O-ring needed for TK26 carbs
24 Oct 2022 07:11 #875914 by stardon
Replied by stardon on topic O-ring needed for TK26 carbs
When I used to work on General Aviation aircraft we would use the MS29513 series o-rings. These are fuel resistant and I used them in my GPZ carbs. They can be purchased at almost any aviation supply place like Wicks Aircraft Parts or Aircraft Spruce. Some FBO's may even stock them too.
The following user(s) said Thank You: martin_csr, GpzGreen
  • GpzGreen
  • Topic Author
05 Nov 2022 12:08 #876421 by GpzGreen
Replied by GpzGreen on topic O-ring needed for TK26 carbs
A local motorcycle shop had the correct size.  They looked to the carbs and suggested I do a better job of cleaning, so I have since got the K&L carb kit for the carbs/bike.  They sure ask a lot for kit$ without all the Orings you need,
I am scrubbing everything more thoroughly now but cannot get the valve seat out to replace the Oring and I suppose the seat itself as it gets marred up.
Any tips to getting the seats out without making a mess?  They rotate but will not pullout.
1982 GPZ-550
  • Nessism
05 Nov 2022 12:24 #876423 by Nessism
Replied by Nessism on topic O-ring needed for TK26 carbs
Heat will help soften the varnish and melt the rock hard O-ring.  Go easy with the pliers on the seat, or you will crush it.  And keep the needle and seat together, don't mix.
The following user(s) said Thank You: GpzGreen
  • GpzGreen
  • Topic Author
05 Nov 2022 13:16 #876425 by GpzGreen
Thank you for the help in this thread, work seems to be getting in the way of my progress...
I have a new needle and seat in the rebuild kit but the original needle has no wear.
Should I just clean and re-oring the original parts?
1982 GPZ-550
  • Nessism
05 Nov 2022 14:17 #876430 by Nessism
If the original brass is in good condition, I'd use it.  Can't say I'm a big fan of K&L.  For one thing, in their Mikuni kits, the float needle spring is too weak to hold up the float.  Not sure about their TK parts, though.
  • GpzGreen
  • Topic Author
06 Nov 2022 09:46 #876473 by GpzGreen
Heat was the answer!  More Orings to replace.  3 more per carb and it should be ready to hit the starter soon.
I have read varying opinions on installing a fuel filter after the petcock.  See through metal mesh or stock without?
1982 GPZ-550
  • GpzGreen
  • Topic Author
12 Nov 2022 17:14 - 12 Nov 2022 17:30 #876727 by GpzGreen
Carbs cleaned as clean as I can get them, including the gasket channels on the bowls, all new properly fitting Orings.  Got it all installed and put the petcock on Prime then to Reserve.
Now the new bowl Oring/gaskets are leaking.  Son mentioned that the gaskets seemed a little small and did not fall into the grooves of the bowl very well, but he thought he got them to work out.  No dice, 2 bowls leaked and dripped until I pulled the fuel line and drained the bowls with the drain screw. Gave up for the night but will disassemble in the morning. Floats were set to 27mm per the service manual.
Anything I might be missing, or do I just need to find a better brand than K&L to get bowl gaskets from that fit properly?
1982 GPZ-550
Last edit: 12 Nov 2022 17:30 by GpzGreen.
  • Nessism
12 Nov 2022 17:30 #876728 by Nessism
I'm not sure, having not seen what you are dealing with, but I recommend using a dot cyanoacrylate adhesive (super glue) in the float bowl groove at each corner, to hold the O-ring.  Use tape to hold the O-ring down until the adhesive drys.  This works for the CV34's on the 750/4 bikes anyway.
  • GpzGreen
  • Topic Author
12 Nov 2022 18:11 - 12 Nov 2022 18:11 #876729 by GpzGreen
So, there is a groove for a round gasket in the bowl, old one was flat and hard.  Attached image.
1982 GPZ-550
Last edit: 12 Nov 2022 18:11 by GpzGreen.
  • GpzGreen
  • Topic Author
18 Nov 2022 16:30 #876959 by GpzGreen
So, I got more bowl O-rings and used the 'superglue' fix.  Still have one carb bowl leaking from one corner.
Is there any fuel resistant RTV to end this leaking/dripping gasoline problem?  This problem is getting old...
1982 GPZ-550
  • riturbo
19 Nov 2022 08:43 - 19 Nov 2022 08:43 #876974 by riturbo
Replied by riturbo on topic O-ring needed for TK26 carbs
I use a dab of grease to hold the o rings in place long enough to get the bowls on . Just smear a bit all along the bowl groove then put the o ring in .
Gpz 750 turbo The one I ride
Gpz 750 turbo Not finished
Gpz 750 turbo Not started
Gpz 550 1981
Gpz 550 1983
Bunch of other junk
Last edit: 19 Nov 2022 08:43 by riturbo.
