Choke plunger Vm28ss
  • Maxbou92
  • Maxbou92's Avatar Topic Author
25 Oct 2024 09:16
#905432
  Hello guys, does these Choke plunger fit on the vm28ss carbs?  There were Niche plunger, the seller tell me that ; eBay item number: 162890295846 Genuine Mikuni VM29 VM33 Smoothbore Starter Plunger Valve VM24/510
Kz750e 1980
  • SWest
  • SWest's Avatar
  • 10 22 2014
  • Maxbou92
Re: Choke plunger Vm28ss
25 Oct 2024 10:08
#905435
Thank youu, but your plunger doesnt have the nipple at the bottom ?! Vm24 are similar at vm28 but I dont know if they fit..
Kz750e 1980
  • Maxbou92
25 Oct 2024 10:26
#905436
The site jetsrus has Vm24 plunger !! When someone confirm me that they fit, I will order them
Kz750e 1980
  • zed1015
  • zed1015's Avatar
25 Oct 2024 12:38 - 25 Oct 2024 12:43
#905438
The ones from Niche fit the VM22,24,26,28 and smooth bores.
They are genuine Mikuni but reproduced for the Japanese market and in particular the classic kawasaki race series and don't have viton seals so are not ethanol fuel resistant  ( which is the case with all pattern plungers ) which is fine if you have the option of running ethanol free fuel but won't last long if you don't.
The majority of fuel on Japanese forecourts is ethanol free except the option of around 2% at one pump which apparently isn't popular.
Last edit: 25 Oct 2024 12:43 by zed1015.
  • Maxbou92
25 Oct 2024 12:41
#905439
Thank you Zed, again!!! Does this oring size can fit on my old plunger 6.75mm (od) x 2.1mm (id) x 2.15mm (thick). ?!
Kz750e 1980
  • zed1015
  • zed1015's Avatar
25 Oct 2024 13:39
#905444
The plunger seals are not 'O' rings.
They are flat lathe spun discs and not available as a seperate part.
The ones i fit are custom made by myself to the exact dimensions of the originals from 75 shore viton to fit each individual plunger.
The VM/SS (16016-021 plunger type ) blanks are 2mm thick with 2mm hole and 7.4 mm diameter with a 40 degree chamfer on the perimeter of one face to conform to the underside of the plungers swaged brass retaining edge.
The following user(s) said Thank You: Nessism, sf4t7, Scirocco, Wookie58
  • Maxbou92
25 Oct 2024 14:34
#905447
So even of I put a Seal/oring it won’t be good !! Thank youu
Kz750e 1980
  • SWest
  • SWest's Avatar
  • 10 22 2014
25 Oct 2024 15:02 - 25 Oct 2024 15:11
#905448
There was no obvious difference between the new ones or the old ones.
Last edit: 25 Oct 2024 15:11 by SWest.
  • SWest
  • SWest's Avatar
  • 10 22 2014
25 Oct 2024 15:08
#905449
I changed mine for GP. Didn't make any noticeable difference. The ones in there were still working but having new ones allowed me to rule out one more thing then move on.
kzrider.com/forum/3-carburetor/618866-choke-plungers#884064
  • Maxbou92
25 Oct 2024 15:33
#905451
What is GP ?!
Kz750e 1980
  • SWest
  • SWest's Avatar
  • 10 22 2014
The following user(s) said Thank You: Maxbou92
