KZ650. Carb #3 spitting fuel out. Wont start
  • BlackEyeCafe
  • BlackEyeCafe's Avatar Topic Author
17 Aug 2022 09:16
#872386
Hello KZ communityI have been having trouble starting my 1977 KZ650.
After tearing the carb down and re-leveling the floats it still won't start.
Today I noticed when trying to start that the 3rd carb from the left was spitting fuel.  Can anyone help guide me to a resolution?
Thanks in advance.
Btw i searched the forum first and the first 10 results did not provide a solution
1977 KZ650 C
Jets - Main 115 - Pilot 17.5 - Needles - Position 3 - NGK BR7ES
  • gd4now
  • gd4now's Avatar
  • Denco where did you go?
Re: KZ650. Carb #3 spitting fuel out. Wont start
17 Aug 2022 09:32
#872388
Just where is the fuel spitting from?  The overflow port/tubes or out the intake bell of the carb?
1977 KZ650 B1
Pods and Denco header
OLD KAW OWNERS SMILE ALOT
  • BlackEyeCafe
17 Aug 2022 09:34 - 17 Aug 2022 10:08
#872389
It's coming out the intake and into the air filter pods
1977 KZ650 C
    IMG_0846.MOV
Last edit: 17 Aug 2022 10:08 by BlackEyeCafe.
  • F64
  • F64's Avatar
  • 81-KZ440D2
17 Aug 2022 10:18
#872390
pull the plugs.
are your plugs fouled?
81-KZ440-D2.
LIC, NY
  • BlackEyeCafe
17 Aug 2022 10:38 - 17 Aug 2022 10:46
#872391
The 3rd was soaked in fuel and all had a little soot built up
1977 KZ650 C
Last edit: 17 Aug 2022 10:46 by BlackEyeCafe.
  • Mikaw
  • Mikaw's Avatar
17 Aug 2022 10:52
#872392
You can save that plug so you can test, use a propane torch and heat the ceramic and earth strap. It will take some time but eventually the ceramic will start to lighten, continue to heat till the whitest color is achieved.
  • Mikaw
  • Mikaw's Avatar
17 Aug 2022 11:05
#872393
Are all the vacuum nipples installed on the carb holders. If it’s not flowing out of the overflow tube then it not likely to be float level, unless the overflow tube plugged.
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Premium Member
17 Aug 2022 11:07
#872394
It could be stuck open float needle valve. Try knocking on bowl to free the valve.
  • BlackEyeCafe
17 Aug 2022 12:43
#872396
Thanks everyone. I’m going to try all those things. I will let you know what happens
1977 KZ650 C
  • zed1015
  • zed1015's Avatar
17 Aug 2022 13:52
#872398
How's the valve clearances ?
If 3 is too tight it may not be seating and blowing back.
  • BlackEyeCafe
17 Aug 2022 14:08
#872400
So I tried everything except torching the plugs because I checked for spark and all 4 plugs were working well.
Could this be a timing issue or air screw issue?  I did the valves and did not touch the Dyna ignition after that, would I be better to re-adjust the timing?
1977 KZ650 C
  • BlackEyeCafe
17 Aug 2022 14:14
#872401
That is my main concern. I just went back over the math and I may have “mis-mathed” on # 3. Thankfully I kept notes and it will just mean ordering a new shim and the excitement of tearing apart the top end again…..
1977 KZ650 C
