Recommendations on carb sync tool
  • Rideallyear
  • Rideallyear's Avatar Topic Author
26 Mar 2026 06:14
#922550
Hello, I have a few carbureted engines in my garage. Some with 1, 2 or 4 cylinders. Although my local vintage bike shop is super nice, they also charge $160/hr. And most of my bikes are now in need of a carb sync (after rebuild or clean up). And so I'm looking at doing the carb sync on my own. I have seen that many of you came up with your own design, but I don't think I have the patience and skills to do that.
And so I'm looking for recommendations of what tool would work best.
Should I get one of these cheap chinese set of gauge off Amazon? Is the Motion Pro decent? Should I cough up a bit more cash for a Carbtune (seems well reviewed)?
80 KZ650 LTD (Project)
81 Honda CX500 (Resto-mod)
20 KLX 140L
21 BMW F850GS
  • rickysnicker
  • rickysnicker's Avatar
Re: Recommendations on carb sync tool
26 Mar 2026 06:19
#922551
I have the Morgan Carbtune and it works very well.  I cannot comment on the other products.
The following user(s) said Thank You: Rideallyear
  • Kofla
  • Kofla's Avatar
26 Mar 2026 07:30
#922556
I think any bike carb synchronizer that uses dial gauges, that allows you to adjust needle fluctuations to ensure a steady, readable vacuum reading should do the trick.
1978 Kawasaki KZ1000 LTD
2010 Kawasaki Ninja ZX-14
  • MFP-Joe
  • MFP-Joe's Avatar
  • forever 18 when on my bike ...!
26 Mar 2026 07:56
#922557
I have a "cheap" 4-clock synchronous tester for two years now, and I'm very happy with it!  - (It works just as well in terms of display and sensitivity as my long-used, high-quality BOEHM 4-clock tester, which I had for 25 years...).. The pics shown while working on both Z1000 bikes.
Z1000 A1 1976
Z1000 A2 1977
Greetings, Joe
  • asphalt900
  • asphalt900's Avatar
26 Mar 2026 08:04
#922558
I've a "Motion Pro stick style" i've had for years. As well as the ole Mercury sticks, still have a glass tube NOS one down in the outbuilding. The Morgan Carbtune is a Nice one, never owned one Though. Sorry Kofla, those Analog individual gauges can be a bear and come with calibration issues. Some have removable lenses to set the needles but that's often only in a "certain" range of vacuum. Of course some gauges are Much better then others but Steer Clear of those Blue backplated Amazon units, they are crap. I have a set i will give you, they are just that bad. A kid gave them to me years ago and just threw them in a box.
The following user(s) said Thank You: Warren3200gt
  • Rideallyear
26 Mar 2026 08:11
#922559
So is it fair to say that the vacuum gauges would work fine as long as I can calibrate them individually and the quality is decent.
The mercury-based system might be more reliable but more expensive?
20 KLX 140L
21 BMW F850GS
  • ckahleer
  • ckahleer's Avatar
26 Mar 2026 08:47
#922560
I struggled with the Motion Pro sync tool for years. Then a few years ago, I gave up on it and got a Carbtune. Couldn't be happier. It's plug and play.
97 ZL600
94 VF750c
94 KE100
82 KZ305
  • TexasKZ
  • TexasKZ's Avatar
26 Mar 2026 12:18
#922561
Another happy Morgan Carbtune user here.
  • Rideallyear
26 Mar 2026 12:39
#922562
Thank you all. I think i'll try the Carbtune and see how that goes.
20 KLX 140L
21 BMW F850GS
  • Nessism
  • Nessism's Avatar
26 Mar 2026 15:22
#922565
The old mercury gauges worked great, just as long as you don't spill them and have a good place for storage.  Sadly, mercury gauges are no longer being sold in most countries.  I strongly recommend the Carbtune, if you can afford them.  They work just as good as mercury, but safer, and easy to store.
  • ThatGPzGuy
  • ThatGPzGuy's Avatar
27 Mar 2026 05:29
#922575
I have a Carbtune and it works well, much better than the dials. Recently came across this that I might try:  Digi Sync
Jim
North GA
2016 Yamaha FJR1300ES
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
1979 Yamaha XS650 cafe'
2001 KZ1000P (sold)
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
  • TexasKZ
  • TexasKZ's Avatar
27 Mar 2026 05:40 - 27 Mar 2026 05:42
#922577
I considered the digital tool, but I decided I did not want yet another battery-eating tool, especially one that I would use so infrequently.
It may be more accurate than the other options and if I was setting up race bikes, that would be a strong consideration.
Last edit: 27 Mar 2026 05:42 by TexasKZ.
