spark plug coils
  • kz1k
  • kz1k's Avatar Topic Author
  • You Cant Fix Stupid!
Re: spark plug coils
14 Sep 2010 09:21
#398629
thanks tek
1978 KZ1000A2
  • TeK9iNe
  • TeK9iNe's Avatar
  • What did you do!?!
14 Sep 2010 09:33
#398631
kz1k wrote:
thanks tek
I think I can speak for most in saying that we love bikes, and being able to help out others.
Your most valuable purchase will deffinately be the service manual. It will save you $$$ and huge headaches/time.
Go through and clean up all the wiring/component electrical connections. Make sure they're shiney and tight like new, especially grounds.
Best of luck.
B)
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
  • kz1k
14 Sep 2010 09:55
#398639
i have a bike salvage in my area. i have to call back in a hour so he can look. fingers crossed....fair price and working.
1978 KZ1000A2
  • kz1k
14 Sep 2010 10:17
#398643
i would buy a new 1, but i need to know if this motor even runs. so my main objective is to get it ready to start up without spending a butt load. once she fires up...then ill dig a lil deeper in my pocket.
1978 KZ1000A2
14 Sep 2010 10:51
#398649
Looking at the condition of the engine, for example - no carbs, I would think a manual would save you money and frustration in trying to get it running. I don't know of anyone who has regretted buying a Kawasaki factory service manual. Good luck. Ed
  • MFolks
  • MFolks's Avatar
14 Sep 2010 10:54
#398652
Looks like the bike was dropped on the right side and slid for a distance.
This will help in wiring the ignition coils:
Ignition Coil Primary And Secondary Wiring
Ignition coils on the 80’s Kz1000,Kz1100’s and Gpz1100’s are wired the same, that is as you sit on the bike, the LEFT ignition coil primary(small wires) are two wires, RED and BLACK. The secondary (or sparkplug wires) go to #1 and #4 sparkplugs.
The cylinders are numbered left to right as you sit on the seat; #1,#2,#3, and #4.
For the RIGHT ignition coil, the primary wires, again are two wires, RED and GREEN, with the secondary going to #2 and #3.
The RED wire gets it’s voltage from the run/stop switch on the right handlebar switch pod.
The BLACK and GREEN wires connect to the IC Igniter(if the bike has the Kawasaki supplied electronic ignition) it actually gives the coils their grounds to fire the sparkplugs.
Primary(small wires) side of the coils will read between 1.8 to 3.0 ohms.
Secondary(sparkplug wire ports)side of the coil will read between 10.4K to 15.6K ohms.
To stress the ignition coils, take a hair dryer, heat the coils and see if the ohm readings change from cold to hot . If they do, it’s time to buy new coils.
Keep in mind, the wiring is reversed for the 550’s 650‘s and 750‘s, that is the RIGHT coil primary will be two wires, RED and BLACK with the secondary(sparkplugs) going to #1 and #4.
The LEFT coils primary wiring would be again two wires, RED and GREEN, with the secondary(sparkplugs) going to #2 and #3.
These engines have what is known as a “Wasted Spark” that is, a sparkplug will fire during an exhaust stroke. It does no damage and many other motorcycle engines have this design.
14 Sep 2010 11:05 - 14 Sep 2010 11:07
#398654
kz1k wrote:
ok well the bike that was given to me came with only i coil i guess you would call it...the thing that has 2 wires and 2 spark plug boots. i have a 81 yamaha maxim coil. can i use that just get it started until i buy 1? sorry if my terminology is wrong....first bike build.
If the Yamaha coil has two spark plug wires, it might suffice temporarily, provided resistance measures 3~4 ohms between primary terminals on the coil.
This should match close enough to the green 3 ohm Dyna coil.
This resistance measurement will require an ohmmeter capable of measuring 3~4 ohms.
The coil's primary terminals are where the two small wires attach to the coil.
Measure ohms between the primary terminals.
Good Fortune! :)
Last edit: 14 Sep 2010 11:07 by Patton.
  • kz1k
14 Sep 2010 11:05
#398655
no luck on the salvage yard. he had a red one that is 1.5 ohm he said. oh well, back to the search.
1978 KZ1000A2
14 Sep 2010 11:12
#398657
If needed, perhaps resistance of the Yamaha coil could be measured for you at the salvage yard.
(Ask about carbs at the same time.)
Good Fortune! :)
  • kz1k
14 Sep 2010 11:28
#398658
Good Fortune! :)
yeah lemme do some reseach. if i can use it just to turn the motor and get it to run ill be happy temperarilly.
1978 KZ1000A2
  • TeK9iNe
  • TeK9iNe's Avatar
14 Sep 2010 11:51
#398661
Good Fortune! :)
So... I take it that the bike does have carbs then, an you just have them off for a cleaning???
:huh:
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
  • kz1k
14 Sep 2010 12:08
#398663
oh yeah i got carbs. they are locked up. theres a thread i started on them in the carb section.TeK9iNe wrote:
Good Fortune! :)
:huh:
1978 KZ1000A2
