Coil Mod: Why it’s Not a Recommended Solution
  • Old Man Rock
  • Old Man Rock's Avatar Topic Author
23 May 2010 11:27 - 23 May 2010 11:55
#370182
I was asked to do a technical write up on this subject matter awhile back and well, just have been lazy I guess, no other excuse.
Unfortunately once again, the Coil Mod has raised its ugly head and thus given me the motivation to getting it done…
I’ll try and not go into in-depth theories of applied science thus boring everyone to death and keep it concise and easy to follow…
Let’s start with this statement….
This is not a personal attack on anyone or any service for as I have researched into it’s conceptual development on the web, this coil mod concept was designed many moons ago back in the 70’s and most likely developed for racing KZ’s where a lot of the electrical system was removed and an ignition switch, lights, turn-signal/hazard relays, brake light switches etc… were no longer required. They only had to get through the race and not for every day street rides.
Now considering these old racings KZ’s also were fitted with large carbs, performance port & polished heads, performance camshafts, 4-1 exhaust etc… Jetting was a PITA between races! Pending elevations, outside temperatures, air densities, internally developed temperatures etc… Carboned fouled plugs during a race not good… With that said, every amount of voltage/current that could be obtained went directly to the coils and ignition components.
Does it work: Yes but not without flaw….
The complete pdf file with further explanations, wiring diagrams, recommended solutions available here...
Here's what you gain in repairing correctly:
All electrical system charging components, lighting and ignition system (coils, EI modules, points, condenser) operations are to specification, no other way to look at it!... ;)
kzrider.com/index.php?option=com_docman&...d&gid=479&Itemid=108
Hope this helps put this to rest once and for all...
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
Last edit: 23 May 2010 11:55 by Old Man Rock.
The topic has been locked.
  • trianglelaguna
  • trianglelaguna's Avatar
Re: Coil Mod: Why it’s Not a Recommended Solution
23 May 2010 12:32
#370200
you know i dont modify stuff much...i prefer em running...the way they were for yrs and yrs...coil mod....oh you mean toal loss ignition...why would i want that unless it was for track days :huh:
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
  • trianglelaguna
23 May 2010 14:13 - 23 May 2010 14:15
#370232
twerp..............
1976 KZ900
2003 ZX12R
2007 FZ1000
Last edit: 23 May 2010 14:15 by trianglelaguna.
  • otakar
  • otakar's Avatar
23 May 2010 14:24
#370241
Guys- Now tell me- Why are we doing this again. Hasn't this warn itself a bit thin for the technical columns? The Rock has finally contributed something constructive and this happens again? ;)
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
  • Old Man Rock
23 May 2010 14:32
#370244
Don't sweat it Otto...B)
Let them have some fun with it for regarding this subject matter and how the other postings always turn out... yeah have some fun with it no doubt.
And BTW, WTF you mean "finally contributed something constructive"... :angry: Bastard... :laugh: :laugh:
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
  • mark1122
  • mark1122's Avatar
  • Keep twisting it
23 May 2010 14:47
#370250
Great write up Dave. i agree 100%. B)
why wire AROUND the problem, when u can fix it right.
I'm not up on Donkey's, but i have seen a few A$$'s .:P
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
  • Old Man Rock
23 May 2010 14:56 - 23 May 2010 14:58
#370254
Almost forgot about this as well....
Electrical Theory of KZ systems...
I’m writing this for nothing more than to possibly help those that don’t have a well balanced knowledge/understanding of the KZ electrical system…
As you will learn, it’s truly not that difficult once you understand the basic principles and applied theories of science associated with all electrical/electronics.
NOTE: This write up is not an electrical troubleshooting guide for that can be covered at a later time but it is designed for educating those who wish to learn a little and obtain a better understanding of what is occurring in their “Colored Spaghetti” wiring diagrams….
Let’s start with some basic electrical formulas and applied science then head into what it all means in our beloved KZ’s….
I’ll try and keep it basic as possible…
kzrider.com/index.php?option=com_docman&...d&gid=463&Itemid=108
See, truly not that difficult.... ;)
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
Last edit: 23 May 2010 14:58 by Old Man Rock.
  • richard head
  • richard head's Avatar
  • Banned
  • Banned
23 May 2010 18:03
#370321
My KZ has the coil mod done and it works fine ! Sure makes things simple.
  • larrycavan
  • larrycavan's Avatar
23 May 2010 19:48
#370352
Dave..... You forgot to include your TESTED by OMR logo...
  • hardr0ck68
  • hardr0ck68's Avatar
  • Who put the what in the where?
24 May 2010 05:16
#370402
coil mod made my bike run noticeably better... and I have zero interest in going through the spaghetti tangle of my wire harness to do it the OMR way only to get the same results.
Maybe it's a short cut, but it works.
1977 kz650 c1
bought it because I was told it would never run again...I like to prove people wrong.
  • otakar
  • otakar's Avatar
24 May 2010 05:30 - 24 May 2010 05:31
#370404
"spaghetti Tangle"? It's only ONE wire, Red/Yellow in most situations. Two wires if you count the ground from the points. That is the only wire you have to worry about. :dry:
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Last edit: 24 May 2010 05:31 by otakar.
  • Old Man Rock
24 May 2010 05:36
#370405
Some of you may be missing the main point here... It's not the same results...
You installed this coil mod due to either low voltage, carboned plugs or a combination of both.. correct?
Yes, in installing the coil mod you now have battery voltage to your coils no doubt, yes...?
But since the rest of your electrical system is terminated to the same original brown conductor off the ignition switch, you most likely are still under rated in your other electrical system components, lighting, and more importantly the feed back to the regulator thus charging system...
That's the point of the article!
Your coils received the desired results but the rest of your system is still suffering and under rated...
And that my friends is why it's deemed a band aid and not truly a repair...
If your going through all the trouble of installing this relay and re-routing conductors, why not do the same regarding new conductors to the ignition switch, kill switch, to the coils... Now the rest of your system is up to spec as well...
Ah well, if you're happy with using the mod, good for you.
OMR
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
