Any Interest In Carburetor O-ring Kits?
  • Nessism
  • Nessism's Avatar Topic Author
03 Sep 2022 14:06 - 03 Sep 2022 14:15
#873295
I've got pretty much all the various O-rings needed to rebuild Mikuni VM and BS/CV sets, and most of the sizes for Keihin CV34s too (will complete set if anyone is interested.)
Only sizes I'm not positive about is for the VM pumper nozzles and CV pilot plug.  I think I've got the proper size, but need help confirming.
Anyway, if you guys are interested, please drop me a PM to discuss.  I've got a post up on The GS Resources about this already.  I decided to do this because cycleorings.com is down now, and not likely to go back up.
Last edit: 03 Sep 2022 14:15 by Nessism.
  • Mikaw
  • Mikaw's Avatar
Re: Any Interest In Carburetor O-ring Kits?
03 Sep 2022 18:06
#873306
Yes!
  • Cfoux85
  • Cfoux85's Avatar
  • 1982 Kawasaki kz 750e
03 Sep 2022 22:22
#873312
is there supposed to be an o ring thats covered by the plug that's in the float bowl? I'm not sure which jet that is
  • Nessism
04 Sep 2022 05:42
#873318
There is an O-ring for the pilot plug on both the CV34 and BS series of carbs.
  • Wookie58
  • Wookie58's Avatar
  • Moderator
  • Moderator
04 Sep 2022 14:34
#873349
Any idea what shipping to the uk would be for my 82 1000ltd. You are obviously discerning in the parts you use so I would rather buy from someone that will supply the right thing to a good quality than take a punt on the parts lottery.
  • riturbo
  • riturbo's Avatar
05 Sep 2022 04:50
#873366
Id take  some when they are ready
Gpz 750 turbo The one I ride
Gpz 750 turbo Not finished
Gpz 750 turbo Not started
Gpz 550 1981
Gpz 550 1983
Bunch of other junk
  • Nessism
05 Sep 2022 05:05 - 05 Sep 2022 05:08
#873367
I'm not an expert on international shipping, but a "letter" size envelope can be mailed for about $4 USD.  Please share if you know of a cheaper way.
Last edit: 05 Sep 2022 05:08 by Nessism.
  • Nessism
05 Sep 2022 05:12
#873368
CV kit?  If so, I need help measuring the pilot plug.  Use calipers and measure the OD of the plug, in the O-ring groove.  Also, the ID of the carb passage it plugs into.  The kits I've got were originally intended for Suzuki GS Mikuni's, which don't use the same type of pilot plugs as the KZ Mikuni's do.
  • Wookie58
  • Wookie58's Avatar
  • Moderator
  • Moderator
05 Sep 2022 05:27
#873370
IF you want to PM me with an all in price I am definitely interested, do you take "Paypal" as a payment option ?
  • Nessism
05 Sep 2022 06:06
#873372
Okay guys, these are the base level kits.
Mikuni BS/CV Kits Includes
- 4 Pilot Screw O-rings
- 4 Float Valve O-rings
- 4 Choke Plunger Cap O-rings
- 12 Fuel Tee/Transfer Tube O-rings
- 4 Drain Screw O-rings
NO PILOT PLUG O-RINGS - I NEED INFO SO I CAN ORDER THE RIGHT SIZE
These kits are for the common BS32/34/36 four cylinder bike sets. I don't have experience with the 450 sets or the two barrel 2nd gen 550 carbs. Sorry.
Mikuni VM Kits Include
- 4 Pilot Fuel Screw O-rings
- 4 Pilot Air Screw O-rings
- 12 Fuel Tee/Transfer Tube O-rings (I don't think KZ's use these, but they are included regardless, unless you state you don't want them)
- 4 Needle Jet O-rings
All O-rings are Nitrile/Buna-N. These O-rings will swell slightly with gasoline contact, which helps improve the seal.
Cost is $20 shipped CONTUS per set. Paypal, cash in an envelop, check, all accepted. International shipping on a case by case basis. Canada is just a small adder.
  • Wookie58
  • Wookie58's Avatar
  • Moderator
  • Moderator
05 Sep 2022 09:51
#873385
CV34 sizes I have measured are
"O" ring - ID 3.18mm OD 6.09mm
Orifice - 5.64mm
Plug groove - 3.14mm
Hope this helps
  • zed1015
  • zed1015's Avatar
05 Sep 2022 10:20 - 05 Sep 2022 10:28
#873388
When i post out jets and plungers the cost overseas worldwide is £11 which is around $13 depending on the exchange rate.
That is via first class tracked and signed large letter ( 00 or 000 size jiffy ) to have proof of postage,delivery and tracking info .
I also send as a gift with a declared value under £39 or under £15 if marked commercial to avoid customs ,vat and handling charges which can sometimes cost more than the actual item.
They could be sent cheaper without the tracking and 2nd class etc for around half that but for my purposes it isn't worth the risk.
I've also found that if you try to send as a plain letter and it contains anything other than a letter /paper etc you still have to apply a CN22 customs lable and declare the value and contents etc which then puts it back in the large letter catagory and the higher shipping cost bracket.
At the end of the day the shipping cost is what it is and if you can't get the parts elsewhere it's still going to be worth it if it gets your bike running again rather that sat unridable and losing value at the back of the garage.
Last edit: 05 Sep 2022 10:28 by zed1015.
The following user(s) said Thank You: Nessism, Wookie58
