Dyna S DS2-1 Installation Tutorial by OMR
- Old Man Rock
05 Feb 2009 17:59 - 05 Feb 2009 18:01
Hey all,
OK, this is a down and dirty (clean cut version) of the Dyna S installation and some of the issues and resolutions for an easy installation...
Hope it helps some others... It's truly an easy process.
OMR's tutorial:
members.cox.net/ruinsofstei/Dyna%20S%20D...ation%20by%20OMR.pdf
Dyna Installation Manual:
members.cox.net/ruinsofstei/DS2-1_2-2.pdf
The results: Sweet!
OMR
OMR's tutorial:
The results: Sweet!
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
Last edit: 05 Feb 2009 18:01 by Old Man Rock.
The following user(s) said Thank You: High-Voltage
- wiredgeorge
Re: Dyna S DS2-1 Installation Tutorial by OMR
06 Feb 2009 06:07
Dave - Good job but I want to point out a couple of things... first the smaller bolt head on your crank end is not 13mm... it is 14mm. You might want to mention for the newbie to use a socket on the 17mm nut because it is thin and most open end box wrenches will slip off and ding the 2/3 pickup (I know this for a fact hehe). Also, there is never a need to slot the back plate. The reason you could only get within 1/8" of where you need to be in timing is that they don't set the two pickups when assembling. When you can't get the timing on because the plate won't rotate far enough, loosen the LEFT pickup and move it counter-clockwise on its two little allen bolts. You will have to move the 2/3 pickup as well later to make it 180 degrees away from the 1/4 pickup. In fact, when you buy one of these things, it doesn't hurt to set up the pickups yourself before you even mount the thing rotating the 1/4 pickup counterclockwise a bit. Last, there are three different advance mechanisms (timing) for the 903/1015cc family and at least one of these doesn't reach full advance till it gets a bit past 3K rpm so the Dyna recommendation to rev the engine to 2.5K rpm to set the timing with a strobe light should be 3500 rpm instead.
- Old Man Rock
06 Feb 2009 06:19When you can't get the timing on because the plate won't rotate far enough, loosen the LEFT pickup and move it counter-clockwise on its two little allen bolts.
As I mentioned in the article, wasn't comfortable where it sat in moving the 1/2 sensor. In my testing/confirmations, the allen bolt just barely caught the end of the sensor to obtain the F amrking, made me nervous where due to vibration it may just slip out.... Henceforth, elongate the slots worked out best...
And as it turned out for me, 2/3 sensor came out dead on after the slot expansion so no need to adjust at all... As mentioned i the article, if required adjust the 2/3 sensor via the Allen head screws as dpeicted in the Dyna literature...
13mm versus 14mm...Oops, good catch, oh well, either case don't use it, use the 17mm as depicted. I used a socket versus wrench, good point as you mentioned...
As provided in the Dyna installtion manual depicts 2500rpm for timing light... Interesting! I'll contact Dyna and see i they have an update to this...
Dave "OMR"
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- Old Man Rock
06 Feb 2009 15:01NOT to USE for crankshaft rotations...13mm versus 14mm
I had thought about this off and on all day and I was sure I had this correct... I just arrived home and remeasured the smaller outside bolt head, sure enough, mine is a 13mm in size...
In either case, don't use the smaller of the two nuts as I leader lined to the correct 17mm to use as depicted.
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- dman3998
06 Feb 2009 15:36
I heard a vicious rumor that OMR was actually a really nice guy but we would not want that to get out might ruin his reputation.
thanks for the hand holding, am upgrading to the Dyna but have not got into it yet. looks like a no brain'er now.
Dman
Dman
Dman
SE Idaho
"Smart only goes just so far, STUPID is UN-limited"
79 KZ1000 LTD
Honda XRL650L
Yamaha RD350B
Yamaha DT400B
SE Idaho
79 KZ1000 LTD
Honda XRL650L
Yamaha RD350B
Yamaha DT400B
- Old Man Rock
06 Feb 2009 16:44
hahahahahahaha... Sush, don't spread that...
Seriously speaking, it truly is a no branier.... If you have problems just post and numerous ppl on this forum that have gone through the process and will be glad to help out... You'll be surprised how simple it truly is...
OMR
OMR
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- HerrDeacon
07 Feb 2009 03:34
Thank you very much OMR for posting that, much appreciated. I just got my Dyna-S, coils and plug wires in the mail and this guide will be great!
Thanks again.
Thanks again.
- larrycavan
- Jeff.Saunders
07 Feb 2009 15:28
There's a related step. Checking your charging system to ensure it's not overcharging.
If your regulator has failed you will see over 15 volts when the bikes RPM rise above 4,000 - often climbing over 17 volts.
This is death to electronic ignitons (and doesn't do the rest of the electrical system much good either).
www.z1enterprises.com
Z1 Ent on Facebook,
- nads.com
07 Feb 2009 17:02
still dont know why people cant put things in laymans terms like i can. Lamp meter light, fe3d cannecter, bla. talk english. Some people dont know these things. whatever happeneed to the black wire or the red wire? keep it simple or youll be locked into a dungeon somewhere, the escape insructions will likely be like the small crack at the bilateral pinion fuse under the scurge port. dont worry bout the dingy dingeon cuz the gov will get out. YOU are their kind of guy! Booya
- nads.com
07 Feb 2009 17:11
AND. quit pickin on that 13mm nut! It didnt do anything. Why dont we just cut to the quick and chew the nut off with our teeth and say there! I knew it! I knew it!WEAK I can look real hard at mine and it starts melting down.
- Old Man Rock
07 Feb 2009 17:12
:blink: :huh: :dry: :blink: ....
Dude, WTF are you talk about.... I guess the "Lamp meter light" in the image wasn't English enough....
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
