Two carbs getting gas, two do not.
  • Warren3200gt
  • Warren3200gt's Avatar
Re: Two carbs getting gas, two do not.
30 May 2023 06:23
#885397
No, nothing fits there. They are just from the common mould used for 1&2 and then then one from 3&4..
If you push a probe down you'll find the are blind.
The following user(s) said Thank You: SRQ Mike
  • Nessism
  • Nessism's Avatar
30 May 2023 07:31 - 30 May 2023 07:32
#885400
Those small joining hoses, between 1-2 & 3-4, are to join together for float bowl venting.  So, there are two vents, instead of having to run four.
This particular diagram is for the larger VM26 carbs, so the details about the fuel feed Tee's doesn't match your VM24 carbs.  Disregard that part.
Last edit: 30 May 2023 07:32 by Nessism.
  • SRQ Mike
  • SRQ Mike's Avatar Topic Author
06 Jun 2023 12:15
#885690
Update:  I have broken down the carbs, soaked the carb bodies, cleaned the passages and cleaned the jets, replaced the O rings (Thanks Nessism), reassembled the carbs, set the float heights, checked for floats hanging up, watched YouTube videos for additional ideas, consulted with a neighbor AND the number two carb is still getting no fuel and number three is getting minimal fuel.  The floats appear to have free movement/not hanging up.  This is the original problem with the carbs.    The bike is a 79 KZ 650 with air screw Mikuni carbs.  (VM24?)
What else should I check?   I would be pulling my hair out, but I'm already bald.
Thanks in advance for any suggestions.
1979 Kawasaki KZ650 SR
  • gd4now
  • gd4now's Avatar
  • Denco where did you go?
06 Jun 2023 12:36
#885691
Sorry but I am sure I have read all of this topic/post but have not gone back and re-read it.  So take this with that info, but since they are from a 79 model year stock it would of had a vacuum petcock running from a port on #2 carb.  If the diaphram in the petcock has a tear in it, it can pull fuel up the vacuum hose from number 2 and flood the carb/cylinder with fuel.and change the ratio of fuel to air in number 2 and not run correctly.  If this is true it may also add fuel to the crankcase.
Since number 1 carb appears to be working fuel is passing from the fuel inlet between 2 and 3 and passing on to number 1. Is there fuel in the bowl on number 2?
1977 KZ650 B1
Pods and Denco header
OLD KAW OWNERS SMILE ALOT
  • hardrockminer
  • hardrockminer's Avatar
06 Jun 2023 12:58
#885692
There should be a joiner between 1 and 2, and 3 and 4.  Therefore no need for a joiner between 2 and 3.  If your carbs are mounted correctly on the rack you may find that the outlet in the photo was never drilled out.
  • SRQ Mike
06 Jun 2023 14:16
#885694
There is no fuel in the number 2 carb bowl.  Dry.
  • SRQ Mike
06 Jun 2023 14:30
#885698
There is no fuel in the number 2 bowl.  Dry.
  • Warren3200gt
06 Jun 2023 14:31 - 06 Jun 2023 14:34
#885699
What happens if you squirt carb cleaner up the float vavle seat on #2? Where does it come out.?
It can only be a fuel feed blockage or a air vent blockage. But if it was an air vent blockage the bowl wouldn't be bone dry.
Last edit: 06 Jun 2023 14:34 by Warren3200gt.
  • SRQ Mike
06 Jun 2023 14:53
#885701
The carb cleaner mostly comes out the fuel inlet T.  Some blows back but I guess that's to be expected.
  • hardrockminer
07 Jun 2023 03:49
#885720
Are you sure you have each carb in its correct position on the rack?  1 and 4 should only allow fuel through the inside of the fuel insert.  The outsides should be blanked off.  On 2 and 3 you should be able to see daylight if you look through the fuel insert.  Both sides should allow fuel into the carbs.  2 is the one with the pump.
You should have two nipples on #2 carb.  One is near the downstream side and is used to provide vacum for the petcock.  If you're using a gravity only petcock this nipple must be blocked off.  I normally use one of the rubbers that go on the intake manifolds.
  • SRQ Mike
07 Jun 2023 05:10
#885726
Yes.  All of what you describe sounds exactly the way mine are arranged.  I've had the bike running, with fuel getting to all the carbs except for number 2.   I'm thinking that there is a problem with the float or the float or the float needle valve on number two.  Unfortunately, nothing obvious.
  • Wookie58
  • Wookie58's Avatar
  • Away
  • Moderator
  • Moderator
07 Jun 2023 05:47
#885728
Have you tried removing the float and needle assembly, put the bowl back on and turn on the fuel - does the bowl now flood?
Yes: fault relates to the float or needle
No: fault is a blockage in the carb body
