spark plug coils
  • kz1k
  • kz1k's Avatar Topic Author
  • You Cant Fix Stupid!
Re: spark plug coils
14 Sep 2010 12:27
#398667
i talked to a tech at kz1. he said that the xj maxim coil should work. so i will give it a shot.
1978 KZ1000A2
  • TeK9iNe
  • TeK9iNe's Avatar
  • What did you do!?!
14 Sep 2010 13:48 - 14 Sep 2010 13:49
#398684
If the coil from the Maxim is too low ohms, it will blow/burn out the Dyna S ignition, and then you'll be paying for both $$$!
MAKE ABSOLUTELY SURE that any coil you use has an input side impedance of 2.8 ohms or greater.
Remember trust, but verify. Check the coil first, then proceed. Just cause a guy says "yeah, it SHOULD work", doesnt mean "YES, I designed this coil for this application". :laugh:
GL.
B)
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
Last edit: 14 Sep 2010 13:49 by TeK9iNe.
  • loudhvx
  • loudhvx's Avatar
14 Sep 2010 15:49
#398712
Oops, I should have said it's a Dyna III, not Dyna S. But they do use the same coils as the one you have.
  • otakar
  • otakar's Avatar
15 Sep 2010 06:08
#398833
kz1k wrote:
heres whats behind the cover. what am i looking for?
I notice that the plate is mounted in full "retard". I would remove the plate and check that the mechanical advancer is working properly, and than mount the plate using a timing light. this will insure proper ignition timing.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
