Headlight conversion HID? Halogen?
- otakar
Re: Headlight conversion HID? Halogen?
18 Feb 2010 08:46
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- mark1122
- Keep twisting it
18 Feb 2010 08:57 - 18 Feb 2010 08:58
Why do they supply an h4 bulb for high beams, and an HID for low, not the other-way around? what size is the h4?
would it be acceptable to remove the shield, and rewire to use the HID for hi, and the h4 for low beam?
i just cant see using poor lighting, for night time running lights? i would like better lighting when people and cars are around and great lighting when they are not.
any other options?
any other options?
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Last edit: 18 Feb 2010 08:58 by mark1122.
- atye
18 Feb 2010 09:07
otakar wrote:
A couple of clarifications to the information above, if I may.
1) The headlamp unit in the picture above uses a clear, smooth lens and a multi-faceted reflector. The reflector itself does the job of focusing the light, true. In the headlamp unit that I showed a few posts up, it has a diffused lens and a smooth reflector, the opposite. In it's case, the lens itself focuses the light. They both do the same thing and the beam pattern for the same H4 bulb would be very, very similar. Companies started making the clear lens models for styling purposes, nothing more. For example, Hella has done the same with the popular 500 Series lamps. They are now offered in a clear lens "FF" or "Free-Form" version alongside the classic style. See the image below for a visual comparison. The light output is nearly identical.
2) 65W bulbs do not draw anywhere near 10-11 amps unless your wiring is totally degraded. Using the most basic formula in electronics, Ohm's Law (Amps=Watts/Volts), a 65W bulb in a 12V system will draw 5.41A. If anyone's system draws more than say, 6A with a 65W bulb, check all of the ground wires for corrosion and consider using a new relay to bypass the old stock wiring to the headlight. Excess amperage not only sucks your limited available power but creates a lot of heat and can cause serious wiring problems such as melted wires.
That is the yipe of reflector you do NOT want to use with the HID conversion. The faceted lens works as a diffuser for the light instead of focusing it. The reflector you want to use is the one in my picture.
This will compare to about 10A to 11A with conventional bulbs on your bike with a 65W headlight and an ADDITIONAL 2A if you run a 90W headlight.
1979 Kawasaki LTD1000 B3
Kerker 4-1 exhaust
Stock airbox
VM26SS carbs (115 main/17.5 pilot)
Corbin Gunfighter seat
Dyna-S ignition
Kerker 4-1 exhaust
Stock airbox
Dyna-S ignition
- otakar
18 Feb 2010 09:47 - 18 Feb 2010 11:042) 65W bulbs do not draw anywhere near 10-11 amps unless your wiring is totally degraded. Using the most basic formula in electronics, Ohm's Law (Amps=Watts/Volts), a 65W bulb in a 12V system will draw 5.41A. If anyone's system draws more than say, 6A with a 65W bulb, check all of the ground wires for corrosion and consider using a new relay to bypass the old stock wiring to the headlight. Excess amperage not only sucks your limited available power but creates a lot of heat and can cause serious wiring problems such as melted wires.
Please read the whole post. Compare apples to apples. I said what the "System Draws" not what just the headlamp draws. This includes EVERYTHING in the LIST. Yes we all know that 65w/12v=5.42a
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Last edit: 18 Feb 2010 11:04 by otakar.
- otakar
18 Feb 2010 09:52
Also there is an enormous difference between a reflected beam and a refracted beam. A reflected beam is intensified but a refracted beam is scattered.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- bountyhunter
18 Feb 2010 11:03 - 18 Feb 2010 11:03
atye wrote:
I mantion the light mods are illegal for an obvious reason: as stated, they make the lights brighter and therefore, are immediately obvious to cops. I never see anybody get written up for headers unless they run without the baffle and break somebody's eardrums. Bright lights are particularly dangerous because they can seriously blind you if they are adjusted wrong.
otakar wrote:
As I said before; much of the stuff we talk about here on this web sight is not legal, because it is not DOT approved. Why should this be any different. Would this be any deferent if we talked about the header that most all of us have on our bike that is not legal. :S
The main difference is that the headlights are one of THE most importantsafety
items on a vehicle and they have the potential to affect other drivers in a negative way (ex: blinding them). Performance mods like exhaust and cams and such do not have the same potential.
No hard feelings here, I'm not trying to step on anyone's toes, I promise. I guess that because I work for a major lighting company this topic is important to me and it seems that a lot of the general public do not know all of the facts about the subject.
Last edit: 18 Feb 2010 11:03 by bountyhunter.
- otakar
18 Feb 2010 11:09
I have never seen anyone get written up for headlights unless they had one burned out. Those citations are very common. I personally know quite a few people who did the HID conversion in older vehicles and they have never been stopped for that violation. But we all know that; "Life is known to cause cancer in the state of California" :laugh:
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- WABBMW
- Let The Good Times Roll !
18 Feb 2010 11:14
Hello Headlight Experts:
A relative gave me all the components for a 35 Watt Zenon HID light system, except for the glass enclosure or headlight itself. Included, is the ballast, wiring, plugs, the lamp itself, etc.
My '82 KZ650 still has the original 7" round sealed beam bulb. Therefore I need to buy the glass headlight housing that will accept the new H4 style bulb. What particular type or style do you guys recommend? Where should I buy this? I would like it to look as much like the original as possible, with a convex front surface.
Another thing about this system, is that the lamp itself switches from low to high by physically moving a section for and aft within the bulb. Therefore I do not anticipate needing any other bulb arrangement.
Please advise. Thanks.
Bill Baker
Houston, Texas
1982 KZ650 CSR
2008 Yamaha FZ1
2006 Yamaha FZ1
1977 Honda Supersport 750 four (sold)
1984 Honda Nighthawk 650 (sold)
Houston, Texas
1982 KZ650 CSR
2008 Yamaha FZ1
2006 Yamaha FZ1
- bountyhunter
18 Feb 2010 11:21 - 18 Feb 2010 11:22
otakar wrote:
Kali cops do it to hassle cruisers (both cars and bikes) who cruise in groups and annoy people. They completely check the vehicles and write up everything that isn't street legal or stock legal. In kali, just about any light/intake/exhaust mods are illegal unless the units are submitted to the state for testing and certification. In reality, the only things that will get caught are things that are obviously modified.I have never seen anyone get written up for headlights unless they had one burned out. Those citations are very common. I personally know quite a few people who did the HID conversion in older vehicles and they have never been stopped for that violation. But we all know that; "Life is known to cause cancer in the state of California" :laugh:
Last edit: 18 Feb 2010 11:22 by bountyhunter.
- otakar
18 Feb 2010 12:11
It is known that; "Tickets are known to cause cancer in the state of California" Or is it the Cops, I forget. :laugh:
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- otakar
18 Feb 2010 12:15
WABBMW wrote:
You require this type of reflector.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- WABBMW
18 Feb 2010 13:41
Where can I buy one of those? Also can you provide a Brand or model number? Thanks.
Bill Baker
Houston, Texas
1982 KZ650 CSR
2008 Yamaha FZ1
2006 Yamaha FZ1
Houston, Texas
1982 KZ650 CSR
2008 Yamaha FZ1
2006 Yamaha FZ1
