KZ650 - STILL not possible for WOT :-(
19 Jul 2024 14:49 - 20 Jul 2024 02:09 #902362 by zed1015
Replied by zed1015 on topic KZ650 - STILL not possible for WOT :-(
 Will choke plungers from VM24 fit into VM26?
Yes! All the 3 bolt top VM plungers are pretty much the same.
Some early chromed plungers have a slightly longer metering needle but it makes no difference.
Last edit: 20 Jul 2024 02:09 by zed1015.
The following user(s) said Thank You: Scirocco
19 Jul 2024 19:49 #902372 by F64
Replied by F64 on topic KZ650 - STILL not possible for WOT :-(
Wookie mentioned your shift light.... How did you wire up your shift light?
81-KZ440-D2.
LIC, NY
20 Jul 2024 01:04 #902375 by Womtong
Replied by Womtong on topic KZ650 - STILL not possible for WOT :-(
Have you tried disconnecting the ignition pulse to your "shift light" ? (it is possible that there is a conflict between the ignition module and the shift light circuit ?)
 Tanks and sorry, have overseen your post.
 Have thought about that but there is no direct link between shift flash and ignition. The speedo is simply connected and get rpm from positive wire of right coil.
20 Jul 2024 07:26 #902378 by F64
Disconnect that tach wire and take it for a ride.
81-KZ440-D2.
LIC, NY
  • SWest
  • 10 22 2014
20 Jul 2024 09:47 #902382 by SWest
Replied by SWest on topic KZ650 - STILL not possible for WOT :-(
Makes sense. If it's robbing one coil of even a little power the bike won't run for SHT.
20 Jul 2024 14:20 #902396 by Wookie58
Replied by Wookie58 on topic KZ650 - STILL not possible for WOT :-(
That doesn't sound right, the positive side is a constant ignition live, surely the tach pulse should be on the switched side of the coil ????
The following user(s) said Thank You: Warren3200gt
20 Jul 2024 16:49 - 20 Jul 2024 18:37 #902400 by F64
Yeah, Wookie it's a weird one. I tried to find the installation instructions last night. It has a positive coil wire tie in.
I'll dig up the instructions and post when I get back home.
photo: W&W Cycles
81-KZ440-D2.
LIC, NY
Last edit: 20 Jul 2024 18:37 by F64.
21 Jul 2024 00:57 #902408 by Wookie58
21 Jul 2024 12:12 #902424 by Womtong
Thanks guys for thinking over the electrical thing.
 Just tried with complete unplugged tachometer. No change at all…
Additional done a WOT plug chop.
 Approximately 2 miles with only wot.
 See first picture below. Too short or real lean.
 Darker plug from right now 40 miles on the sharp ridden.
 The hotter the engine, the better the bike runs. That's what I noticed.
 But Topspeed only 150kmh. To that point she pulls very strong. Notice on 7/8 throttle from 5 to 7k that the engine sounds little “louder“, could be little more greedy. Difficult to explain.
 For me it looks like to go back to 112 main.
 Your suggestions?
21 Jul 2024 13:40 - 21 Jul 2024 13:51 #902428 by zed1015
What grade plug is that.
The ground strap ( heat range ) indicates you may need a colder plug.
2nd pic darker base ring ( mixture strength)  looks wet so either oily or rich.
1st pic is very clean and looks fuel washed .
Engine running louder may be detonation.
Before you dig back into the jetting try applying the choke ( enrichener ) to add more fuel at high rpm and see if it improves.
Last edit: 21 Jul 2024 13:51 by zed1015.
21 Jul 2024 14:43 - 21 Jul 2024 15:07 #902429 by Womtong
Plugs are NGK B8ES
Colder plug is B7ES or B9ES?
 What do you mean with louder are detonations?
 You are right, jetting will not help because I have tried to use enricher during jerking. Makes it little worser…
Last to tries for me if you all have no idea: VM26 and jump to Dyna ignition.
There is something other wrong. Any further subsections?
Edit: This is new: During deceleration from high rpm I had 2 times on that 40 miles a very load exhaust detonation. Means too rich I think?
Last edit: 21 Jul 2024 15:07 by Womtong.
21 Jul 2024 15:48 - 21 Jul 2024 15:53 #902430 by zed1015
Colder is B9ES.
Backfiring on decel can be caused by excess fuel being burnt in the exhaust but can also be caused by other issues such as an exhaust air leak etc.
If backing off the throttle at WOT improves running you may need smaller main jet.
Another thought.. Have you tried running the bike with the pods removed..
Last edit: 21 Jul 2024 15:53 by zed1015.
The following user(s) said Thank You: Womtong
