball and ramp), the screw turns counter-clockwise to seat before turning clockwise to provide the gap.
Will now speculate that the bike at hand has the ball and ramp style, whereby the screw turns counter-clockwise to seat before turning clockwise to provide the gap. But I might be wrong. So if it doesn't work that way, adjust it the other way.
Remember to snug the locknut before finishing. Just snug is plenty tight enough.
Lastly, reduce "slop" in the cable to produce desired amount of free play in the lever at the perch.
is the adjustment in the manual?....
Last edit: 17 Feb 2011 13:51 by Patton.
- bgmrc
- bgmrc
18 Feb 2011 07:46 - 18 Feb 2011 07:48
adjusted that clutch area on the case and it worked perfect!!!!
i had no slack at all in the clutch...and super hard to pull in the clutch...lil adjustment and it works great!!
thanks yall!!
amazing...kicker works good and was able to pop start it on the 3rd try in the parking lot across street...
ran well!!!
all i need now is paint/grinding/re locate battery/cafe seat/front brakes/starter installed/blaa blaa blaa
but now i can start all that now that i now its a running bike
SWEET!!
thamx all!!!
thanks yall!!
ran well!!!
SWEET!!
thamx all!!!
Last edit: 18 Feb 2011 07:48 by bgmrc.
- vosberdv1975
18 Feb 2011 18:14
Check the resistance of your coil. I think it should be between three and five ohms. Also check to make sure your wire to your points is not touching any surface other that the screw to your points. Could also be a faulty condenser.
- bgmrc
20 Feb 2011 10:53
^^thanx bud...replaced all the parts u spoke of...it was a bad set of points
