spark plug coils
- kz1k
- You Cant Fix Stupid!
spark plug coils
14 Sep 2010 06:52 - 14 Sep 2010 06:53
ok well the bike that was given to me came with only i coil i guess you would call it...the thing that has 2 wires and 2 spark plug boots. i have a 81 yamaha maxim coil. can i use that just get it started until i buy 1? sorry if my terminology is wrong....first bike build.
1978 KZ1000A2
Last edit: 14 Sep 2010 06:53 by kz1k.
- otakar
Re: spark plug coils
14 Sep 2010 07:03
First of all, you should fill out your profile indicating what bike you have or please do so when you ask a particular question. Coils changed from bike to bike and year to year. Very few of them are interchangeable. Also it will depend on what ignition is in the bike. I doubt very much that the coil from the Yamaha will work. Coils have different internal resistances and must be matched with the ignition.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- kz1k
14 Sep 2010 07:15
ok, thanks and im on top of filling out my profile.
1978 KZ1000A2
- otakar
14 Sep 2010 07:27
Make sure that it is a 78 and not a 77. If the bike is made in July it might be a 77. Give us the VIN and I can look it up in my book. If you wish you can PM me the VIN if you don't want to advertise it.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- Motor Head
14 Sep 2010 07:32
He has a clear shot of his tag on the steering head, VIN # is clear, KZT00A-030869 7/77
- kz1k
14 Sep 2010 08:00 - 14 Sep 2010 08:02
here you go guys. if your on the bike, i have the left coil pack and wires. i am missing the right 1. where can i get one?
how is the firing order on these? is the lefrt coul 1 and 2 or 1 and 4?
1978 KZ1000A2
Last edit: 14 Sep 2010 08:02 by kz1k.
- kz1k
14 Sep 2010 08:01
1978 KZ1000A2
- trianglelaguna
14 Sep 2010 08:08
that is a dyna coil and you most likely would need to search e-bay for a matcher...they do sell by them selves sometimes....someone here might donate or sell you one...or you could go and try and score a set of stock coils for cheaper.....you may want to remove the timing cover on the right(as you sit) smaller side of the engine...often folks will run an after market ignition and rotor and a picture will help big time for folks to steer you towards getting the rights coil/coils....a picture inside the timing cover should be your next move imo....
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
2003 ZX12R
2007 FZ1000
- kz1k
14 Sep 2010 08:13
trianglelaguna wrote:
not sure where the timing cover is...right side...where exactly..lol, sorry. my roomate is the one that helps me work on this. he knows more about bikes, but hes at work.....ill take a pic if i can figure out where it is.that is a dyna coil and you most likely would need to search e-bay for a matcher...they do sell by them selves sometimes....someone here might donate or sell you one...or you could go and try and score a set of stock coils for cheaper.....you may want to remove the timing cover on the right(as you sit) smaller side of the engine...often folks will run an after market ignition and rotor and a picture will help big time for folks to steer you towards getting the rights coil/coils....a picture inside the timing cover should be your next move imo....
1978 KZ1000A2
- TeK9iNe
- What did you do!?!
14 Sep 2010 08:14 - 14 Sep 2010 08:18
Considering the look/condition of that coil, and the importance of ignition. I would pick-up a "set" of coils.
If that bike is a 78/79, then it has points style ignition and you can use these:
Heres the link: Z1 Enterprises
They're not very expensive for coils, and will work just fine and save you headaches and guessing in the future.
If the bike ignition has benn modified (Dyna S, etc.), then you can still use these coils, but a better match would be a new set of Dyna coils, but they start @ $140.
Good luck.
PS. THE VERY FIRST THING you need is a good service manual before you buy anything else! Part of regular maintenence absolutely required for these machines is to remove the valve cover and check the valve-to shim gap on the cylinder head. There is a huge maintenence chapter that must be completed before attempting to move the bike into service.
Good luck.
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
Last edit: 14 Sep 2010 08:18 by TeK9iNe.
- otakar
14 Sep 2010 08:17 - 14 Sep 2010 08:21
No eBay APP ID and/or Cert ID defined in Kunena configurationWhat kind of ignition do you have? Look under the right points cover and post a picture. This is a 3-Ohm coil and I am presuming that someone has already took the time to install a Dyna ignition. Here is a brand new matching coil to yours. the price is pretty good because you do not have to buy two of them.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Last edit: 14 Sep 2010 08:21 by otakar.
- TeK9iNe
14 Sep 2010 08:19
otakar wrote:
Most likely...
Ignition/points cover on right side of engine, while seated on bike. Has 2 bolts only.
GL.
Most likely...
GL.
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
