Dyna S DS2-1 Installation Tutorial by OMR
  • keith1
  • keith1's Avatar
Re: Dyna S DS2-1 Installation Tutorial by OMR
07 Mar 2009 15:56
#270261
timebomb33 wrote:
find and use left hand drill bits they are the bomb diggity for removing stripped out screws and if they don't quite do it try vise grips
just what i would suggest...needle nose vise grips..
if ya cant get regular ones in there...clamp em good..should work...they cant be that tight...
  • wiredgeorge
  • wiredgeorge's Avatar
07 Mar 2009 17:30
#270272
I think what I would do if a plate mount screw head was stripped would be to cut the head(s) off and remove the plate, cut a slot in the screw using a Dremel/cut off wheel and then tap it with a hand impact driver flat bladed bit.
The screws that hold these plates are M5 JIS with .8 pitch. The slots are not the same as an SAE (or metric) phillips head screw... they are frequently stripped for that reason as folks don't have JIS screwdrivers. Try a place that repairs copying machines for these screwdrivers... most are #1 or #2. The #3 screws don't strip with a #3 phillips head driver. There are no JIS impact driver bits that I have found, unfortunately.
  • keith1
  • keith1's Avatar
07 Mar 2009 18:26
#270284
grinding the head off and cutting a slot for flat
impact tip.....good advice.....i bought a dremel 2 yrs ago and it has paid for itself many times over.......
  • timebomb33
  • timebomb33's Avatar
07 Mar 2009 19:33
#270300
try using left hand bits you will be pleasently surprised
I THINK MY POWERBAND BROKE
  • dman3998
  • dman3998's Avatar
12 Jun 2009 15:46
#298643
Finally got the old girl running with the new Dyna and coils. I am surprised that Dyna keeps producing this without fixing the timing issue. I also had to slot the plate to get to the F marks. It would do it with the coils slid to the FAR left spots but as OMR said one of the screws is barely 50% on the pickups slot so not real comfortable with that. maybe not enough people have complained.
Dman
SE Idaho
"Smart only goes just so far, STUPID is UN-limited"
79 KZ1000 LTD
Honda XRL650L
Yamaha RD350B
Yamaha DT400B
  • Old Man Rock
  • Old Man Rock's Avatar Topic Author
12 Jun 2009 16:13
#298648
Well it could also be due to the difference in the timing advance unit.... Thanks Jeff @ Z1...
I also associated mine to the camshafts I installed where most of the Dyna units are probably designed are stock camshaft configurations...
No big deal, just slot her, rotate accordingly, good to go.... ;)
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
  • telefunkin
  • telefunkin's Avatar
12 Jun 2009 17:22
#298676
Question for you guys. Does the Dyna S bypass the IC ignitor?
12 Jun 2009 17:57 - 13 Jun 2009 03:32
#298686
Yes. Dyna-S signal wires route to coils. Inside module to coil firing outside plugs 1&4. Right module to other coil firing inside plugs 2&3.
Good Luck! :)
Edit -- Yes. Dyna-S signal wires route directly to coils. Under points cover, left (rearward) module wires to coil firing outside plugs 1&4. Right (forward) module wires to other coil firing inside plugs 2&3.
[Click on image for better view]
KZ650 has an additional blue wire to oil pressure switch.
Last edit: 13 Jun 2009 03:32 by Patton.
  • timebomb33
12 Jun 2009 19:48
#298727
the dyna s is a complete self contained ignition all by it's self
  • telefunkin
12 Jun 2009 20:57
#298736
Patton wrote:
Yes. Dyna-S signal wires route to coils. Left module to coil firing outside plugs 1&4. Inside module to other coil firing inside plugs 2&3.
Good Luck! :)
Sweet. I've been thinking about ordering on of these so I can clean up some of the wiring around the fuse case and battery.
in case I do upgrade, does anyone have a pair of rear foot pegs they want to trade for an igniter?
13 Jun 2009 03:30
#298761
See edit and image added in previous post.
Good Luck! :)
  • telefunkin
13 Jun 2009 18:09
#298915
Good Luck! :)
Thanks Patton, that pic clarifies things nicely. Hell, I would have been less confused if I had just seen that to begin with and not even looked at any instructions.
