No spark at the POINTS??
- bgmrc
Re: No spark at the POINTS??
21 Jan 2011 06:44
cool thanx^^^
nothing happens when i hit the starter botton...but it oemed out when i had it apart..ill chech power to it...where does power come in form for the start button?
what/where supplies voltage to the points area??
will redo some more connection...i got most of them already
- stonemaster
21 Jan 2011 06:56
bgmrc wrote:
u need a wiring diagram or
trace the wires from the component in question
if u got power to the button, then ur next problem would be the starter relay,its probably bad, if it dont turn over then no power will go to points, so save that till next
cool thanx^^^
- bgmrc
21 Jan 2011 07:16 - 21 Jan 2011 07:17
MY MANUAL HAS WIRE DIAGRAM FOR CANADIAN AND EUROPE VERSION ONLY...UGGHH
THANX FOR INFO..
ILL KEEP CHECKIN FOR POWER TO START BUTTON
THANX FOR INFO..
Last edit: 21 Jan 2011 07:17 by bgmrc.
- Motor Head
21 Jan 2011 07:47 - 21 Jan 2011 08:18
From what I see the USA and Canadian models have the same wiring.
Here is the diagram, it is under file base here on KZR. Go to the green bar at the top, Under KZ Information, get into file base and search. It comes up as a pdf, you need adobe acrobat reader to view.
Now look at the Diagram, you need power from the battery across the 20 amp fuse on the White wire going into the ignition switch. That's first, make sure of it. Then with the key on you should have power coming out of the Ignition switch on the Yellow wire to the coil. Then also the Brown wire at the Ignition switch should have power when the key is on, this goes to your start button, and brake light switch to name a few.
Last edit: 21 Jan 2011 08:18 by Motor Head.
- stonemaster
21 Jan 2011 07:59
that a good one, its colored, the FSMs all are in black and white only
- Motor Head
21 Jan 2011 08:03 - 21 Jan 2011 08:15
And this has the contacts as the Ignition switch is in different positions, with the wire colors.
Also looking you should have a starter lock out switch, that means that the clutch lever needs to be pulled in to have the starter button supply power to the solenoid. Its at the back of the lever perch, two black wires coming of, 1 from the start button, then the other down to the solenoid.
Last edit: 21 Jan 2011 08:15 by Motor Head.
- nads.com
21 Jan 2011 08:38 - 21 Jan 2011 08:46
ohm test the coils, if you have power to them and they are grounded and no spark at the points, someone left the ignition on and the coils are FRIED COOKED
BURNT TOASTED.
ROASTED.
SCORCHED
SEARED
MELTED
INCINERATED
welcome to thermal breakdown.
Poke each coil in the middle with your finger.
If you hear a short raspy cough come out of the coil, and it emits a small whisp of smoke they're gone, bury them properly in the back yard and seek counciling, (couple whisky shots).
OR
I'm up too early again today. :blink:
BURNT TOASTED.
ROASTED.
SCORCHED
SEARED
MELTED
INCINERATED
OR
Last edit: 21 Jan 2011 08:46 by nads.com.
- nads.com
21 Jan 2011 08:48
Also looking you should have a starter lock out switch, that means that the clutch lever needs to be pulled in to have the starter button supply power to the solenoid. Its at the back of the lever perch, two black wires coming of, 1 from the start button, then the other down to the solenoid.[/quote
Is that a pic of a tape worm race?
- stonemaster
21 Jan 2011 09:09 - 21 Jan 2011 09:12
ohh no the dreaded lockout switch, i forgot about that, thank god I dont have one of those :S
tapeworm race, Funny :laugh:
Last edit: 21 Jan 2011 09:12 by stonemaster.
- bgmrc
21 Jan 2011 09:30
^^HAAAA
ANYWAY I NEED TO BE PULLING IN THE CLUCH TO GET THIS WORKIN??? REALLY??
OK THAT COULD BE PART OF THE PROBLEM FOR SURE..ILL PULL IT IN...THEN CHECK WIRES IF NOTHING GOES ON WITH CLUCH LEVER IN
THANX FOR ALL ADVICE!!
- TeK9iNe
- What did you do!?!
21 Jan 2011 09:36
Please... stop yelling. :laugh:
Check my avatar...
Check my avatar...
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- stonemaster
21 Jan 2011 09:39
MAYBE HIS HEARING AID HAS AN ELECTRICAL PROBLEM AS WELL :woohoo:
