Headlight conversion HID? Halogen?
- otakar
Re: Headlight conversion HID? Halogen?
22 Feb 2010 05:27 - 22 Feb 2010 05:32
Afrosemite wrote:
Those are definetly interesting. When the price comes down like it has come down on the HID, they will be in the running. I remember when just a bulb for an HID was well over a hundred dollars. OEM HID bulbs still sell for around $75+ each. Did you also notice that they are I.T.A.R. controlled. I remember when IIT had an I.T.A.R. violation about 2 years ago. It cost them something like $50,000,000 in fines. :blink: Where i was employed, we had to have I.T.A.R. training once a year and our computers were checked weekly for violations.
www.pmddtc.state.gov/regulations_laws/itar.html
There's always the possibility of spending $300 and going LED
www.truck-lite.com/webapp/wcs/stores/ser...ctId=64057&langId=-1
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Last edit: 22 Feb 2010 05:32 by otakar.
- otakar
24 Feb 2010 14:22
I just did an interesting illumination test today. Using the proper reflector, one with the faceted mirror instead of one with the diffused lens, we tested both a Halogen bulb and a HID system. What we found was that the HID was better focused than the Halogen. This meaning that if the light is properly adjusted, the blinding affect should be less with the HID than with a 90W Halogen. This coming back to the fact that with common sense and care HID will give better quality light than Halogen. Once again stating that the original reflector must not be used.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- otakar
28 Feb 2010 18:10
I just had some Hi-Voltage extensions made up for the Hid systems so that the ballast can be mounted under the seat or under a sidecover for those applications that do not have the room to mount it tastefully in or near the headlight.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- atye
01 Mar 2010 08:03
www.kbcarstuff.com/Xenon_HID_Headlamps_s/43.htm
This site has some DOT approved (LEGAL!) Bi-Xenon conversions for 7" round and 200mm rectangular sealed beam headlamps. The Bi-Xenon lights use a single D1S bulb and an electro-mechanical shutter to switch between high and low beam functions.
I'm not endorsing these lights or anything, I'm just showing that there are some legal alternatives that should provide a good beam pattern and upgraded light output at the same time.
1979 Kawasaki LTD1000 B3
Kerker 4-1 exhaust
Stock airbox
VM26SS carbs (115 main/17.5 pilot)
Corbin Gunfighter seat
Dyna-S ignition
Kerker 4-1 exhaust
Stock airbox
Dyna-S ignition
- otakar
01 Mar 2010 09:14 - 01 Mar 2010 09:16
Boy, those guys aren't cheep, are they! Mine are a third of what they ask. Plus mine come with the LED City-light. If you get technical they still aren't legal because your bike did not come with them. Just like mine. My 6x7 are also DOT rated.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Last edit: 01 Mar 2010 09:16 by otakar.
- atye
01 Mar 2010 10:40
otakar wrote:
You're kidding, right? They are legal if you use a DOT/SAE approved headlight assembly. Does that mean that changing a factory round to factory rectangular sealed beam headlight using factory parts would not be legal just because it "did not come with them"?
Also, your "DOT rated" headlamps are not DOT rated the minute you modify them. The original unit was submitted for inspection and measurement as it was designed and manufactured. You are modifying that design and therefore negating the DOT approval.
Again, not busting anyone's balls here. Just trying to keep the readers informed of both sides of the coin.
Kerker 4-1 exhaust
Stock airbox
Dyna-S ignition
Kerker 4-1 exhaust
Stock airbox
Dyna-S ignition
- otakar
01 Mar 2010 12:08 - 01 Mar 2010 13:04
Now take that statement and apply it to the entire bike. What do you get when you make any modification to your bike. A non DOT rated vehicle. :woohoo: I talked to one of my friends the other day who is a Cop. As he put it; they don't enforce it because they would have to stop 25% of the cars on the road, but vehicles are only legal as they come from the factory. No oversize tires no after-market exhausts no tinted windows. You are even suppose to update your registration when you change the color of you vehicle. YES if he wanted to he can site for that. It is at the discretion of your local constabulary, how much they want to harass you (or not).
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Last edit: 01 Mar 2010 13:04 by otakar.
- atye
01 Mar 2010 12:16
otakar wrote:
atye wrote:?
Touche'
Good point.
Kerker 4-1 exhaust
Stock airbox
Dyna-S ignition
Kerker 4-1 exhaust
Stock airbox
Dyna-S ignition
- otakar
01 Mar 2010 13:00 - 01 Mar 2010 13:02
I believe that is where this post got some time ago. The question is; HOW ILLEGAL IS YOUR BIKE? Sort of like asking; how pregnant did you get your girlfriend???? :laugh: :woohoo: A lot or just a little???
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Last edit: 01 Mar 2010 13:02 by otakar.
01 Mar 2010 13:30
otakar wrote:
At $490.00 for 1 light bulb they should have a 30 year replacement warranty. Unfortunately, I didn't see any warranty info in the ad. I just imagine the joy I would feel if I bought one and it blew out after a couple months. :woohoo:
- atye
01 Mar 2010 13:33
650ed wrote:
The bulb is replaceable (D1S). You are not paying $490 for "1 light bulb"... You are buying a replacement headlamp system.
Try replacing a headlamp assembly (just one side) on any BMW with Xenon headlamps. Some will run you over the $1000 mark easily... Per side!
otakar wrote:Boy, those guys aren't cheep, are they!
Kerker 4-1 exhaust
Stock airbox
Dyna-S ignition
Kerker 4-1 exhaust
Stock airbox
Dyna-S ignition
- mark1122
- Keep twisting it
01 Mar 2010 13:45
I just got my headlight Otto. Thanks.
Have u used a plastic lens before? I am a little worried it will scratch easily, especially when trying to get dryed bugs off of it.
is there any way to tell if the headlight alignment tabs on its back are going to have the right placement for the bracket,before u buy it? this 1 does not align with my bracket. it may have to do with it being for a car rather than a motorcycle?
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
