Carb opinion
Re: Carb opinion
13 Dec 2022 15:46The cutaway is 1.5 on those carbs slides.The cutaway is that missing section on the bottom of the slide. There should be a number on the slide...I think on the bottom. It will either be 1.5 or 2.0.
I can see the air/fuel adjuster on the intake side of the carb. This is evidence of them being from a KZ900.
I noticed a date code on one of the photos. 65. That means either June/75 or May/76. In either case it points to those being from a KZ900. The cutaway will be definitive.
Re: Carb opinion
13 Dec 2022 17:25
If so then those are almost certainly off a KZ900. Good carbs. I have them on my 1980 KZ1000 LTD.
- LukasLee
Re: Carb opinion
13 Dec 2022 18:12
Yes it does have 1.5 stamped on the bottom of the slide, I didn't know that 65 was a date code, interesting !
Now I will try to find float bowls for them.
1979 KZ1000 LTD
1978 CB750F
2012 FLHTK
1978 CB750F
2012 FLHTK
Re: Carb opinion
13 Dec 2022 20:19Now I will try to find float bowls for them.
Mikuni VM float bowls fit a variety of different size and make carbs. Suzuki VM bowls should be the same as KZ VM bowls, for example. Realize that there are two types; those with the drain facing right, and those facing left.
- LukasLee
- LukasLee
Re: Carb opinion
13 Dec 2022 21:56
Haven't got this quote part figured out yet. lol
OK Thanks for the info on the float bowls.
1979 KZ1000 LTD
1978 CB750F
2012 FLHTK
1978 CB750F
2012 FLHTK
Re: Carb opinion
14 Dec 2022 04:44
Can you use the bowls currently on your Suzuki carbs?
- LukasLee
Re: Carb opinion
14 Dec 2022 10:08Can you use the bowls currently on your Suzuki carbs?
I could yes, I would like to have them complete & ready to go. There are 2 motorcycle salvage places near by I will see if I can find some there.
1979 KZ1000 LTD
1978 CB750F
2012 FLHTK
1978 CB750F
2012 FLHTK
- LukasLee
Re: Carb opinion
14 Dec 2022 18:37
Picked up an almost set today, 1 bowl drain pointing north instead of south.
1979 KZ1000 LTD
1978 CB750F
2012 FLHTK
1978 CB750F
2012 FLHTK
- LukasLee
Re: Carb opinion
15 Dec 2022 11:32Hardrockminer,If so then those are almost certainly off a KZ900. Good carbs. I have them on my 1980 KZ1000 LTD.
Do you have pods, if so what jets are you running ?
1979 KZ1000 LTD
1978 CB750F
2012 FLHTK
1978 CB750F
2012 FLHTK
- zed1015
Re: Carb opinion
15 Dec 2022 12:09 - 15 Dec 2022 12:12For running pods you just need air corrector jets and go up a size from stock on the mains.Do you have pods, if so what jets are you running ?
No need for any other mods, all other settings, pilot jets and needle position remain stock but use good quality free flowing pods such as K&N, S&B etc and not cheap chinese knock offs as these are generally restrictive .
Air corrector jets for Mikuni VM 24, 26 and 28mm round slide Mikunis. - KZRider Forum - KZRider, KZ, Z1 & Z Motorcycle Enthusiast's Forum
Air corrector jet kit.Kawasaki Z1,Z650,Z900,Z1000,Z1R.MK2, MIKUNI.LEDAR.PODS.K&N | eBay
Last edit: 15 Dec 2022 12:12 by zed1015.
Re: Carb opinion
16 Dec 2022 04:58 - 16 Dec 2022 05:05No, I don't have pods. I use a Z1 airbox because it's so easy to install the carbs compared to the original airbox. I also have a 4/1 exhaust. From memory I think I have 107.5 main jets and 17.5 pilots. The needles and needle jets are original to the carbs but I don't remember what setting for the needles. The bike starts easily on choke and quickly stabilizes and idles well. It pulls well in all gears but is a bit hard on gas.
Last edit: 16 Dec 2022 05:05 by hardrockminer.
