spark plug coils
  • trianglelaguna
  • trianglelaguna's Avatar
Re: spark plug coils
14 Sep 2010 08:20
#398608
my brand new set that never got used in the box cost me 70 bucks...single dynas go for 20-40...
TeK9iNe wrote:
Considering the look/condition of that coil, and the importance of ignition. I would pick-up a "set" of coils.
If that bike is a 78/79, then it has points style ignition and you can use these:
Heres the link: Z1 Enterprises
They're not very expensive for coils, and will work just fine and save you headaches and guessing in the future.
If the bike ignition has benn modified (Dyna S, etc.), then you can still use these coils, but a better match would be a new set of Dyna coils, but they start @ $140.
Good luck.
B)
PS. THE VERY FIRST THING you need is a good service manual before you buy anything else! Part of regular maintenence absolutely required for these machines is to remove the valve cover and check the valve-to shim gap on the cylinder head. There is a huge maintenence chapter that must be completed before attempting to move the bike into service.
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
  • otakar
  • otakar's Avatar
14 Sep 2010 08:23 - 14 Sep 2010 08:25
#398610
If you already have a Dyna coil in the bike I would stay with that. They have about double the output voltage of the stock coils.
Edit
I found that Z1E has the single coil cheaper, even with the postage
www.z1enterprises.com/detail.aspx?ID=2092
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
Last edit: 14 Sep 2010 08:25 by otakar.
  • TeK9iNe
  • TeK9iNe's Avatar
  • What did you do!?!
14 Sep 2010 08:25 - 14 Sep 2010 08:25
#398611
Yeah, I got that price wrong... for a pair on Z1E its $126, but can be found eBay, small shops, etc. for less or individually.
B)
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
Last edit: 14 Sep 2010 08:25 by TeK9iNe.
  • trianglelaguna
14 Sep 2010 08:27
#398613
no they are expensive...but deals can be had if ones patient or even lucky...they are like 112-40+ though through a shop....
1976 KZ900
2003 ZX12R
2007 FZ1000
  • otakar
  • otakar's Avatar
14 Sep 2010 08:29
#398614
single Dyna coil at Z1E is $65
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
  • kz1k
  • kz1k's Avatar Topic Author
  • You Cant Fix Stupid!
14 Sep 2010 08:29
#398615
wow you guys are a lot of help. i think i will stay with the dynas. i will look for the timing cover and take a pic.....
1978 KZ1000A2
  • kz1k
14 Sep 2010 08:32
#398616
where is the cover?.......also the coils...are they all the same? or so i need to buy a specific one for the right side?
1978 KZ1000A2
  • TeK9iNe
  • TeK9iNe's Avatar
14 Sep 2010 08:35
#398620
Coils are the same.
The cover is on the bottom right side of your pic, the one with 2 screws/bolts and DOHC stamped on it.
GL.
B)
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
  • kz1k
14 Sep 2010 08:42
#398621
heres whats behind the cover. what am i looking for?
1978 KZ1000A2
  • loudhvx
  • loudhvx's Avatar
14 Sep 2010 08:51
#398624
Yup. That's a Dyna S, which explains why you have the green Dyna 3-ohm Coils.
  • kz1k
14 Sep 2010 09:05
#398626
ok then i need 1 dyna coil....are all the couls universal? do i need a specific one for the right side of the bike if sitting on it?
1978 KZ1000A2
  • TeK9iNe
  • TeK9iNe's Avatar
14 Sep 2010 09:16 - 14 Sep 2010 09:20
#398628
As said... coils are the same when sold in pairs, or individually, no matter what side they're used on. You need the green Dyna 3 ohm coil, to match the other
B)
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
Last edit: 14 Sep 2010 09:20 by TeK9iNe.
