Replaced perished manifold boots now v high idle speed
Re: Replaced perished manifold boots now v high idle speed
18 Mar 2023 05:49
You are correct in that the small screws are the only thing holding in the choke plate. Also note the dimples on the plate, forcing it to be installed/removed from one side only. If the plate doesn't come out easily, it's because it's bent, and you may need to use force. When you replace the screws, be sure to use RED loctite, the permanent type. Loosely install the plate/screws, actuate the choke to make sure it moves smoothly, then tighten the screws evenly, and double check the plate/shaft movement.
The following user(s) said Thank You: howardhb, Jimbo68
- Warren3200gt
18 Mar 2023 06:43 - 18 Mar 2023 06:48
As its the bottom half that's bent it doesn't look too hard a job to straighten it in situ. It's only thin sheet which parallel jaw pliers would sort.
Last edit: 18 Mar 2023 06:48 by Warren3200gt.
The following user(s) said Thank You: Jimbo68
- Jimbo68
18 Mar 2023 08:27
I’ve put the carbs back on my bike and it starts, runs, and idles ok.
Thank you EVERYBODY here who helped me. I’ve learned a huge amount and resolved the original problem, to replace the perished intake boots. New problems along the way, also fixed.
I didn’t do a full strip down, but I will. I needed to reinstall it in my bike, just to give me the confidence that after the changes and tests I’d done, all worked ok. I can tell it’s not running perfectly yet: the occasional pop from the exhaust and the idle fluctuates between 900 and 1300. When I did a wet test, the RHS carb looked good, the LHS one was odd and seemed to defy logic: the petrol didn’t sit level on each side of the bend. It was a bit higher on the end AWAY from the overflow outlet, and neither side was close to where the bowl meets the main body of the carb. Yet the bowl was filled with petrol and when drained seemed to contain a similar volume to the RHS bowl.
Next time, when I’ve got more free time, I’ll follow the common sense advice from many of you, and fully strip it, clean it, straighten the choke plate, investigate the wet test observation, and remove, clean, and replace the petcock filter. For that, I’ll start a new forum topic.
Meantime, I’ll order replacement o rings for the rebuild, buy a compressed air can, read relevant forums here, and be much better prepped.
Thanks again all. My baby is back on the road
1981 Kawasaki KZ440-A2
- Jimbo68
02 Aug 2023 11:24
Hi there folks.
I'm back, with an aspiration to get the carbs out my KZ440 LTD and tear down, clean, and straighten the bent choke plate. First, gather everything I need...
@nessism, you mention here you have a replacement o ring kit for my pair of carbs. Is that still the case please?
Other pre-tear down questions:
Can anyone recommend a carb soak product please? I have an aerosol but I'm guessing the soak comes in a large pouring vessel? I'm UK-based.
Any step by step guides you know of for tearing down my specific carbs?
I recall reading/seeing somewhere there is a specific item on the carb to screw down until tight, counting the turns hence knowing how much to back it out when re-assembling. Any more information please?
Is it wise to replace the rubber hoses?
I'd appreciate info about any possible gotchas for both the internal disassembly and the disconnecting/reconnecting of the carb pair, including the spring assembly for the throttle.
Is there any part of the carb I SHOULDN'T disassemble?
Suggestions for compressed air? I can get aerosols but with previous purchases of such things, I've noticed liquid dribble out and mix with the jet of air. Might that liquid be detrimental to the target holes?
FYI I have the maintenance manual.
Thanks a million.
Thanks a million.
