1980 750H bare bones for mattylight
- loudhvx
Re: 1980 750H bare bones for mattylight
14 Jun 2011 15:13
Yeah, no problem. Do you know what starter and ignition switch you will use? Will you keep the kill switch? Sticking with points?
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
The following user(s) said Thank You: sk8vet
- sk8vet
15 Jun 2011 14:38
Hey, sorry for the false alarm but I'm going to stick with the stock wiring until I get it running right. Afterwards I'll do something more custom and probably come back here
. Thanks for the reply tho!
- loudhvx
18 Jun 2011 11:21 - 10 Jan 2019 10:30
1979 kz650 for grabber.
Drag to the desktep to see in full resolution.
This is for the U.S. models. I don' know if the U.K. models will have variation.
Ignore the stuff to the right of the arrows. That's just for lighting in case you need it in the future. But it would require an ignition switch so the lights won't be on all the time.
EDIT 1/10/2019:
Mattylight Barebones Bare Bones
1979 Kawasaki Kz650 for grabber
Kz 650
EDIT 1/10/2019:
Kz 650
1981 KZ550 D1 gpz.
Other links.
Other links.
Last edit: 10 Jan 2019 10:30 by loudhvx.
- grabber
- loudhvx
19 Jun 2011 11:10 - 10 Jan 2019 10:31
added starter
EDIT 1/10/2019:
Kz 650
EDIT 1/10/2019:
Kz 650
1981 KZ550 D1 gpz.
Other links.
Other links.
Last edit: 10 Jan 2019 10:31 by loudhvx.
- sk8vet
26 Jun 2011 00:54 - 26 Jun 2011 00:56
Hi loudhvx,
I'm back and hoping you can help me out now that I have my plan straight. Again, I have a 78 KZ650 C2 with the following wiring diagram:
diagrams.kz650.info/wiring/images/KZ650-B2,C2.jpg
BUT, my bike didn't come with right hand controls so I found one from a C3:
diagrams.kz650.info/wiring/images/KZ650-B3,C3.jpg
You'll notice the C3 right controls has a mystery yellow wire going to the ignition, and no headlight on/off switch which has me a bit confused.
Will you please help me with a wiring diagram based on the C2, with the C3 right controls, and with the following "deletes":
-No hazards
-No horn
-No speedo or tach
-No front indicators (turn signal indicators, neutral, high beam, oil, brake light fail)
-No starter lockout switch
Since I have no headlight on/off switch I'd like them to be on when I turn on the ignition key (ignition is off/on/park). Also, I will be using points for the time being.
What do you think? Doable?
-No hazards
-No horn
-No speedo or tach
Last edit: 26 Jun 2011 00:56 by sk8vet.
- loudhvx
26 Jun 2011 11:13 - 10 Jan 2019 10:33
I tripled up on the ignition switch contacts to make the ignition switch more reliable. As it's drawn, the input and output of the ignition switch will have 3 wires tied together. Input will be red and two whites. Output is brown, blue, and orange/green. THe blue may actually be blue with a red stripe, or red with a blue stripe.
EDIT 1/10/2019:
1978 Kawasaki Kz650C2 for Sk8vet
Kz650C Kz650 C2 Kz 650 C 650C2 650C
EDIT 1/10/2019:
1981 KZ550 D1 gpz.
Other links.
Other links.
Last edit: 10 Jan 2019 10:33 by loudhvx. Reason: Corrected title on image
26 Jun 2011 11:31
If needed, here's how to save a forum image to your computer:
Click > www.kzrider.com/forum/8-about-the-site/4...age-to-your-computer
The following user(s) said Thank You: loudhvx, nkymain485
- loudhvx
26 Jun 2011 11:49
I put a link to it in my signature.
Thanks Patton.
Thanks Patton.
1981 KZ550 D1 gpz.
Other links.
Other links.
The following user(s) said Thank You: nkymain485
- sk8vet
26 Jun 2011 13:39
amazing! thank you SO much for your help! next time you're in LA, i owe you beers
- loudhvx
26 Jun 2011 15:04
No problem. Hope it works out.
1981 KZ550 D1 gpz.
Other links.
Other links.
- loudhvx
16 Jul 2011 14:15 - 10 Jan 2019 10:36
Bare bones 1979 KZ 750 B4 KZ750 B4 750B4 KZ750B4 twin for Frank Parks
EDIT 1/10/2019:
1979 Kawasaki Kz750B4 twin for Frank Parks
Kz750B Kz750 B4 Kz 750 B 750B4 750B
EDIT 1/10/2019:
1981 KZ550 D1 gpz.
Other links.
Other links.
Last edit: 10 Jan 2019 10:36 by loudhvx.
