Headlight conversion HID? Halogen?
  • otakar
  • otakar's Avatar Topic Author
Re: Headlight conversion HID? Halogen?
03 Jan 2011 03:58
#419847
I order them in lots of 24 from an overseas manufacturer. They are clear lens with a faceted mirror and designed with a specific dispersion pattern for me.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
  • mtbspeedfreak
  • mtbspeedfreak's Avatar
03 Jan 2011 23:40
#419990
If they are the round 7" ones for a Z1/KZ, would you consider parting with one in about a month???
2000 ZRX 1100
1976 KZ 900- Daily Driver
  • otakar
04 Jan 2011 03:31 - 04 Jan 2011 03:33
#420001
Sure, I also make complete kits with everything you need including the hi-voltage extension cable to put the ballast under the seat.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Last edit: 04 Jan 2011 03:33 by otakar.
  • mtbspeedfreak
10 Jan 2011 18:06
#421334
Just sent you a PM, thanks!
2000 ZRX 1100
  • Bugeater
  • Bugeater's Avatar
26 Jan 2011 06:57
#425653
Hello all - first post!
I was wondering if there is a contact or url that I can check out regarding the kit with extended wiring for underseat installation. Very Interested. I just procured a 75 Z1B Turbo bike that I would like to bring into this century technologically in some respects and this is one area I would like to address. I sent our man a PM, but he may not see these that frequently so figgured I would ask the congregation if I missed a link to a site or ??? that sells otakar's kits!!!
Much appreciated,
John
75 Z1B Turbo...
1327cc Wiseco 10.25:1
Mr. Turbo (Mikuni 42mm HSR draw through setup)
Dyna 2000 controller with their miniature series 3ohm coils
74 Z1A 1105cc...
  • otakar
26 Jan 2011 18:16
#425879
Please do not mistake LED for HID. They are two completely deferent things.There are some LED systems around, I believe BMW has them available in some of their top of the line sedans as an option.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
  • tooocool49723
  • tooocool49723's Avatar
26 Jan 2011 18:51 - 26 Jan 2011 18:53
#425894
I think he means extended leads to the bulb from the ballast so that he can mount the ballast under the seat. Could be wrong though.
(I just didn't see anything about LED's in his post)
'82 KZ550 "Project"
First bike, 30k miles
Ann Arbor, Mi
Last edit: 26 Jan 2011 18:53 by tooocool49723.
  • otakar
27 Jan 2011 03:22
#426027
He sent me a PM asking about LED. I just wanted to clarify.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
  • Tested
  • Tested's Avatar
07 Aug 2011 04:33
#467405
Afrosemite wrote: There's always the possibility of spending $300 and going LED
www.truck-lite.com/webapp/wcs/stores/ser...ctId=64057&langId=-1
We had those in Iraq and they were horrible. They looked cool but only worked on high-beam. Of course I had 16 lights on my truck. We had a route clearance light kit. We also had some super bright lights from KC that could shine miles. You could not drive at is with those lights on. Awe the good ole days.
Anyways, I was unimpressed with the LED headlights.
2008 KLR 650
1977 KZ 750
_____ Have had _____
1981 KZ 440
1970's CR 125
1982 KLX 175
  • otakar
07 Aug 2011 09:05
#467421
I think that BMW has had some problems with them also. I am not sure if they still offer them on their hi end cars.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
  • otakar
07 Aug 2011 11:39
#467454
For the HID you have to make sure that your Battery, alternator, regulator , and rectifier are in good working condition. If there is too much voltage deviation or the current is not properly rectified the ballast will shut itself off.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
  • Tested
  • Tested's Avatar
07 Aug 2011 12:48
#467468
@otakar - Just because she breaks down every other day doesn't mean that when does show up she doesn't put in work. Grin.
I will get a voltmeter and check to see. I am thinking of just running it direct from the battery to the headlight and avoiding the whole problem. Maybe through an inline fuse in it.
Can I get a price and time for a 7" HID kit from you.
2008 KLR 650
1977 KZ 750
1981 KZ 440
1970's CR 125
1982 KLX 175
